Old 06-05-2005, 04:48 AM   #13756
hi, i have no trouble getting the ride height low enough, with the collars full unwound i hav 1mm rideheight. are you using the rayspeed sprig retainers? insteads of the plastic ones that come with the kit? you have to use the rayspeed ones as the shock towers are so low.
hope that helps
agower is offline   Reply With Quote
Old 06-05-2005, 04:50 AM   #13757
also make sure you are using the short shock rod ends, i have mine screwed up until there is only a tiny bit of thread left showing on each rod.
Old 06-05-2005, 05:37 AM   #13758
rraden's Avatar
Trader Rating: 235 (100%+)
Default SDW vs LCG
I'm new to Yokomo cars and was wondering what's the difference between the MR4TC-SDW and the new LCG conversion? Which ones better?
rraden is offline   Reply With Quote
Old 06-05-2005, 06:50 AM   #13759
hurley081182's Avatar
Trader Rating: 15 (100%+)
Send a message via AIM to hurley081182 Send a message via Yahoo to hurley081182
the sdw is suppose to be already setup for you when u put it together. not sure about the lcg i just know i want to get lcg kit though
Old School Stampede=FUN
hurley081182 is offline   Reply With Quote
Old 06-05-2005, 07:21 AM   #13760
the lcg is a updated and more user friendly version of the sdw. the sdw is a complete car, the lcg is a conversion kit to update the ssg chassis but you can also use the cgm or sdw chassis parts. the sdw is a limited edition car and parts may be hard to find shortly.
Turtlemaster is offline   Reply With Quote
Old 06-05-2005, 09:54 AM   #13761
Originally Posted by blindwolf
Hi,
I recently upgraded my ssg to the lcg and know im unable to get my ride height lowered beyond 5.5mm. Im using the yokomo dampers(aluminum bodies) w/ stainless springs. The dampers are using rayspeed all around badders w/ rayspeed piston rings(1mm 2 hole) with 40wt oil. I have loosened the collars all the way to the top to no avail.(springs sloppy on shaft) Still does not drop. Any reason for this? Any and all help much appreciated.
Check to see which hole you have the caster block in. The upper and lower hole can make a difference too.
Also where you put the spacer, on top or below the steering hub will make a difference as well.
pops is offline   Reply With Quote
Old 06-05-2005, 10:08 AM   #13762
STLNLST's Avatar
Trader Rating: 21 (100%+)
good run yesterday in the slidefest. The track was very inconsistent for everyone in mod yesterday no matter what tire we were using. I couldn't power out of the turns no matter what I did to the set up. I see you guys switched to the oneway....I was going to but was scared that due to the low bite it would get worse with the oneway. What was your take on the spool vs the oneway yesterday? Be sure to post for Matt H. that I did hook ya'll up with a killer motor. he doesn't love me anymore See ya next weekend.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 06-05-2005, 10:18 AM   #13763
Matt Howard's Avatar
w h a t e v e r
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 06-05-2005, 10:20 AM   #13764
STLNLST's Avatar
Originally Posted by Matt Howard
w h a t e v e r
Old 06-05-2005, 10:34 AM   #13765
shouldn't you be practicing for the Speedworld Cup instead of stalking me?
RCTech #361
Old 06-05-2005, 10:38 AM   #13766
Is for the Yokomo SDW a sway bar kit available with various sway bars?
darulor is offline   Reply With Quote
Old 06-05-2005, 10:45 AM   #13767
yes. the front uses the Rayspeed sway bars and the rear uses the front upper type. I don't have the part #'s in front of me but they are available.
RCTech #361
Old 06-05-2005, 10:48 AM   #13768
STLNLST's Avatar
That's what yesterday was for. I need to come up with a very low bite set up in order to do well next weekend. Go to work or something....LOL
Old 06-05-2005, 10:52 AM   #13769
SWR has low bite? Did Billy sell the track or something? Who in the world is in charge of spraying, it can't be Billy.
RCTech #361
Old 06-05-2005, 11:01 AM   #13770
STLNLST's Avatar
the track was well sprayed but something is up with the asphalt. I don't know what it is but it's been low bite as of late. I will get a handle on it for next weekend
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
