Yokomo MR-4TC SD
Old 06-04-2005, 01:36 PM
  #13741
Agower, nice pics!!! I did not find the Jet Racing blue washers on Ebay...could you give me a link please?
Are those Team suzuki knuckles or Speed Racing?
Thanks and good luck with your new ride!
Tbevofreak is offline
Old 06-04-2005, 02:07 PM
  #13742
there team suzuki nuckles front are rear. il try to find the link, it is on ebay uk though. thanks
found the link: http://cgi.ebay.co.uk/ws/eBayISAPI.d...978643345&rd=1
where country are you in?
agower is offline
Old 06-04-2005, 02:10 PM
  #13743
hurley081182's Avatar
Trader Rating: 15 (100%+)
Talking
hey guys i got a question for you all. im trying to get my sd to be all black and blue. right now im trying to find some blue screws that i cant find anywhere. i got so far:
10 - 3X8mm flat heads
10 - 3X10mm flat heads
but i need a bunch more. here is a list of just some of right now
6X4mm screws
m3X12mm cap screw
3X10mm button head
3X8 button head
6X6mm flat head
3X6mm button head
if you guys know of any good sites where i can find these in the color blue and in aluminum let me know please.
hurley081182 is offline
Old 06-04-2005, 02:14 PM
  #13744
im not sure where to get them from but i know associated do blue aluminium screws, try looking through the part lists of some cars to find the ones you need, then contact your rc shop.
agower is offline
Old 06-04-2005, 02:20 PM
  #13745
checked there webpage they dont do metric. yeah i also talked to my lhs and they only had the one type.
Old 06-04-2005, 05:40 PM
  #13746
highwayman's Avatar
Originally Posted by Mr. Shookie
Best question is. Which will you use more? Then you have yoru answer. It is always better to go with the one you will get the most use out of.
That is why I got the LCG even after I got the BD.
My first love was shaft drive and especially for stock, but my skill is coming up (ever so slowly but coming up none the less) so I wanted a car that could handle the move to 19T and eventually MOD.
I don't think I will need another car upgrade for a couple of years.
There is so much technolegy wraped inside these little cars now adays that to improve on them will take another two years at least.
Just my tow pennies, use them to help fund you cause...LOL
-Stephen <><
as usual, very sound advise... thank you...
my first love is modified, so i'll probably use the BD more...
i'll use those two pennies very wisely...
highwayman is offline
Old 06-04-2005, 07:08 PM
  #13747
kylehirano's Avatar
Trader Rating: 14 (100%+)
6X4mm screws
m3X12mm cap screw
3X10mm button head
3X8 button head
6X6mm flat head
3X6mm button head
Tobee Craft makes an aluminum blue screw kit for the SD, go to Speedtech.com or call Steve Wang he can help you get what your looking for.
kylehirano is offline
Old 06-04-2005, 07:11 PM
  #13748
kylehirano's Avatar
Default wrong address
Speedtechrc.com Is the address not Speedtech.com sorry
Old 06-04-2005, 08:30 PM
  #13749
blindwolf's Avatar
Default RC Noob w/ ?
Hi,
I recently upgraded my ssg to the lcg and know im unable to get my ride height lowered beyond 5.5mm. Im using the yokomo dampers(aluminum bodies) w/ stainless springs. The dampers are using rayspeed all around badders w/ rayspeed piston rings(1mm 2 hole) with 40wt oil. I have loosened the collars all the way to the top to no avail.(springs sloppy on shaft) Still does not drop. Any reason for this? Any and all help much appreciated.
blindwolf is offline
Old 06-04-2005, 09:17 PM
  #13750
its my understanding that along with the lower top deck you also get lowered shock towers. you didn't say but with all that rayspeed stuff i'm sure your using rayspeed spring retainers, you may have to use yok springs with the rayspeed retainers, this is just a guess as i don't have the car, check back a page or two, maybe the question as already been asked and answered
Turtlemaster is offline
Old 06-04-2005, 09:32 PM
  #13751
ChadCapece's Avatar
Originally Posted by blindwolf
Hi,
Take out all the travel limiters inside of your shock. Your shock should be in the mid 60mm range. With atleast 15mm of travel.
ChadCapece is offline
Old 06-04-2005, 09:34 PM
  #13752
ChadCapece's Avatar
-Stephen <><
Haven't you heard. Yokomo just realeased the new LCG Pro4Capece version 2005 spec Worlds CNC SD 3.2 asphalt knife MS AP kit. Man, your WAY behind the market trends.
Old 06-04-2005, 09:39 PM
  #13753
can u send me the link to the webpage i already looked on there but couldnt find it. thanks for the help though
Old 06-04-2005, 11:23 PM
  #13754
blindwolf's Avatar
Default Travel Limiters?
hi,
Would the travel limiter be the insert that looks like a triangle which rests at the base of the damper(inside). In regards to the other reply I have tried rayspeed springs to no avail. Currently im using the stainless yokomo springs as u suggested. I will remove the limiter and report back. Thanks
Old 06-05-2005, 12:01 AM
  #13755
that triangle piece is NOT a limiter. it is a shock shaft guide. it will effect how far out the shock rod comes not how far up it goes. when you said you had rayspeed, pistons and bladders...... i was assuming you had rayspeed retainers as well. if your using the yok springs and yok retainers then you may need to use the rayspeed retainers, if you don't have any or access to any real quick, try other brands, hpi, tamiya, assoc. maybe one of those will work as a temp fix.
pro 4, are you sure about the 15mm of shock travel, seems like a lot
