Old 06-01-2005, 09:32 PM   #13711
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Originally Posted by axel
Whoa ...whoa...whoa mr. shookie what about all that help from the BD?
WHOA WHOA.
What
I dirve a shaft better than a belt in Stock racing...Not a big secret...
The BD is a fantastic car in stock but I drive the LCG better in slow speeds..
Do you need me to do a comparison in 19T... I will tell you right off the BD will spank my LCG...the BD can carry more speed into corners with a faster motor.
With a Mod the BD is awesome...Just I'm not that great at driving at that rate of speed.
I love both of my Yoks wouldn't give either of them up.
But if I had one choice for stock motor racing it would be the SD LCG.
Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 06-01-2005, 09:37 PM   #13712
ChadCapece's Avatar
Man, you making the decision alot harder for me. I'll be racing 19t and maybe mod in club racing, but stock at the Nats.
LCG vs. BD
Sounds like either way: I win
ChadCapece is offline   Reply With Quote
Old 06-02-2005, 12:29 AM   #13713
highwayman's Avatar
Originally Posted by Mr. Shookie
It takes all the good and right things of the SD/Rayspeed and adds the ultra smooth and easy to work on drive line of the BD and SDW and literally made a pearl out of sand...
... i like your analogy ...
we run mostly modified... only in the rare big races where stock is our only option, do we run stock, but im still considering, whether to get the LCG or just run my JRX's...
highwayman is offline   Reply With Quote
Old 06-02-2005, 01:37 AM   #13714
hello,
what is the shim kit part umber fro shimming the diffs (sideways)?
thanks
agower is offline   Reply With Quote
Old 06-02-2005, 07:34 AM   #13715
s2
s2's Avatar
ZC-S100S
s2 is offline   Reply With Quote
Old 06-02-2005, 09:55 AM   #13716
rc_bam226's Avatar
WHOA WHOA.
What
Stephen <><
I'll agree with Shookie. Shaft drive cars work great with the low powerband of stock motors, instant power on the go, whereas with belts, takes a little longer to get going, but can carry speed through turns better, and has a smoother top end.
rc_bam226 is offline   Reply With Quote
Old 06-02-2005, 01:09 PM   #13717
hi,
does the lcg come with aluminium rear dogbones? i no it says there is a new type for it but are they aluminium.
thanks
A Gower
Old 06-02-2005, 02:41 PM   #13718
No, they are made of steel. But I use the Tobee dogbones... they work as well.
The LCG went very good on carpet on wednesday... it was amazing. I was 2-3 tenths faster then I ever was with my CGM... Now the CGM will be for playing with foams.
Cheers
Chris
speedy-932 is offline   Reply With Quote
Old 06-02-2005, 02:45 PM   #13719
rc-zombies's Avatar
If anybody's interested in Tobee dogbones.. I have NIB 4 paks to sell. 2 bones per pack. $18.00 for 2 paks shipped.via reg. USPS mail.
Old 06-02-2005, 04:29 PM   #13720
racer's Avatar
Cheers
Chris
are you using rubber/foam on carpet?
can you post your setup?
Thanks in advance!
racer is offline   Reply With Quote
Old 06-02-2005, 11:25 PM   #13721
I'm using rubber tires. I think from next year on we will use foams... at least in mod...
My setup:
front:
oneway
no swaybar
springs: orange
oil: 40 wt
piston: #2
damperstay: innerst hole
a-arm: middle hole
ride height: 5mm
droop: 6mm
rollcenter: 1mm under the ballstud on the bulkhead
rear:
no swaybar
springs: green
40wt oil
piston #2
damperstay: outest hole
a-arm: outest hole
3 degree toe-in
ride height: 5.5mm
droop: 5mm
rollcenter: no spacer anywhere
body: Mazda 6
tires: Sorex 28
insert: JB blue
I think that's all. This setup ist for a high traction carpet track.
Cheers
Chris
Old 06-03-2005, 01:35 PM   #13722
my first pic of lcg that arrived today.
Old 06-03-2005, 01:46 PM   #13723
Wow!! The steering rack is all blue alloy! nice extra over the plastic one in the prototype photos...you re a lucky person!!
I really love that lowered upper deck, what is the part number of those blue alloy washers you used under the 2 screws over the steering rack on the upper deck??
I ve been looking for those for my SDW..
Thanks! And good racing with your LCG, should be a killer!
Tbevofreak is offline   Reply With Quote
Old 06-03-2005, 02:01 PM   #13724
thanks, it is a nice car,
i got the washers off ebay but they say they are made by jet racing on the packet, i intend to use them on the top deck completely when i get some longer screws. and on the shock towers when i make them.
there was one problem with the instructions where it says what screws to use to hold down the steering rack, it has a picture of a screw and says ' 3 x 8 mm flanged bearing' that confused me for abit.
A Gower
Old 06-03-2005, 02:05 PM   #13725
even though the lcg is quite expensice its also quite cheap for me aswell compared to usa:
lcg $239 ----> 131
but a bd bought from the uk is about 300 so it would be -------> $540!!!!
AGower
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
