Old 05-30-2005, 08:30 PM   #13681
without having to go back and see if it has been asked before, has anyone tried the upper holes in the rear axle hub. other then being a bear to get ride height and shock movement. what can i expect handling wise.
Turtlemaster is offline   Reply With Quote
Old 05-30-2005, 08:52 PM   #13682
Matt Howard's Avatar
I'm pretty sure those holes are only there so the hubs can be used in the rear of the mr4bc 4wd offroad buggy. I've never tried or heard of anyone trying to use those holes in a touring car.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 05-30-2005, 09:17 PM   #13683
ChadCapece's Avatar
I have a quick setup question:
If I move the camber links to the upper holes on the shocktower. Will I have more or less roll? And if I make them shorter, will I have more or less roll?
I've had these questions for a while now, and even when I make the changes, only the stopwatch shows any difference.
ChadCapece is offline   Reply With Quote
Old 05-30-2005, 09:26 PM   #13684
now that you mentioned it, i do have a set on the buggy. i guess it was a silly idea. but then again, with the 14mm of ride height i have i could try it on the off road track. lol thanks once again.
Old 05-30-2005, 09:31 PM   #13685
I always felt like when I raised the inner camber link that end rolled less. Also, with a shorter link I've always felt like the car rolled more.
RCTech #361
Old 05-31-2005, 01:48 AM   #13686
highwayman's Avatar
i tried on my CGM before, and it was a pain to lower the ride height... anyway, handling wise, it seemed to improve my rear traction a bit, but all together, i felt it didn't give a real advantage...
highwayman is offline   Reply With Quote
Old 05-31-2005, 04:00 AM   #13687
highwayman's Avatar
for me, shortening the rear links gives me a more consistent rear traction feel... unlike a longer link that has more traction at the beginning of a turn, but when it reaches the its limit, snaps abruptly.
Old 05-31-2005, 10:37 AM   #13688
Send a message via AIM to aoizip
anybody try the double deck version of LCG kit on the carpet yet?
need some financial support to get this kit(who doesn't )
also WTS:
1 x Rayspeed Conversion Kit(new) --> $120 shipped
1 x HPI PRO4 KIT(new) ---> $250 shipped
~Ming
aoizip is offline   Reply With Quote
Old 05-31-2005, 01:42 PM   #13689
The front suspension on my Yokomo SSG has a lot of left-right play in it. That is, it appears that I can move the front right wheel up to three degrees of toe in/toe out before the servo is affected. (I thought maybe the ball joints are worn; also appears to be from the steering rack, which I guess is the only other possibility). The left wheel appears to be able to move about 1 degree left-right. I asked a couple guys at my local track (I'm a newbie) who said that's normal for Yokomos. Is he right?
Second question, I read about some people mounting their servo horizontal to the steering rack. Would you recommend this for the SSG?
Thanks for your help.
grazianos is offline   Reply With Quote
Old 05-31-2005, 02:05 PM   #13690
ChadCapece's Avatar
Every car will get this as it gets used. The ballcups, kingpin holes, shims, wheel hexes, ect... will get play from the dust and grit the wears out the moving parts.
Old 05-31-2005, 02:05 PM   #13691
ChadCapece's Avatar
Usually this won't affect handling b/c the momentum helps the wheels track straight.
Old 05-31-2005, 05:09 PM   #13692
Yes, I would recommend it, it will give you more space for the electronics and better balanced car
If you dont want to go thru the hassle of drilling holes you can tape the servo with some good quality double sided tape.Some Yokomo Team Drivers used to do it this way so it should work fine
See ya!
Tbevofreak is offline   Reply With Quote
Old 05-31-2005, 09:15 PM   #13693
Man, 3 degrees of play is normal wear and tear? Makes me laugh at the I spend time with my set-up gauges making 1/2 degree changes.
I'm not too keen on mounting the servo with tape alone. I think there would be play in that. At the same time, I don't feel comfortable drilling holes in my chassis (I don't have the capability to drill a countersunk hole). Hmmm... I guess I may have to stick with an off-balance car.
Old 05-31-2005, 10:04 PM   #13694
ChadCapece's Avatar
Have you measured it out to be 3 degrees? Or does it "feel" like 3?
Old 05-31-2005, 10:05 PM   #13695
ChadCapece's Avatar
Can somebody post a few pics of their car with the servo mounted parallel to the upper deck? AKA: The other way to mount it.
thanks
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
