Old 05-16-2005, 12:20 PM   #13516
rc_bam226's Avatar
Originally posted by Pro4Capece
I've got a great setup for 19turn on medium grip bumpy asphalt. Only problem is, I don't have Adobe Standard or Professional. I have a compute at my house that might be able to modify the setup sheets. If it does, I'll either PM you or post it on this thread.
Hey, you got a PM.
rc_bam226 is offline   Reply With Quote
Old 05-16-2005, 04:53 PM   #13517
rc_bam226's Avatar
Originally posted by Matt Howard
LCG conversion should be in the states by the end of the week, pricing will up on yokomousa as soon as they get 'em in.
Woohooo!!!
Old 05-16-2005, 06:04 PM   #13518
Horatio's Avatar
They say a picture is worth a thousand words......
Heres the LCG version SD
Horatio is offline   Reply With Quote
Old 05-16-2005, 06:21 PM   #13519
That sure looks sweeet!
I wonder if the drivetrain is lower than the other double decked shaft cars on the market?
Like the Pro4 and Evo4
Tbevofreak is offline   Reply With Quote
Old 05-16-2005, 06:24 PM   #13520
rc_bam226's Avatar
Its going to be similar to the SDW in terms of profile. I've put a Pro4 next to an SDW, and its close with the SDW 1 to 2mm taller than the Pro4. That's placing the chassis side by side minus wheels, and no suspension in play.
Old 05-16-2005, 06:34 PM   #13521
Horatio's Avatar
Well with the LCG's transmission being 5mm lower than the SDW, I'd expect the LCG to be even lower than the pro 4, perhaps by as much as 3mm?
Old 05-16-2005, 06:38 PM   #13522
Horatio's Avatar
Of course what I meant to say was the upper deck is 5mm lower than the SDW! The transmission is 4.5mm lower than the normal SD.
Old 05-16-2005, 06:45 PM   #13523
Horatio's Avatar
It certainly does look nice. But I'm not a fan of open gearboxes. Just one stone/screw/bodyclip/washer (delete as applicable) could spoil your day. Hopefully, lexan gear covers are available?
Old 05-16-2005, 07:14 PM   #13524
Actually, I m a big fan of open gear boxes!
I just love the way it looks, but you re right about the prob it can cause and I think you will just have to make you own covers out of lexan unless yokomo has the good idea to make some available as a hop up or something..
Old 05-16-2005, 08:15 PM   #13525
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Well here is something you could probably convert to the LCG SD.
http://www.speedtechrc.com/store/ebp...id=418&id=4633
Oh and I know a guy who races his SDW everyweek and has not one thing broke cause it got into the gear boxes....
I like the open boxes it allows for a lighter and more free drive train...
Hope to see one real soon.....
Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 05-16-2005, 08:23 PM   #13526
ChadCapece's Avatar
How hard is it to get the diffs out of the SDW?
ChadCapece is offline   Reply With Quote
Old 05-16-2005, 08:48 PM   #13527
rc_bam226's Avatar
Just looked at the previous post from Shookie about the specs of the LCG, looked at my SDW, and the first thought that came to mind was, how big of a spur can the LCG take?
I mean Yokomo lowered the drive train 4.5mm from the SD standard, and like horatio hypothesized 3mm from the SDW, that's a considerable reduction in the maximum size spur that could fit w/o protruding from the bottom of the chassis.
Are we talkin' mid to high 60's for the largest spur that could fit? Good grief, time to start buying smaller pinions to get my gear ratios in the right spots for motor again.
Old 05-16-2005, 08:50 PM   #13528
rc_bam226's Avatar
You have to undo the upper deck, and remove each bulkhead, and then take it apart.
Old 05-16-2005, 09:26 PM   #13529
having done this a few times i can tell you its not hard at all, it does require what the other guy said, but it only takes a few minutes, largest spur gear on lcg i don't know, on SDW its a 77 without filing, 78 with a little filing on the lower chassis. thats 48 pitch of course. i've ran mine almost everyweek end since they came out and have had the gears get noisy because of debry but haven't broke any gears yet.
Turtlemaster is offline   Reply With Quote
Old 05-17-2005, 03:05 AM   #13530
Horatio's Avatar
Good point! Some of us are probably lucky enough to have a full range of pinions already, otherwise it's an extra cost to consider.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
