Old 05-07-2005, 04:42 AM   #13426
Default tires
cheers i will put together a couple of both
judge10tpt is offline   Reply With Quote
Old 05-07-2005, 12:13 PM   #13427
Default SDW drivetrain
Well I re-shimmed the drivetrain and I got about 5 secs of free spin but its nice and smooth how long do you guys get of free spin?
cheers!
Tbevofreak is offline   Reply With Quote
Old 05-07-2005, 08:34 PM   #13428
jiggen5354's Avatar
Wouldn't worry too much about spin time. as long as the drivetrain is free and smooth the drive the car. it will free up further with use.
jiggen5354 is offline   Reply With Quote
Old 05-07-2005, 10:10 PM   #13429
edseb's Avatar
Will LCG conversion kit completely convert a CGM or will other parts be needed as well?
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 05-07-2005, 11:33 PM   #13430
Matt Howard's Avatar
it will convert a CGM as well. You're only using the basic suspension components and the drivetrain out of your old car. You get a new chassis, bulkheads, shocktowers, etc.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 05-07-2005, 11:39 PM   #13431
As you can see it's basically a new kit, minus some basic parts off of your old SD. they're even giving you the new heavy duty arms, new rear dog bones, and a sway bar kit.
LCG Conversion Kit
For the MR-4TC SD
Main features:
Lowered drivetrain
- 4.5mm lower than the standard SD
New graphite main chassis, upper deck, front and rear shock towers, battery plate
Aluminum bulkheads
- removable upper piece for easy diff access
New aluminum motor mount
Upper deck positioned lower
- 7mm lower than standard SD
- 5mm lower than SD World's Replica
Front and rear upper camber links mounted on bulkhead
prototype shown : production version will not have camber link holes on shock towers
New battery tray system
- compatible with GP3700 and IB3800 cells
- no filing of the battery slots required
- prevents batteries from shorting on the chassis
New aluminum steering assembly
- aluminum bellcranks used
- positioned low for lower cg
Aluminum servo mounts
Heavy duty suspension arms
Rear bumper
Anti-roll bars (front:Rayspeed type, rear:upper type)
New rear dog bones
RCTech #361
Old 05-08-2005, 01:15 AM   #13432
Greg M's Avatar
Whats the LCG kit worth?
Greg M is offline   Reply With Quote
Old 05-08-2005, 01:22 AM   #13433
I haven't seen any prices for it yet since it's not released yet in the states. A good guess is going to be between $250-$300 though.
RCTech #361
Old 05-08-2005, 04:24 AM   #13434
Default Re: SDW drivetrain
cheers!
Assuming you mean just the gearbox then about 10 seconds but with the car together and with all four wheels on it's about 65 seconds on my CGM.
Mabuchi540 is offline   Reply With Quote
Old 05-08-2005, 10:33 AM   #13435
JayBee's Avatar
Trader Rating: 31 (100%+)
Post Re: Re: SDW drivetrain
... -JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 05-08-2005, 10:34 AM   #13436
Send a message via AIM to Johnnytc3
Default Re: Re: SDW drivetrain
Can i send you my car and pay you to make it spin that long?
Johnnytc3 is offline   Reply With Quote
Old 05-08-2005, 10:36 AM   #13437
do not worry if you can't get anywhere close to 65 seconds like M540 has, i will bet just about anything he is the only one getting this kinda free spin time. as long as there is no binding you will be fine.
jaybee, remember the air hose test. what was that around 30 seconds?
Turtlemaster is offline   Reply With Quote
Old 05-08-2005, 10:46 AM   #13438
edseb's Avatar
Thanks for the info. So I'm assuming one-way, etc. will work the same too?
Carl Hyndman
Old 05-08-2005, 10:47 AM   #13439
Hehe , yea i actually prefer my car nice tight and smooth rather than being loose.
Old 05-08-2005, 11:55 AM   #13440
Default SDW bearings
65 SEC wow thats a lot man, concerning the bearings I let them as they were with the lube wich makes them nice and smooth but adds some drag to the drivetrain but I guess its more important to protect them
BTW, I was suprised the SDW bearings were not rubber sealed and openable for cleaning and lubing and I was wondering about the quality of them....HOW WOULD RATE THE SDW BEARINGS?
thanks
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
