Yokomo MR-4TC SD
jaybee, you have to remember that not everyone has the same driving style. and not all setups are the same on all cars or even the same on the same brand of car. example, you can take two sdw's built buy the same driver, same day, same setup, give them both to a none interested party and ask him which one feels better, he will "find" a difference in them. the amount of extra rebound given by the o rings vs the foam is so small that i don't think you or i could tell. esp at FW. heck, i took the foam out of my shocks and can't tell the difference. do'nt sweat the small stuff. good fresh tires is most important at FW then setup.
Originally posted by Turtlemaster
anyone else break a out drive cup for the center shaft. broke two yesterday. first one didn't even know it was broke until i turned car on for main and saw center shaft flopping around, thanks to yoks design was able to change it in about a minute or so, but next one didn't last one lap. i was running a 9x2 cobalt with a one way. rough track, pavement, on thought i had was that when hitting a bump the front end unloads a bits and spins faster and when it hits the ground the shock is breaking the cup. does this make sense. i pulled the shaft out last night, all is good there.
SDW Drivetrain and Shaft
Hi guys,
I'd like to know how long the SDW replica drivetrain is able to spin free for, is it as good as the Pro4?
I'm a little anxious concernig the CF shaft, can it handle low turn mod? I heard drivers having probs with Cf shaft breaking...
Thanks!
Thanks!
Re: SDW Drivetrain and Shaft
Originally posted by Tbevofreak
Hi guys,
Thanks!
Hi guys,
Thanks!
Re: Re: SDW Drivetrain and Shaft
Originally posted by rc_bam226
The CF shafts that broke were the first generation one that were cheaper than the current version. I broke one using a 12 turn single, but I believe someone posted a fix by CA gluing the whole shaft to reinforce it. Mind you, this was a fix for the older shaft, not the newer one.
The SDW one is made by Bomber. I had a RC maniax shaft and the shaft is ok but the ends twist in the shaft. I am getting the SDW one soon and i hope it doesnt do the same as the other i had.
Yup, the one that comes with the SDW is stronger, and like Dan said, it is made by Team Bomber, relabeled for Yokomo. But that said, Johnny, if you do pick up an old one, its thin shaft that looks like the CF has been milled. You can buy the newer shaft, its available.
Ok, cool, i saw one on speedtech, but didnt know if it was the rubber one or not, i guess ill pick one up prettty soon. But can it withstand the power of 7-9 turn modifieds?
Weight Watchers for my SSG SD
Ok, so I'm now on a diet. I need to drop 80 grams without performance loss. Where can I lose the most weight, and approximately how much?
I'm running rubber tires on asphalt. I'm using a MG servo, GT7, R300 (full sized) reciever, 3600 IB cells.
Thanks for any help
Chad
Thanks for any help
Chad
What other weight saving options do you have on there? Or do you need suggestions?
Re: Weight Watchers for my SSG SD
Thanks for any help
Chad
Thanks for any help
Chad
There are inserts weighing up to 15 grams EACH......and others wheighing 15 grams PER SET..........try to play with inserts and find any combo that is good and lightweight.....
Thanks SalvadoriRacing
rc Bam: I have removed the center deck and painted the body with thin paint.
I know this has been asked before, BUT how much weight will I save with the aluminium input shafts?
What tape is best for the batteries? Will I need to widen the slots for the tape?
