Old 04-21-2005, 09:10 AM   #13216
Matt Howard's Avatar
Default Re: Re: Re: Low center of gravity conversion kit for the SD???
Originally posted by v0rtex
And for those of us not familiar with US seasons in comparison to the southern hemisphere, what month approxamately is that?
Sorry about that, Hopefully in the next month or two we should have a firmer release date on the LCG conversion
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 04-21-2005, 09:26 AM   #13217
ChadCapece's Avatar
Originally posted by Mr. Shookie
Make one with the Losi spool pads.
I can not remember the part number but they are like diff rings that are sand paper and also help because they are alot lighter than the regular spool, unless you plan on running Mod then I would say order one from Steve. www.speedtechrc.com
Hope this helps,
Stephen <><
Thanks shookie. Will they be a direct fit, or do I need to modify the pads?
ChadCapece is offline   Reply With Quote
Old 04-21-2005, 09:52 AM   #13218
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Should be a direct fit.
Glad to be a help
Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 04-21-2005, 10:15 AM   #13219
ChadCapece's Avatar
Thanks for everyone's help. I've ran about 6 different cars in the last year, and with the Yok, I've gotten the best tech support.
And some people say the Xray is the best in that department I know all about tuning, but as with any car, I just need to learn the tips and tricks to make it more reliable.
Thanks again,
Chad
Old 04-21-2005, 10:23 AM   #13220
rc_bam226's Avatar
Here's the part no. for the Losi spool pads:
LOSA3250
I know they are priced under 2 bucks. Easy made spool.
rc_bam226 is offline   Reply With Quote
Old 04-21-2005, 11:28 AM   #13221
hi
what gear do you use with the speedtech spool the oneway gear or the standard diff one?
thanks
A Gower
agower is offline   Reply With Quote
Old 04-21-2005, 11:29 AM   #13222
rc_bam226's Avatar
Use the one-way gear.
Old 04-21-2005, 12:39 PM   #13223
hurley081182's Avatar
Trader Rating: 15 (100%+)
Send a message via AIM to hurley081182 Send a message via Yahoo to hurley081182
i got a question about the yoko sd i just got. i was wondering why the main shaft drive is so loose. will that affect anything on the car? is it suppose to be this way? and if its not suppose to do this how do i tighten it up?
Old School Stampede=FUN
hurley081182 is offline   Reply With Quote
Old 04-21-2005, 01:41 PM   #13224
rc_bam226's Avatar
Define "loose," does the drive-shaft move forward and back, or do the pins on the shaft sit loosely in the drive cups?
Old 04-21-2005, 01:53 PM   #13225
ChadCapece's Avatar
same question here.
The only answer I can think of would be to make removal easier.
Old 04-21-2005, 02:09 PM   #13226
its the drive cups. the one that moves inwards and outwards so u can take off the drive shaft off. is there a screw or something that goes in it? i dont think that it can just move freely like that. kinda weird
Old 04-21-2005, 02:14 PM   #13227
Send a message via AIM to Johnnytc3
I had the same problem, i had nikkis light weights input shafts and they were a tad skinnier than the stock shafts, i went ahead and got the yokomo lightwieghts and they soo much tighter.
Johnnytc3 is offline   Reply With Quote
Old 04-21-2005, 02:17 PM   #13228
rc_bam226's Avatar
EDIT:
Well, on each drive cup, there is a pin and o-ring setup that holds the drive cup to the input shafts, front and rear. There is also an o-ring in the rear input cup to keep the main drive shaft from moving front to back. Its sounds like you don't have that o-ring in there.
Also, there are shims between the front input cup, and the bearing, outside of the diff case for the front end. Trying to narrow what it could be. Hope this helps.
Old 04-21-2005, 02:32 PM   #13229
yeah it doesnt have a screw on the rear shaft cup. where can i get one of these at?
Old 04-21-2005, 02:34 PM   #13230
rc_bam226's Avatar
Sorry, thinking about another car The input cups are held onto the shafts via pin and large o-ring that goes on the groove of the input cup.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
