Old 04-18-2005, 07:52 PM   #13186
ChadCapece's Avatar
Originally posted by Turtlemaster
jaybee, just a reminder, no one around weighs our cars for club races, you only need to worry about the 1500 for a two race like at 4 seasons or rain city. and not sure about 4 seasons
In that case, remove weight from the heavy side to balance the chassis.
If your going to race in big races, go ahead and weigh the car down to 1500 grams.
ChadCapece is offline   Reply With Quote
Old 04-18-2005, 07:56 PM   #13187
ChadCapece's Avatar
Originally posted by JayBee
The weight of my car is 1395 grams. I don't know the weight that it is suppose to be. Front left is 368.7g, Front right is 312.6g... Rear left is 345.3g and the Rear right is 367.7g. How do I even this out without having to jump back-n-forth between settings? There probably isn't a way is there -JB
Is your car the SDW? Rayspeed? or Stock SD? Mine came out to be 1630 with GT7, 3600's, rubber tires, and MG servo.
I think a digital plastic gear servo would help. I've already reduced the weight down to 1560 grams.
Old 04-18-2005, 08:03 PM   #13188
i believe he taking about his rayspeed, his sdw is only used to attract dust in his work shop
Turtlemaster is offline   Reply With Quote
Old 04-18-2005, 09:10 PM   #13189
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
Funny turtlemaster
Pro4Capece-
It's the Rayspeed with 3300's, Keyence Zero V Extreme, Fut. S9550, Fut. R113iP PCM receiver, rubber tyres. I just figured the lesser and the more even the weight, the better... -JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 04-19-2005, 04:22 AM   #13190
Default Oh man seriously....
Funny turtlemaster
Pro4Capece-
1395 grams?
My CGM needed approx 70 grams added to it so I put 90 in the Rayspeed.
But if your car is 1395 with that gear and mine is similar in weight, but the batteries are only 1500mah packs, I'm going to have to add like 120-130 grams in total.
Mabuchi540 is offline   Reply With Quote
Old 04-19-2005, 09:27 AM   #13191
JayBee's Avatar
Post
I'm gonna redo everything to make sure... -JB
Old 04-19-2005, 10:15 AM   #13192
hurley081182's Avatar
Trader Rating: 15 (100%+)
Send a message via AIM to hurley081182 Send a message via Yahoo to hurley081182
hey guys just got a yoko ssg and i was wondering what everyone runs with it. any secrets you know about it, like setups. this car is awesome. i been asking alot of questions to jaybee and he has been super helpful, but dont want to keep bugging him every few hours or so. i other then the ssg i also have a xxxs so its a totally different car that is why im asking so many questions. thanks for the help everyone.
Old School Stampede=FUN
hurley081182 is offline   Reply With Quote
Old 04-19-2005, 12:58 PM   #13193
ChadCapece's Avatar
Yokomo Dominates At Yatabe
19-04-2005 19:22:00 GMT +1 - Send this to a friend
Team Yokomo dominates the 2005 Super Stock Championships at Yatabe Arena.
Masami Hirosaka TQs and wins the 2005 Super Stock (23T) Championship with the MR-4TC SDW.
Yokomo drivers finishing in the top 10.
1. Masami Hirosaka (SDW)
2. Takashi Katoh (BD)
3. Shinnosuke Adachi (BD)
5. Shinya Kimura (SDW)
6. Ichiro Fukuda (SDW)
9. Naoto Matsukura (SDW)
All those guys who went out and bought a BD, and the SDW still beats it.
Old 04-19-2005, 01:07 PM   #13194
the bds beat more sds then it lost to lol that makes little sence
agower is offline   Reply With Quote
Old 04-19-2005, 01:37 PM   #13195
Yeah, and if Masami had run the old MR4-TC Silver or special he would have won it too.
pops is offline   Reply With Quote
Old 04-19-2005, 07:26 PM   #13196
ChadCapece's Avatar
Only one position counts
Old 04-20-2005, 11:01 AM   #13197
ali_g's Avatar
hi guys, any tips on hw to shim the front one way??
ali_g is offline   Reply With Quote
Old 04-20-2005, 01:56 PM   #13198
iamramos's Avatar
shim out the side to side play first with no input gear. then shim the dif/1way over with the input gear installed(stock shims). you should have a tiny bit of rocking between the gears. install the cover and test the free spin. the cover sometimes binds the gears so you may need to move some shims around but most of the time its right on
zc-s100s shim kit will let you realy fine tune the mesh with different thicknesses
iamramos is offline   Reply With Quote
Old 04-20-2005, 04:41 PM   #13199
Default Yokomo Set-up Order
I recently bought a Hudy set-up system and this is the order that they recommend: downstops (which I think most people refer to as droop, but I could be wrong), ride height, droop, camber, caster, toe, steering throw, tweak.
I've been having a lot of fun with the set-up system and highly recommend it. It's been a big help in setting my car up. Now I just have to learn to drive it!
JayBee - I think you helped answer a question I had through one of your previous posts. I bought some Rayspeed springs based on a guy at SoCal saying they were "must haves." My ride height ended up 7.5 mm and I couldn't get it down, even shortening the shocks to the stock 60 mm. I didn't realize that not having the Rayspeed cups messed everything up. Thanks for posting that tip!
PS - There was no significant change in ride height shortening the shocks from 62 mm to 60 mm, nor in playing with the shock collars. This surprised me.
grazianos is offline   Reply With Quote
Old 04-20-2005, 07:42 PM   #13200
JayBee's Avatar
Default Re: Yokomo Set-up Order
My knowledge is limited so I'm glad something I posted helped -JB
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
