Old 04-04-2005, 04:23 PM   #13066
Originally posted by JayBee
OK guys help time... here's my set-up-
*tyres- Take Off CS27
*ride height- 5mm
*droop (front-2mm) (rear- 6mm)
*shock oil- 40wt. all around
*springs- RS green all around
*shock tower position (front)- 2nd hole from INSIDE using old RS rear(not the new geometry one) shock tower
*camber link position (frt.)- lower row/ innermost hole (middle hole on C-hub)
*front HD lower arm position- middle
*shock tower position (rear)- 2nd hole from OUTSIDE using old RS rear shock tower
*camber link position (rear)- lower row/innermost hole (3rd from outside on hub carrier)
*3-degree rear toe
I'm on a tight-technical carpet track w/nice traction. I had RS blue springs on the rear first but the ass-end was sliding on initial thru mid-corner so I switched to green and that helped ALOT. The rear-end is scrubbing/skipping thru the corner now, if you know what I mean?
Could someone give me tips on how to improve my set-up, starting with some things to change first...
Thanx -JB
JayBee, was kinda having a simular problem this last weekend, couldn't seem to help anything no matter what I tried to change on the set-up. The car would tend to get loose or spin out in the sweepers. I spoke to Robert at Yokomo and he said it sounded like a hairline crack on the end of an arm. Closer inspection and sure enough there was a hairline crack at the end of the arm. You could barely see it. Robert recomended going the the heavy duty arms to fix the problem.
Try stiffing up the front of your car (heavier oil in front than rear 50/40) Rayspeed Red springs in front and Yellow in rear). Also put a little black grease in the slots of your diff halves for the universal pins to slide on. This will help with the chatter.
pops is offline   Reply With Quote
Old 04-04-2005, 04:36 PM   #13067
mo
mo's Avatar
Hopefully no more super spinout for Alex. Did you get the new car yet?
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 04-04-2005, 05:39 PM   #13068
rc-zombies's Avatar
hey Pops
you have a good starting set for 19T for SWR?
oops... nevermind... i'm in the wrong forum..
need set-up for the BD..
Old 04-04-2005, 05:40 PM   #13069
Should arrive tomorrow, didn't go out until Friday, hobby shops come first.
Old 04-04-2005, 05:42 PM   #13070
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
Thanx pops, I gotta check my arms now .
I do have the HD arms on the front but regular graphite on the rear.
And talking to Mr. Wang today I got similar advice with the addition of making my droop more equal.
Again thanx for the help -JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 04-04-2005, 05:44 PM   #13071
rc_bam226's Avatar
Originally posted by rc-zombies
hey Pops
DOH!!!
rc_bam226 is offline   Reply With Quote
Old 04-04-2005, 05:48 PM   #13072
Oh yeah, you've got way too much droop in the front, try 6mm in front and 5mm in rear.
Old 04-04-2005, 05:51 PM   #13073
hey Pops
From what I was told, the stock set up in the kit should be a pretty good staring point.
Old 04-04-2005, 07:42 PM   #13074
bigragu's Avatar
Default can i use ssd chassie
does anyone know if you need the new chassie with the conversion kit or can you use a ssd chassie for it. i know that it has the slot system for the 3800 but i have a custom chassie made for carpet 4mm thick and i wonder if i can use it with the conversion kit. thanks for any info in advance.
bigragu is offline   Reply With Quote
Old 04-04-2005, 10:08 PM   #13075
Default Re: can i use ssd chassie
Old 04-05-2005, 01:25 PM   #13076
Does anyone have a good setup for the CGM and rubber tires (CS-27 or Sorex 28) for a high bite carpet track? My current setup is not bad but perhaps someone has a better one.
Chris
speedy-932 is offline   Reply With Quote
Old 04-05-2005, 02:48 PM   #13077
rc_bam226's Avatar
Chris
Check out www.yokomo.tk
Old 04-05-2005, 02:57 PM   #13078
NVisible's Avatar
wtf.... edit
NVisible is offline   Reply With Quote
Old 04-05-2005, 04:47 PM   #13079
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
Does anyone know if the new LCG conversion will convert a CGM ok, or will it only convert an SSG or Black?
I assume the CGM would be OK because its just a different chassis on the CGM, right?
v0rtex is offline   Reply With Quote
Old 04-05-2005, 04:50 PM   #13080
Matt Howard's Avatar
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
