Old 04-03-2005, 02:04 PM   #13051
pheyhoe's Avatar
R/C Tech Charter Subscriber
do you mean lower spec for the SD, i am guessing so...
although i would not be suprised is they bought out a cheaper version of the BD without so many ally bits etc..
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 04-03-2005, 02:15 PM   #13052
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
If I'm correct, I think he's saying that they're thinking about bringing out a lower spec version of the WORLD'S KIT (SDW)... - jb
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 04-03-2005, 04:12 PM   #13053
Originally posted by kmorast
What kind of grease are you running in the diff, I've used associated clear grease and have never had any problems with my diffs.
Im using the grease that comes with the kit, iv not niticed it until recently. It just seemed really bad today. Im going to get some new plates and go from there.
Dan Hughes is offline   Reply With Quote
Old 04-03-2005, 04:17 PM   #13054
Matt Howard's Avatar
Originally posted by agower
a few things.
thanks to matt howard for your spool setup from yokomo.tk, it is really awesome, ran it today at national and i managed to get 9th in A and 4th in A in 27t. worked really well, the only thing i changed was i used 1 degree rear camber.
thanks
Andy Gower
Glad you liked it, that setup seems to have worked pretty good for others that have tried it as well.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 04-03-2005, 04:50 PM   #13055
pheyhoe's Avatar
DanH
I use silicone lubricant in my diffs.. runs very smooth as far as wear goes, the plates are not very expensive, either are the standard kit balls so i would just buy some new ones....
Old 04-03-2005, 07:58 PM   #13056
kidDynomite's Avatar
JB, he might have meant this kit... Read more here:
http://www.team-orion.ch/global/global_news.asp?id=2836
kidDynomite is offline   Reply With Quote
Old 04-03-2005, 09:29 PM   #13057
JayBee's Avatar
Post
OK guys help time... here's my set-up-
*tyres- Take Off CS27
*ride height- 5mm
*droop (front-2mm) (rear- 6mm)
*shock oil- 40wt. all around
*springs- RS green all around
*shock tower position (front)- 2nd hole from INSIDE using old RS rear(not the new geometry one) shock tower
*camber link position (frt.)- lower row/ innermost hole (middle hole on C-hub)
*front HD lower arm position- middle
*shock tower position (rear)- 2nd hole from OUTSIDE using old RS rear shock tower
*camber link position (rear)- lower row/innermost hole (3rd from outside on hub carrier)
*3-degree rear toe
I'm on a tight-technical carpet track w/nice traction. I had RS blue springs on the rear first but the ass-end was sliding on initial thru mid-corner so I switched to green and that helped ALOT. The rear-end is scrubbing/skipping thru the corner now, if you know what I mean?
Could someone give me tips on how to improve my set-up, starting with some things to change first...
Thanx -JB
Old 04-03-2005, 09:40 PM   #13058
that is a picture of the new conversion kit, the LCG "lower center of gravity" that is a upgrade for the ssg based on the SDW or worlds car. just without all the bling bling, i.e. alum axles, ti screws, etc, etc, lets just wait and see what happens before starting a new tread.
Turtlemaster is offline   Reply With Quote
Old 04-03-2005, 10:10 PM   #13059
rough512's Avatar
Please excuse this attachment...
Attachments don't work at our local forum.
okay, attachments are not working here too...
rough512 is offline   Reply With Quote
Old 04-03-2005, 11:12 PM   #13060
Regional Moderator
daniz24's Avatar
I hope I can replace my SDW with these new easy diff access bulkheads
daniz24 is offline   Reply With Quote
Old 04-04-2005, 01:37 AM   #13061
rovic's Avatar
Thanx -JB
skipping? with rubber tires?
is the track rough? i dont believe rubber on carpet would provide enough traction to skip the rearend, no matter how stiff it is... track must be rough. by scrubbing, does it slide out?
i did alot of testing on carpet (before they took it out) and ive found that low friction universals scrub alot of corner speed and corner accleration. try harden universals (at least in front) / i dont like alum because on carpet they wear out quickly...
rovic is offline   Reply With Quote
Old 04-04-2005, 07:15 AM   #13062
ROVIC, i lost it, but a few pages back you were talking about spur gear sizes and motor winds, could your repeat, thanks
Old 04-04-2005, 11:23 AM   #13063
rovic's Avatar
the rule of thumb i use is;
stock motors & 19t use 70t spur then use the appropriate pinion...
you could use 64p, ive used 88t with good results. but 48p are more dependable when the track has marbles.
mods no less then 10t use the 72t spur and gear accordingly
mod 9t and less use 75t spur and so on and so forth.... (keep in mind when using 9t and lower that the car isnt faster in the since of top speed / they just spool up faster.
donny is a real fast local, buy him a happy meal and you might be able to negotate the ideal gear ratio for every track in wa.
see you at the sizzler...
Old 04-04-2005, 12:57 PM   #13064
jaybee was right i was on about a lower spec of the sdw. wel thats what i have been told. suprised you didnt know as in england things nomraly get known alot later!!!
agower is offline   Reply With Quote
Old 04-04-2005, 03:47 PM   #13065
NVisible's Avatar
has any more info been released on the LCD Conversion? IE: Release Date, Pricing?
NVisible is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
