Old 03-31-2005, 07:37 PM   #13006
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
Originally posted by Kyew
SD conversion kit, and it's not that cheap.
standard retail 31290 yen
Check yokomo's japan website.
I think I'll be getting this before the BD - JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 03-31-2005, 08:14 PM   #13007
NVisible's Avatar
looks about 290 USD.
thats a hefty pricetag for a conversion
NVisible is offline   Reply With Quote
Old 03-31-2005, 09:33 PM   #13008
Rob Phillips's Avatar
Matt, I have a quick question. My car seems to push going into the corners and then midway to exiting the corner, the inside wheels lift. Medium grip track.
I'm running;
front
#1 piston 50w
puple ae spring
Magenta red GQ tyres
droop set at 3mm with hudy
0 toe
-1 camber
stock caster
Copper sway bar
rear
#2 piston
copper ae spring
magenta GQ tyres
1* toe in
all other settings are the same as mo's setup.
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 03-31-2005, 09:54 PM   #13009
Matt Howard's Avatar
That's pretty much the setup that I ran but I ran less droop in the front, probably around 2-3 mm and the rear was 3-4mm. Try a silver rear bar as well, that should keep the chassis flatter and give you a bit more turn in steering that you're looking for.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 03-31-2005, 10:27 PM   #13010
Oops, the front droop should be about 3mm. Do you measure to the king pin or the arm on the front for droop?
I was going to try running a rear sway bar, only ran two q's tonite have to try it out sat. If the sway bar doesn't do it, what would you try next, stiffer spring(s) or thicker oil? Thanks.
Old 03-31-2005, 10:30 PM   #13011
If forgot to mention, stock class.
Old 03-31-2005, 10:40 PM   #13012
for foam tires you want to measure how far the suspension lifts up before the tires lift off the ground. Have you tried different tires? Some guys have found that the GQ tires are softer than jaco/trc/or parmas and were having problems with tires lifting in the corners. If you're still having problems I would try a harder rear spring to give you more turn in and keep the chassis flatter in the middle and exit of the corner.
RCTech #361
Old 03-31-2005, 11:01 PM   #13013
actually I do have a set of harder tires that I was going to try Sat. The tires really do feel soft. I ran one pack thru harder gray/black and then ran the magenta/red and went with them. I think it's lack of set up, that's why the softer tires seem to work at first. I understand what most suspension changes do, but not when to use them. Still trying to learn set up my onroad cars.
Old 03-31-2005, 11:03 PM   #13014
And thanks for the tip on setting droop with foams, I thought every on used a gauge? Oh well. Never asked actually, just assumed.
Old 03-31-2005, 11:16 PM   #13015
SpeedTech's Avatar
Hi Guys,
on the LCG conversion kit for the SD, we will work with Yokomo USA in the next few days and next week to come up with our best estimation of this conversion kit. As soon as we can come up with some more solid information on actual specs and pricing, we will set up a pre-order for the LCG as well.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 03-31-2005, 11:39 PM   #13016
JayBee's Avatar
Post
Hey Steve,
This is a pre-order pre-request... PUT ME 1ST ON THE LIST - JB
Old 03-31-2005, 11:46 PM   #13017
SpeedTech's Avatar
Originally posted by JayBee
Hey Steve,
well that's a first, a pre-request for a pre-order....hahahahaha. But you already have one of these (the SDW )
Steve Wang
Old 03-31-2005, 11:55 PM   #13018
Hebiki's Avatar
Trader Rating: 26 (100%+)
Hey Steve,
cant be first on the list.. Steve is always first. you can be third. (im second)
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 04-01-2005, 12:40 AM   #13019
JayBee's Avatar
Post
Steve Wang
The SDW is a trophy piece, I need the LCG conv. kit to race with and... Hebiki, dem's fight'n words - JB
Old 04-01-2005, 12:50 AM   #13020
Hebiki's Avatar
heheh nah. i just live closer to his shop. thats all.
Hebiki Design Works
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
