Yokomo MR-4TC SD
Old 03-25-2005, 05:58 PM
  #12916
rovic's Avatar
Originally posted by Johnnytc3
Doesnt that defeat the purpose? I thought the main point of the spool was the ability to break.
actually the main benifit of the spool is to pull the car out of the corner, without the front wheels unloading. breaking is something you could live without, since the spool causes push anyway...
I think the main idea is to combine the front spool with this center oneway to have better cornering speed.
without any diff action, i still believe the frontend will push. its just underbreaking the car will rotate as expected.
rovic is offline
Old 03-25-2005, 06:53 PM
  #12917
I see what you are saying, but what i was saying was since both one ways and spools are used to pull out of the corner, you would want to use the spool when you braking is important.
Johnnytc3 is offline
Old 03-25-2005, 09:35 PM
  #12918
rovic's Avatar
braking with a spool causes frontend slide, push... unless your breaking in the straight; with the steering pointed straight; the end result is car going straight.
(not using brakes) off throtle cornering with a spool has a very soft initial steering; slight push. on small track the car tends to slide alot (when holding the line), on throtle and off it just slides making acceleration benefits null; its almost like driving a drift car... bigger tracks the spool can be maximized, because brakes are rarely used.
rovic is offline
Old 03-25-2005, 11:09 PM
  #12919
JayBee's Avatar
Trader Rating: 31 (100%+)
Post question about the grease...
inside the oneways, can it be cleaned out and replace with something thinner like Tribo? Will this help or harm the action of the oneway; will this help to free it up a bit?
- JB
JayBee is offline
Old 03-26-2005, 03:32 AM
  #12920
JimmyMac's Avatar
I actually use micro oil in my oneways.. hehe.. And they have lasted for 2 years. So I guess it's fine to use. Just be sure to keep them lubed up.
JimmyMac is offline
Old 03-26-2005, 08:34 AM
  #12921
JayBee's Avatar
Post
Thanx K-Ruf, I'm on it. Got the whole front-end torn apart and just cleaning & going through it
- JB
JayBee is offline
Old 03-26-2005, 08:47 AM
  #12922
jaybee call me, now. ritchie
Turtlemaster is offline
Old 03-26-2005, 02:38 PM
  #12923
coastaltony's Avatar
I'm considering getting a SD till the H.B. car comes out. Whats a good price for me to pay for a new one?
coastaltony is offline
Old 03-26-2005, 02:47 PM
  #12924
Cgm or Silver/black?
Old 03-26-2005, 03:10 PM
  #12925
My bad, but I thought SD was "Black Special" carbon chassis. Yes, looking for SD "black special" to race on smooth prepaired asphalt.
Old 03-26-2005, 03:26 PM
  #12926
Your in luck, kthobbies.com has them for 229.99, they are around 260-290 every where else.
Old 03-26-2005, 03:28 PM
  #12927
Cool thanks for the input
Old 03-26-2005, 08:10 PM
  #12928
Default productD parts
has anybody tried there internal gear ratio kit . it changes it to 2.5 instead of its 2.29 I think thats it .
snaponjunky1 is offline
Old 03-26-2005, 08:19 PM
  #12929
rovic's Avatar
Default Re: question about the grease...
- JB
ive had bearing failure (slipping)in the past with oil/silicone; it also attracts alot of dirt. why risk it?
rovic is offline
Old 03-26-2005, 08:26 PM
  #12930
jiggen5354's Avatar
Default Re: productD parts
I have it. I don't think theres any real benefit. aside from it being blue. it changes the internal ratio from 2.353 to 2.5.
jiggen5354 is offline
