Old 03-08-2005, 10:32 PM   #12736
Default sdw
anyone have or know of where i can get a set or two of arms for the sdw
Turtlemaster is offline   Reply With Quote
Old 03-08-2005, 10:41 PM   #12737
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
Tried SpeedtechRC?
www.speedtechrc.com
v0rtex is offline   Reply With Quote
Old 03-08-2005, 11:29 PM   #12738
I mounted the NIKI one in mine and I like it. I didnt have to dremel at all.
Not? Do you can show me a pic while the motor mount is installed?
speedy-932 is offline   Reply With Quote
Old 03-09-2005, 04:09 AM   #12739
Lonestar's Avatar
Originally posted by Johnnytc3
Ive noticed there is quite a bit of flex with the CGM without the battery in or even with the battery in as the battery mount posts are non-adjustable and the battery sits somewhat loose. When i press the battery strap down, the chassis is as stiff as a brick. Ive ordered the Tobee adjustable post and hope this solves this issue.
Johnny
careful not to mount it too tight in order to
1- not tweak the chassis
2- prevent that it flexes less on the batt side than on the electronics side...
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 03-09-2005, 08:09 AM   #12740
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
I wonder how much stiffer my SD will be when the World's upgrade become availble next month??????
Has anyone with the SDW notice that the car is stiffer in comparision to the SD/Rayspeed?
Just wondering....+waiting for the new ride...BD
-Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 03-09-2005, 08:10 PM   #12741
hate to be the one to tell you but the sdw is not a stiff chassis/car
i know jaybee has both the rayspeed and sdw so he can say how much difference for sure.
vortex, thanks for the tip, but been there done that. and hes out of stock. and these other online shops are just a nightmare for me to get around. steve definately did his homework and site navagation
Old 03-09-2005, 08:21 PM   #12742
Blakesrc's Avatar
Send a message via AIM to Blakesrc
Default Rayspeed Towers and Yok Hd arm holes
Hey Guys,
I still dont have any of the new hd arms for my standard sd but it seems like i have been told they only have 3 holes instead of 4. Are those 3 holes the same as 3 of the holes on the standard arms and if so what ones? Also, same situation with the rayspeed towers, they only seem to have 4 camber positions, are they the same as 4 of the camber positions on the stock towers, if so what ones? Lastly, the shock top location on the rayspeed towers, " " I have a setup that uses hd arms and rayspeed towers so im trying to see if i can use what i have rather than buy new parts.
Thanks for your time,
Blake
Blakesrc is offline   Reply With Quote
Old 03-09-2005, 09:06 PM   #12743
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
Shook-
The Rayspeed conversion is the stiffer of the two; it's in-between the Black vers. and CGM.
- JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 03-09-2005, 09:37 PM   #12744
Originally posted by JayBee
Shook-
- JB
Wahy about stiffness of the SDW in comparasion?
Thanks,
Stpehen <><
Old 03-09-2005, 09:40 PM   #12745
JayBee's Avatar
Post
The SDW is what I'm comparing Shook.
- JB
Old 03-09-2005, 09:54 PM   #12746
Thanks,
just misread.
How has the Rayspeed been treating you?
I got a kick in the pants last weekend after tearing apart my entire car and re-built everything, reset everything to stock RS settings and found it to be very sound settings. I only needed minor changes to toe and camber to achieve the desired effects.
Man they must have really worked that setup to get it that close. Well at least for asphalt. I ran it at SoCal which is indoor high bit asphalt and then again at Hot Rod Hobbies which is medium bit (only cause it has lots of tiny pebbles) and is outdoor. Both times the car handled very well with the stock settings.
I will have to do more testing to get my final setup for asphalt but I am almost there.
I am really looking foward to the BD,
I got all new electronics ordered and on the way.....i.e.
Ko Propo PS2363
GM Racing SX12
Spektrum Receiver
I can not wait....
Old 03-11-2005, 07:48 AM   #12747
Anyone else using the Shooters amluminum inner camber link mount.
Here is picture of it.
I have one and waitign for another for the rear...
It gives a more horizonal line to the camber link.
Just wanted to know others thoughts on this item.
Thanks,
Stephen <><
I will also put a picture of my yok with it on the front.
Old 03-11-2005, 07:49 AM   #12748
Here is the picture of it in my car, it is on the front.
thanks
Stephen <><
Old 03-11-2005, 09:17 AM   #12749
Matt Howard's Avatar
I used the early version of the shooters mount and it bent real easily since it was so thin. I believe they've made them thicker since then. I liked it since you can put shims under the inside ballstud to slightly alter the camber link angle
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 03-11-2005, 05:26 PM   #12750
Default SDW
With front end geometry, To make the kick up 1deg (from 0deg) do i jus out a 1mm shim under the front/front sus mount?
Xray T2 09 (still) - LRP - MuchMore - Futaba 3PK (still)
Bluey_74 is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
