Yokomo MR-4TC SD >
Yokomo MR-4TC SD
Like Tree12Likes
Yokomo MR-4TC SD
Old 05-13-2003, 10:07 AM
  #1261
THeGame's Avatar
Default Chris@WeaponR
what car were you running before the Yok ? Rollout the same..
THeGame is offline
Old 05-13-2003, 10:11 AM
  #1262
utieh's Avatar
i would really like to answer to you but i noticed the gearing i used were different than the set up sheet i used to see
for example with a 13x3, used a 25/72 combo while looking at grainger's, it was for a 12x2 31/72!, when i putted a 26 pinions, the motor was a way to hot (i am using 2400 and 3000H batts)
with my spec 17x2 motor i am usinga 28/72 (29,s too hot too)
it was on hogh grip small track so perhaps it is the reason .
just try different gearing and u will find it quickly but don't follow my advice, i am not a good driver and the conditions were specific.
utieh is offline
Old 05-13-2003, 10:23 AM
  #1263
R/C Tech Founder
Gearing is a very difficult thing to suggest because it is so dependant on track configuration and your driving style. For example, I gear a Monster Stock in the 6.5-7.0 range for tracks like TCHR in Minnesota or Trackside in Milwaykee, whereas I gear it closer to 8.7-9.2 for my home track here in Madison. That is with the same car and everything else being the same.
futureal is offline
Old 05-13-2003, 12:28 PM
  #1264
Regional Moderator
Darkseid's Avatar
so....so.....true.
THe best place to find advice about gearing is at the same track your racing at. Even if your using different cars, odds are that the advice someone gives you there, will be better than what we can give you here.
The monsters around here are usually geared around 8.7 final. While the 19turns are geared around 7.20-7.50. And thats about everyone, no matter what car your running.
Darkseid is offline
Old 05-13-2003, 03:02 PM
  #1265
THeGame's Avatar
Does anyone know when a graphite kit will come out ?
THeGame is offline
Old 05-13-2003, 03:09 PM
  #1266
THeGame's Avatar
speedtech
Can I Pre Order the oneway ? when do you think they might come out ?
THeGame is offline
Old 05-13-2003, 03:50 PM
  #1267
Matt Howard's Avatar
Thegame- the oneways will be in the states by the end of the week. I haven't heard anything about a graphite kit yet.
Matt Howard is offline
Old 05-13-2003, 04:55 PM
  #1268
THeGame's Avatar
Thanks Matt.
THeGame is offline
Old 05-13-2003, 06:23 PM
  #1269
Jeff Werner's Avatar
Trader Rating: 30 (100%+)
What are these grumblings about a "Black" SD? Any info on that car or better yet any pics...lol
I think this will be my next car (SD). Going to race this weekend with my New G+ but will look to maybe move it after the weekend to get me a new kit. Keep up the good work Yok guys!
Jeff
Jeff Werner is online now
Old 05-13-2003, 06:32 PM
  #1270
BigDogRacing's Avatar
You are so right Shane!! We were gearing the 19 turn C2's 6.5 at the Snowbirds!! Eric told me what to gear it (before rollout) and I was like... WHAT?!?! Really?!?!?! well, OK, you're the expert...lol
BigDogRacing is offline
Old 05-14-2003, 12:02 AM
  #1271
DickemDown's Avatar
thanks sosidge, thegame, & johnbull for explaining kick-up/roll center in relation to reducing castor. i'll spend a day trying things out.
DickemDown is offline
Old 05-14-2003, 12:59 AM
  #1272
alana07's Avatar
Trader Rating: 53 (100%+)
Jeff
is there really a black sd available? i was about to jump onto the ssg bandwagon!! any pics or links to the black sd would be appreciated.
alana07 is offline
Old 05-14-2003, 01:18 AM
  #1273
R/C Tech Founder
The "black" kit is a tub-style chassis, similar to the TC Special, or so I am told. Sounds like it might be available in Japan as early as next month.
I have yet to see a pic of this thing, though.
futureal is offline
Old 05-14-2003, 08:52 AM
  #1274
SpeedTech's Avatar
Hi Guys,
I forgot to mention that the Ti-Screw kit are hex heads (allen wrench type). In case any of you were wondering
TheGame,
Sure, you can pre-order the one-way, I'm sure we'll have them as soon as they hit the states.
Steve Wang
SpeedTech is offline
Old 05-14-2003, 10:36 AM
  #1275
IH
IH's Avatar
Default Turning servo 90 degree
Is there any increase in performance besides you gain space, when you turn the servo 90°? Does it improve the steering linkage angle, too?
Greets,
IH
IH is offline
