Old 03-01-2005, 06:49 PM   #12661
anybody know where I can find the ball stud king pins like the SDW had for the front camber links?
kmorast is offline   Reply With Quote
Old 03-01-2005, 07:03 PM   #12662
rc_bam226's Avatar
oooooh, ZC-206SA ALUM. BALL STUD HARD COATED W/ STOPPER, not that one, the KING PIN (BALL TYPE) ZS-007F,you might want to check with Steve at Speedtech about that one.
rc_bam226 is offline   Reply With Quote
Old 03-01-2005, 09:04 PM   #12663
Default Gearing between classes
How much of a difference do people use when changing between different classes. Im only talking about Spur sizes.
Do you find that a 75 tooth works better for 19T but a 68 better for stck?(AS AN Example)
Ive been messing around with different sized spurs for Stock and 19T racing, but i cant find much of a difference!
What does every one else do?
Thanks in Advance
Xray T2 09 (still) - LRP - MuchMore - Futaba 3PK (still)
Bluey_74 is offline   Reply With Quote
Old 03-01-2005, 09:10 PM   #12664
Default Gearing
I forgot to add, I regularly use med to large tracks, med traction(ie not car park grip) and use stock gearing about 5.80 in a Yoke CGM.
Old 03-01-2005, 09:15 PM   #12665
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
The main changes most people make with thier spur is to go to 64pitch, often when using foams on carpet..
It allows a much finer ratio adjustment over 48pitch. I think you wont notice too much difference with different spur sizes so long as the ratio is the same.
Notice my new rc car Simon?
v0rtex is offline   Reply With Quote
Old 03-01-2005, 10:36 PM   #12666
I did notice your pic!!
Nice effort!
I have noticed a bit of diference,. Ran the car with 5.86 with a 68 tooth, and then went to a 75 tooth, with the gearing as close as i could get enf there was heaps of difference. in performance, motor temp, and rutime!!
Thats why im curious!
Old 03-01-2005, 10:37 PM   #12667
Serious!? I didnt think there would be much difference really..
Old 03-02-2005, 01:10 AM   #12668
SpeedTech's Avatar
Hi Guys,
the new Team Suzuki Light Weight 0.5 degree rear hub carriers are in stock
Also, some of you were looking for the SD Worlds sway bar set, and they are available now as well.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 03-02-2005, 02:08 AM   #12669
Lonestar's Avatar
There should not be.
could be that the 75spur was of better quality/shape, or that the mesh was better adjusted.
Besides that, gear ratio is gear ration (no matter what productD says).
Cheers,
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 03-02-2005, 05:45 AM   #12670
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
I don;t know if anyone else is excited but I am. About the conversion kit for the SD.
It will brign the SD upto almost SDW standards and should be out first part of April. I look forward to it.....
-Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 03-02-2005, 06:20 PM   #12671
Send a message via AIM to Johnnytc3
Does anybody know what size screw is needed to attach the Ring Gear to the Spool or Oneway.
thanks
Johnny
Johnnytc3 is offline   Reply With Quote
Old 03-02-2005, 06:22 PM   #12672
Tek Nickal's Avatar
I think the larger the spur, the smoother the car feels. A smaller spur would give a more aggressive feel.
Tek Nickal is offline   Reply With Quote
Old 03-02-2005, 06:24 PM   #12673
rc_bam226's Avatar
thanks
Johnny
I believe its a 1mm, 0.5 pitch metric screw with a phillips head. If you can find the one maintenance kit for the oneway it would have those screws. Hope this helps.
Old 03-02-2005, 06:25 PM   #12674
Thanks, do you know if they come with the one way ring gear and shaft gear set?
thanks
Johnny
Old 03-02-2005, 06:29 PM   #12675
rc_bam226's Avatar
thanks
Johnny
Sorry, the gears are sold separately as a set. The one way maintenance kit has the screws, and the o-orings that are inside the drive cups.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
