Old 02-26-2005, 06:32 AM   #12616
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default dogbones/axles
anyone have pictures of their SDW with the universals replaced with the usual dogbone/axle set up from the SD? i read that some dremel work is required, but i dont remember what page i read it on or where to dremel. thanks guys.
*thinking of replacing the universals* on my SDW once they wear. thanks!
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 02-26-2005, 07:04 AM   #12617
Matt Howard's Avatar
You need to dremel the end slightly if you're using the silver universals from the old belt drive car.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 02-26-2005, 07:20 AM   #12618
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Have you subcribed yet.....??????????
http://www.rctech.net/forum/showthre...0&pagenumber=1
Thought I would let you guys know about this so you could make the top 100 for the free gifts Shane is sending out. Plus you actually get to help this forum grow....Didn't see many names on the list from my fellow Yok drivers....GET HOT....HELP OUT
-Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 02-26-2005, 09:23 AM   #12619
Default Re: Quick question.....
Originally posted by Mabuchi540
what size hole do I need to put in a touring car body to fit the Amb transponder?
Oh and yes I'll probably get the new belt car too (always been better with belt drive).
6 or 7mm hole.
Dan Hughes is offline   Reply With Quote
Old 02-26-2005, 10:59 AM   #12620
Send a message via AIM to Johnnytc3
How do you correctly measure droop on this car (CGM) , where the caster block is the lowest or on the edge of the arm??
thanks
Johnny
Johnnytc3 is offline   Reply With Quote
Old 02-26-2005, 12:37 PM   #12621
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Lowest position of the caster block is the point for measuring droop.
I'm probably giving SDW up and try TRF415.. Only because i can't get the car right on carpet and rubbers.. Just can't get the real grip.. Don't tell me i have'nt tried to set it up.. i've got some real good help from my sponsor to get it working..
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 02-26-2005, 12:41 PM   #12622
That's too bad, I think the CGM is much better on carpet than a flat chassis. It is much stiffer than a flat graphite chassis. Hope you save your SDW for outdoors.
pops is offline   Reply With Quote
Old 02-27-2005, 11:35 AM   #12623
Im having a hard time getting my rear transmission to be free using the pin in the spur adapter, it seems like the pin limits the ability to shim the rear input shaft. Without the pin, the tranny spins like butter, Is it ok to run the car without the spur adapter pin?
thanks
Johnny
Old 02-27-2005, 01:04 PM   #12624
thanks
Johnny
No, the pin keeps everything in place. Even though you have a set screw, it could loosen and then you will have more problems. The pin should go in without any effort. Maybe you have a bearing not completely seated in the tranny case? This happened to me once. Tried to force it and wrecked the seal on the bearing. This caused the bearing to drag. Just check those bearings again. Hope this helps.
Old 02-27-2005, 01:11 PM   #12625
rovic's Avatar
thanks
Johnny
if you could run the car without the adapter pin (??); then its not the same pin you are saying...
you could run without the set screw on the adapter...
rovic is offline   Reply With Quote
Old 02-27-2005, 01:19 PM   #12626
No i have the set screw holding the adapter to the input shaft, and im not using the pin, it doesnt even look like the pin will fit anyways as the holes dont line up, Im just wondering if the Set Screw could hold the adapter on during a race.
THanks
Johnny
Old 02-27-2005, 02:39 PM   #12627
rovic's Avatar
THanks
Johnny
the pin is first inserted and then adjusted to the correct mesh & drive shaft coupler can be pinned.
its not a good idea to run with just a set screw, because if tighted hard/firm it will distort the adaptor...
Old 02-27-2005, 04:17 PM   #12628
thanks rovic i didnt even know there was a recessed area for the pin to slide in, that was my problem all along.
thanks
johnny
Old 02-27-2005, 08:43 PM   #12629
Trader Rating: 39 (100%+)
Send a message via AIM to Zac R Send a message via MSN to Zac R
Default setup
does anyone have a good set up for a carpet track with
rubber tires and a stock motor??
and what about a setup for foam with mod on carpet?
thanks
92zero Designs - AKA - O.S Engines - Futaba - Team Orion - B-Fast R/C LiveRC.com - RC Scoring Pro - TFR
92zero Deisgns
Decals - Clothing - Pit boards - Wraps - Signs - Banners & More
Zac R is offline   Reply With Quote
Old 02-27-2005, 09:39 PM   #12630
Default Re: setup
thanks
There's a bunch of setups posted on www.yokomo.tk Tosolini's carpet nats setup seems to be the one most people like for foam carpet racing.
RCTech #361
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
