Old 02-21-2005, 02:29 AM   #12541
FW-05RR's Avatar
these new prototype "one-piece" super light weight aluminum bulk heads equipped with carbon top support plate designed for rigidity and easy maintenance
FW-05RR is offline   Reply With Quote
Old 02-21-2005, 02:58 AM   #12542
Matt Howard's Avatar
Originally posted by Bosscat
Just got some Rayspeed Shock Pistons and they have a groove milled on one side around where the holes are.
Which way up do I use them groove up or down or doesn't it matter??
it doesn't seem to matter.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 02-21-2005, 05:40 AM   #12543
Just checking if I've got this right before I try it....
The front hinge pins are held in place by part SD-300 which is marked F1 and if I've read correctly that refers to 1 degree of front kick up?
So if I use the part F0 instead I'll have less kick up and more steering as a result?
Would castor need to be changed as well?
Mabuchi540 is offline   Reply With Quote
Old 02-21-2005, 07:20 AM   #12544
Default Re: Just checking if I've got this right before I try it....
with zero kickup the car will have better on power steering but lose a tad bit of offpower steering. Yokomo only has 4 deg castor blocks so changing your castor isn't even an option. Most of the time I run the 0 deg front mount
RCTech #361
Old 02-21-2005, 08:17 AM   #12545
Send a message via AIM to Johnnytc3
Does anyone know the base setup on the CGM? I dont think it came with one, only a blank setup sheet. Ive looked on yokomo.tk but the server was down as always and the yokomousa site only has setups with one ways, i only drive with a solid.
Anybody have a good starting setup for a medium sized , medium traction , alsphalt track using a solid axle up front?
Johnnytc3 is offline   Reply With Quote
Old 02-21-2005, 08:22 AM   #12546
http://www.ultratechcleaning.com/yok...ps/spool-2.jpg
I just checked and yokomo.tk is back up and running, here's my spool setup and it should be good for a medium sized medium traction track.
RCTech #361
Old 02-21-2005, 08:45 AM   #12547
Thanks Matt, thats exactly what i needed, although i like to have lots of steering so i will probabably do same oil front and rear, ive noticed that the stock pistons are quite loose, are the rayspeeds any better or just another tuning option?
Old 02-21-2005, 08:59 AM   #12548
the Rayspeed pistons fit the shock body perfectly
RCTech #361
Old 02-21-2005, 01:09 PM   #12549
Post Once again
then I must have gotten some from a bad batch because the ones I just fitted during a rebuild had gaps barely smaller than the kit ones.
Old 02-21-2005, 01:17 PM   #12550
Default Re: Well then ......
Once again I must have gotten some from a bad batch because the ones I just fitted during a rebuild had gaps barely smaller than the kit ones.
I don't believe you got a bad batch... if you measure the Yoke stock ones, and compare them to the Rayspeed you will notice the Yoke stock ones are smaller. You have to have a little play in the shock body for some blow-bye. Otherwise the shock would rub too much and stick. The Rayspeed pistons fit the Yoke shock bodies a little more tighter than the Yoke pistons.
pops is offline   Reply With Quote
Old 02-21-2005, 01:25 PM   #12551
Default Re: Re: Well then ......
Must be our different understandings of the word "perfect fit" then I guess.
I got some with larger holes than the stock ones I use because people have said time and again "perfect fit" now the ones I've ended up with are way to fast with the weight of oil I have and I have no thicker oil.
Old 02-21-2005, 02:27 PM   #12552
Default Re: Re: Re: Well then ......
I would have to agree, that the Rayspeed pistons are more of a perfect fit.
Which ones are you running and what did you run before?
Old 02-21-2005, 02:30 PM   #12553
Ive seen a setup that uses AE pistons, now how do these fit? I have tons of Ae pistons
Old 02-21-2005, 02:37 PM   #12554
Default Re: Re: Re: Re: Well then ......
Was running 3 hole Yokomo ones now 3 hole Rayspeed ones, I assumed of course that with the better fit and from what others have said about the fit that bigger holes would be required anyway.
Old 02-21-2005, 04:22 PM   #12555
TFR
TFR's Avatar
" ヨコモ新ベルトドライブEPツーリングカー
ヨコモさんに問い合わせたところ、新しいベルトドライブツーリングカーが28日に発表されるようです。現在 最終テスト中で、画像&詳細は2月28日(月)とのことでした。期待ですね!!"
New Yokomo belt drive car.
TFR is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
