Old 02-18-2005, 03:57 PM   #12511
Default rob philips
Rob, plenty of us have used the light weight chassis, no set up issues, or strength issues.
Cant recall how much weight it saves, but anything is an iimprovement.!!
Xray T2 09 (still) - LRP - MuchMore - Futaba 3PK (still)
Bluey_74 is offline   Reply With Quote
Old 02-18-2005, 04:03 PM   #12512
Hey Rob, on my cgm I tossed out the batt. strap and post. Cut the the post off the motor mount, and dremeled some slot's to tape the batt. in. That saved almost an ounce. I took off all the chassis braces, and run just the wide foam bumper not the plastic. I have the old style steel front shaft's in the car and it weigh's in at 51.2 ounces! Our min. wieght is 51.
I also drilled some holes in the chassis too. It flexes a little, but with Tosolini's last Cleveland set-up in it, it goes pretty good on carpet. Had a hard time with it last summer on asphalt, but may try some of the trick's I have learned on carpet and see how that does, ie. roll center's, anti-dive, etc.....
As for gear I run 34/100, 64 pitch, with 57 mm tires in stock.
HENRYJ is offline   Reply With Quote
Old 02-18-2005, 06:22 PM   #12513
Originally posted by lem2
Hmmmmm... Now I get it. Yes it does that also, will putting O-rings on each side help? It only does that on slow speeds, hope it will not speed up the wear.
Good Luck to all racing this weekend!!
I wouldn't put O rings in each side. You need a little play. With a frontal hit you could damage the drive train if there isn't any give for the shaft.
The directions call for you to put the O ring in the rear cup, I put it in the front. This makes the shaft sit deeper in the rear cup. Was having problems with the rear cup breaking (plastic cups) in mod. Haven't broken a rear cup since I changed the O ring placement.
pops is offline   Reply With Quote
Old 02-18-2005, 11:15 PM   #12514
lem2's Avatar
Thanks for the Tip!! Will do that!
RobPhilips: all the suggestions to cut down weight are really great, if you want more--It will be an expensive process. Ti this and that, alum here and there. But its a grreat car as it is!
lem2 is offline   Reply With Quote
Old 02-19-2005, 01:53 PM   #12515
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Well, i finally got my SDW like i want, regular long HD arms in front made the trick, along with Rayspeed green springs, and a shorter camberlink inf ront. I'll see if i can make a setupsheet later..
The car is much easier to drive on carpet and rubber now, best car i've driven, period.
*edit*
I had nothing else to do so i made a sheet.
PDF file
looks terrible because of comprimation but i hope you can see anyway
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 02-19-2005, 02:29 PM   #12516
rc_bam226's Avatar
Hey Sparx, looks legible to me.
rc_bam226 is offline   Reply With Quote
Old 02-19-2005, 02:41 PM   #12517
NVisible's Avatar
Hey guys, im wondering if any of you can tell me what the SDW box looks like. Im looking at what i think is one, but i want to be sure its legit
NVisible is offline   Reply With Quote
Old 02-19-2005, 02:52 PM   #12518
NVisible
It looks pretty low budget, just a black box with MR4TC SD and a big sticker that says something about ISTC2004 champion, all in japanese :P
I'll see if i can get a pic
Old 02-19-2005, 02:54 PM   #12519
NVisible's Avatar
that sounds about right. Shiney lettering on the big SD right?
thanks for your help!
Old 02-19-2005, 03:00 PM   #12520
Exactly
See attachment
Old 02-19-2005, 03:01 PM   #12521
NVisible's Avatar
sweet. you da man.
thanks!
Old 02-19-2005, 08:25 PM   #12522
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
What parts from the SDW will fit a CGM? Specifically, I want to know if the main drive shaft will fit.
Thanks!!
PitNamedGordie is offline   Reply With Quote
Old 02-19-2005, 08:48 PM   #12523
NVisible's Avatar
have you guys had a chance to check out the pics at TQ racing?
http://www.tq-racing.com/events/titc05/headlines.htm
im not up to scratch on the SD, but that thing looks pretty killer
Old 02-19-2005, 08:57 PM   #12524
Hebiki's Avatar
Trader Rating: 26 (100%+)
looks like the SDW bulkheads got revised so one-way and diff maintainence will be easier.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 02-19-2005, 08:59 PM   #12525
eeyan's Avatar
Send a message via AIM to eeyan Send a message via Yahoo to eeyan
Ahhh geezzz... i haven't ran my sdw, and there's already an update?! What a hobby...
TAOB Racing Team (1999 - 2011)
eeyan is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
