Old 02-17-2005, 02:59 PM   #12481
Surprise, Adachi is not running Rayspeed chassis, looks like a SDW with silver top deck and different shock towers. Unusually rear camber links set up!
caveman is offline   Reply With Quote
Old 02-17-2005, 03:07 PM   #12482
Registered User
ritchie's Avatar
if anything i would say yokomo might make a conversion kit for the ssg or cgm to turn into a worlds car, or they could just change a few things and it wouldn't be a worlds kits, i.e. standard screws, input shafts,and cvd's all the things that raise the price of the sdw.
ritchie is offline   Reply With Quote
Old 02-17-2005, 04:59 PM   #12483
iamramos's Avatar
Default Re: ya
Originally posted by 05fordgt
r your sd ssg quiet or loud, quiet as in you can only hear the motor quiet. lmk
05- check that you shims aren't bent and do the shimming correctly. you will also need some lube.
My first SD made some wicked sounds but after I notices bent shims and gear binding, I reshimmed it and its been quiet from then on.
iamramos is offline   Reply With Quote
Old 02-17-2005, 05:05 PM   #12484
Default hi
could you tell me where i dont know where to shim the car. this is my first time doing it.
05fordgt is offline   Reply With Quote
Old 02-17-2005, 05:08 PM   #12485
Tek Nickal's Avatar
You shim the shaft thats on the bevel gear that goes to the diff.
Tek Nickal is offline   Reply With Quote
Old 02-17-2005, 05:28 PM   #12486
iamramos's Avatar
05- I have a post from yesterday, read that first.
Old 02-17-2005, 06:05 PM   #12487
Default shim
so i put the actual sim between the 5x10 bearing and the center drive cup
Old 02-17-2005, 06:36 PM   #12488
Default steering
its me again, i was just wondering if anyone could just hook me up with the stock steering, i just want it that way so you guys that use the modified way, could you give me your stock steering linkage, the guy before me who had i never gave me the 90 part thta hooks the turnbuckles to from the servo to the 90- degree part., just lmk if you guys can give it to me.
thanks
05forgt,
Old 02-17-2005, 07:39 PM   #12489
lem2's Avatar
Originally posted by pops
Did not like the Suzuki lightweight cups for those same reasons. So went back to the plastic cups. I don't think the Suzuki cups are bad, just didn't like the excess play.
The Roll bars are color coded, you have to measure them with calipers to determin the thickness.
Copper 1.5mm
Brass 1.2mm
Silver 1.1mm
Black 0.9mm
The RAYSPEED lightweight input cups are as light as the plastic ones and I have not noticed any play. EDITED(its Team SUZUKI not raySpeed, sorry)
Got my TS lightweight rear hubs!!! I think there will be too much toe in in the rear and will wear my tires fast, but the track we will be playing this sunday is a bit dusty. with the 3+0 rear holder, I'm getting 3.5 degrees of toe in right?
lem2 is offline   Reply With Quote
Old 02-17-2005, 11:00 PM   #12490
If you are running the hollow graphite shaft, it is really loose in the lightweight Suzuki cups.
pops is offline   Reply With Quote
Old 02-17-2005, 11:52 PM   #12491
Thumbs up That has helped a whole lot.....
Originally posted by Matt Howard
It sounds like you have too much front grip, try a stiffer spring or sway bar in the front and see what happens.
thanks (sway bar suggestion initiated lol ).
It is basically at the stage I wanted to get it to, in that it is now up to me to put it where it needs to go and if I can't get it around the track it's my fault rather than anything I can pin on the car itself.
Hope that makes sense?
The hooking is also (as best as I can tell if it happens) now my fault just for trying things to fast rather than the car setup as such. Double thanks.
The only thing that concerns me now is that seeing as I have the two diffs instead of a one-way I notice I have to enter the hairpin turns as pictured in the second black and white picture in this link.....
http://www.tckc.net/tips_faqs/drivin...techniques.htm
in that if I brake just before I turn I can get around as pictured (although the exit is a little tighter than that) which is all well and good if it's just me lol.
But any suggestions as to how I might be able to make the entry (to this type of turn) a little tighter so I don't get one-way equipped cars coming up on the inside would be appreciated.
About the only adjustments I can think of that I haven't tried (now that the anti-roll is the stiffest I've got) is to swap the green to the front and the pink to the rear or go from 2 to 3 degree toe angle on the rear?
Mabuchi540 is offline   Reply With Quote
Old 02-17-2005, 11:56 PM   #12492
What do you guys think of the RIDE bodies?
Its something I havent seen much of, anyone tried them on an SD?
Xray T2 09 (still) - LRP - MuchMore - Futaba 3PK (still)
Bluey_74 is offline   Reply With Quote
Old 02-18-2005, 12:07 AM   #12493
Blakesrc's Avatar
Send a message via AIM to Blakesrc
Bluey,
I am using the Yokomo stratus E which i believe is the same as the ride mkII and its great. The mkIII is suppose to have more steering and the mkI i believe is for larger flowing tracks.
Blake
Blakesrc is offline   Reply With Quote
Old 02-18-2005, 12:31 AM   #12494
lem2's Avatar
Just asking, did you guys place the small O-ring inside the Suzuki LtWt Cups??? (Its TS not RS my mistake)
I'm also using the Hollow Carbon shaft and its not loose at all
Old 02-18-2005, 01:03 AM   #12495
Hebiki's Avatar
Trader Rating: 26 (100%+)
i have the mk.III and ride accord... as soon as this bloody rain storm leaves southern california. ill let you know. (i was very happy with the Mk.III with my "other" car)
[begin rant]i swear.. with all this #[email protected]%ing rain...its like i live in seattle now. [/end rant]
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
