Yokomo MR-4TC SD >
Yokomo MR-4TC SD
Like Tree11Likes
Yokomo MR-4TC SD
Old 02-15-2005, 03:03 PM
  #12436
Blakesrc's Avatar
Trader Rating: 24 (100%+)
Sparx and Racer,
I was told by Robert at yokomo that you can use the hardened universals if you grind or sand down the end of the ball to the pin on the one way side. I would imagine you could use any drive shaft if you did that as well.
Blake
Blakesrc is offline
Old 02-15-2005, 04:31 PM
  #12437
lem2's Avatar
Originally posted by Blakesrc
Sparx and Racer,
Blake
In the RAYSPEED MIP CVD unit, the instruction is in Japanese, I understand the part about shimming the front one way cups, what I cant figure out is: if we use the RS-MIP CVD's in front, do we have to trim a part of the Alum HEX hubs?
Our brothers in Japan? or Masami? Can Help?
And since its MIP, it only uses American (standard) nuts, not metric? Am I correct?
The MIP looks really beefy if your using a spool.
lem2 is offline
Old 02-15-2005, 06:58 PM
  #12438
Regional Moderator
daniz24's Avatar
Default Re: Part number for SDW arms
Originally posted by Al Williams
Does anybody know the part numbers for the SDW suspension arms. Are the front ones even available yet. I ordered some SD008HW, - are these just the rear ones ?
This is SDW part number for all you guys reference. SD-008hw is 1 pc front and 1 pc rear arm
SD-200LW SERVO SAVER MOUNT (PAIR)
SD-200BW SERVO SAVER POST & COLLET
SD-118GW BATTERY PLATE (GRAPHITE)
SD-118MW BATTERY POST (PAIR)
SD-300FFW ALUM FRONT SUSPENSION MOUNT (FRONT PIECE)
SD-300FRW ALUM FRONT SUSPENSION MOUNT (REAR PIECE)
SD-630W SPUR GEAR HUB
SD-302W ALUM TRANSMISSION CASE
SD-010FW FRONT UNIVERSAL DRIVESHAFT (W/SPACER)
SD-010RW REAR UNIVERSAL DRIVESHAFT (W/SPACER)
SD-008HW FRONT & REAR LOWER SUSPENSION ARM
SD-304W MOTOR MOUNT
SD-017W FRONT SHOCK TOWER (GRAPHITE)
SD-018W REAR SHOCK TOWER (GRAPHITE)
SD-003W UPPER DECK (GRAPHITE)
SD-016RF REAR BODY MOUNT PLATE (FRONT) (GRAPHITE)
SD-016RR REAR BODY MOUNT PLATE (REAR) (GRAPHITE)
SD-002W MAIN CHASSIS (GRAPHITE)
SD-412WF FRONT ANTI-ROLL BAR SET
SD-412WR REAR ANTI-ROLL BAR SET
SD-016HW FRONT BODY MOUNT SUPPORT (GRAPHITE)
ZC-206SA ALUM BALL STUD HARD COATED (W/STOPPER)
SD-644W MAIN DRIVE SHAFT (HOLLOW GRAPHITE)
daniz24 is offline
Old 02-15-2005, 09:10 PM
  #12439
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default SDW
made the dive i have blakesrc to blame.
Hebiki is offline
Old 02-15-2005, 09:13 PM
  #12440
FW-05RR's Avatar
Default Re: SDW
I knew it
FW-05RR is offline
Old 02-15-2005, 09:43 PM
  #12441
Registered User
ritchie's Avatar
with the mip/rayspeed axles you need to file down the back side of the wheel hex so when you tighten the axle nut it doesn't bind. only takes a couple of minutes i've done it, no biggie. and they use the metric nuts.
ritchie is offline
Old 02-15-2005, 09:44 PM
  #12442
Registered User
ritchie's Avatar
Originally posted by racer
has anyone swapped out the SDW's universals for dogbones?
if yes, which ones did you use for the front/back?
would the ones found on the SD work with the SDW?
Thanks in advance!
i only switched out the fronts, i'm using a set off a ssg/cgm
the bones are the same front and back, only the axle part is different.
ritchie is offline
Old 02-15-2005, 10:09 PM
  #12443
lem2's Avatar
Thanks ritchie!!!
HEBIKI: Hi! where do you race in La Mirada? Or you go down all the way to Aliso Viejo or SoCal??
lem2 is offline
Old 02-16-2005, 12:45 AM
  #12444
Hebiki's Avatar
Thanks ritchie!!!
yup.. i race at all three locations. but the SDW is not allowed at the Tamiya track on saturdays. if i get into the Reedy race, i'll be using that car for sure.
Hebiki is offline
Old 02-16-2005, 05:14 AM
  #12445
Tommy Bergfeldt's Avatar
Sparx and Racer,
Blake
I'm running the original steel CV's from SSG on my car, no need to grind anything and they hold up for 12-turn rubber real good
Tommy Bergfeldt is offline
Old 02-16-2005, 07:36 AM
  #12446
You must be running a diff and not a one-way. More clearance is needed for a one way.
pops is offline
Old 02-16-2005, 07:46 AM
  #12447
Weird, i'm running One-way and i cant see or hear any rubbing, must look after more
Old 02-16-2005, 07:55 AM
  #12448
It is not so much rubbing as that when the suspension compresses, the ball on the bone will bottom out inside the the outdrive, it should happen on a dff too, most likely hit the diff screw too. You just have to grind down the ball just about even with the pins on the bone.
pops is offline
Old 02-16-2005, 08:16 AM
  #12449
aha ok, i'll take a look at that then, thanks
Old 02-16-2005, 10:14 AM
  #12450
I remember someone posted a pic using x-ray spring steel drive shafts in the front end.
caveman is offline
