Old 02-15-2005, 12:39 AM   #12421
On the diff there should be 1 shim on each side as per instructions, put them both on the long side of the diff it helps free the car up.
Dan Hughes is offline   Reply With Quote
Old 02-15-2005, 01:13 AM   #12422
Default Initially I tried that......
(one on each side) but there was way to much side to side movement of the diff in the gearbox for my liking, and I don't like my diffs to rattle in their housings eh.
Mabuchi540 is offline   Reply With Quote
Old 02-15-2005, 03:12 AM   #12423
lem2's Avatar
Default Re: Is one shim worth 5 seconds in the long run.....
Originally posted by Mabuchi540
Ok the gear boxes have had a few runs now and are turning nice and free and after a bit of experimenting I notice....
For the sake of having a bit of free play (as near as I can tell 3mm worth at the spur) I get consistently a 45 second spin time.
Now if I move just one shim on the diff that free play almost goes completely to the point of being barely detectable (should make for better pick up right) but the spin time is consistently 40 seconds and makes a "god aweful" (comparatively speaking) noise you'd think the gearbox is going to strip itself.
So the question is sloppy and quiet or noisey and better pickup?
Are you using the stock bearings? what did you do to them??
lem2 is offline   Reply With Quote
Old 02-15-2005, 03:22 AM   #12424
Default SDW suspension arms
Are the SDW suspensions arms the same front and rear ?
Al Williams is offline   Reply With Quote
Old 02-15-2005, 03:29 AM   #12425
rough512's Avatar
The best I could do is 3 seconds on an SSG. I too would like to know how to free up the drivetrain even more. My bearings are already washed out and re-oiled with Trinity Royal Bearing oil.
I'm looking at my carbon prop shaft. It wobbles at low speed. Also, I'm using Ti axles and alum front input shaft which may contribute to less spin time.
rough512 is offline   Reply With Quote
Old 02-15-2005, 03:54 AM   #12426
Default Well yes....
I do have all the heavy stuff in it at the moment so that would add to the momentum when I give it a good spin.
Yes I am using kit bearings at the moment, and I've flushed them out and re-oiled them with trumpet valve oil. Very very thin but I'd need to re-oil every couple of days (or runs for that matter) depending on the track conditions.
Old 02-15-2005, 04:05 AM   #12427
rough512's Avatar
Default Re: Well yes....
Plus you may be 6'5" heavyweight while I'm only a puny 5"3' weakling .
Old 02-15-2005, 04:24 AM   #12428
Default Re: Re: Well yes....
I wish I was 6'5" but you got the heavy weight part right.
Old 02-15-2005, 04:42 AM   #12429
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
Default Re: SDW suspension arms
No They are not the same.
fpart is offline   Reply With Quote
Old 02-15-2005, 05:06 AM   #12430
lem2's Avatar
Default Re: Re: SDW suspension arms
And the ones in the SDW feels different, like they are made of delrin, becuase I compared my new New Yokomo Graphite arms to the SDW, they look the same but feels different.
Rough512: big things come in small packages!! I hope my new rear TS hubs will come before our Big race!! See you sunday!
Old 02-15-2005, 05:25 AM   #12431
Default Part number for SDW arms
Does anybody know the part numbers for the SDW suspension arms. Are the front ones even available yet. I ordered some SD008HW, - are these just the rear ones ?
Old 02-15-2005, 05:29 AM   #12432
lem2's Avatar
Default Re: Part number for SDW arms
it has one front and one rear! they are sweet
Old 02-15-2005, 05:31 AM   #12433
Thanks lem2 - now I understand ....
Old 02-15-2005, 01:18 PM   #12434
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Hmm, does anyone know if ZS-010A really is the CV dogbones for SD? My memory is lost and i can't seem to find a bag from them, found the art number on yokomousa though but it's a heap of bones there '
*edit* nevermind, i found the number (ZS-010RSB) at Speedtech
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 02-15-2005, 03:42 PM   #12435
racer's Avatar
has anyone swapped out the SDW's universals for dogbones?
if yes, which ones did you use for the front/back?
would the ones found on the SD work with the SDW?
Thanks in advance!
racer is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
