Old 02-13-2005, 05:22 AM   #12406
Yeah, the short SDW front arms give too much steering for oneway(rubber on carpet),I have the standard HD arms back on the car, just a little grinding, maybe 0.5mm will do.
caveman is offline   Reply With Quote
Old 02-13-2005, 05:26 AM   #12407
Forgot to say, you will need the old style arm mounts for standard HD arms.
Old 02-13-2005, 05:27 AM   #12408
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
well well, just a little grinding made 'em fit. Hope i can use some other bodies than Parma Alfa to get it around the track now
Thanks Caveman for the info even though i did'nt read it before i started building :P
No probs, i did already know that
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 02-13-2005, 09:58 AM   #12409
What driveshafts am i best running on my SDW? Ti racing ones or the hardened yokomo belt drive ones? Dont want to run the ones that come with it.
Rick Draper is offline   Reply With Quote
Old 02-13-2005, 10:05 AM   #12410
I think the Ti Racing ones are the best option, iv never seen any break.
Dan Hughes is offline   Reply With Quote
Old 02-13-2005, 10:36 AM   #12411
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
The Rayspeed Ti. ones are great for the rear.
For the front I keep the Steel ones with the lightened axels becasue the amont of abuse I put on the front end with a one way.
Hoep this helps,
Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 02-13-2005, 10:39 AM   #12412
racer's Avatar
Originally posted by Sparx
Hmm..
Has any of you SDW-drivers tried to adapt the old regular style HD front A-Arms with blocks to your SDW? I'm havin B-I-G troubles with too much steering on my car...
have you made any changes to the setup of your car or are you using the kit setup to race on carpet?
Thanks in advance!
racer is offline   Reply With Quote
Old 02-13-2005, 12:36 PM   #12413
Hmm, what have'nt i tried you better ask.. I have struggled with a bit oversteer ever since i got it, on some tracks i did'nt notice it as much though and it was fast and concistent.
The car is MUCH faster than CGM or SSG even for me for some laps, but because of the extreme steering it has been a little twitchy on carpet and rubber and in 5 minutes i always hit some curbs, that was a seldom with the CGM..
I tried it with foam though and it was awsome!
It will be real fun to try it with the longer arms
Old 02-13-2005, 07:47 PM   #12414
Registered User
ritchie's Avatar
yep, i had the same steering problems with the SDW, way to much. easy fix though, i just put some crappy tires up front, and it was dailed. kit set up. lol
ritchie is offline   Reply With Quote
Old 02-14-2005, 01:19 AM   #12415
Default Is one shim worth 5 seconds in the long run.....
Ok the gear boxes have had a few runs now and are turning nice and free and after a bit of experimenting I notice....
For the sake of having a bit of free play (as near as I can tell 3mm worth at the spur) I get consistently a 45 second spin time.
Now if I move just one shim on the diff that free play almost goes completely to the point of being barely detectable (should make for better pick up right) but the spin time is consistently 40 seconds and makes a "god aweful" (comparatively speaking) noise you'd think the gearbox is going to strip itself.
So the question is sloppy and quiet or noisey and better pickup?
Mabuchi540 is offline   Reply With Quote
Old 02-14-2005, 06:23 PM   #12416
Send a message via AIM to Johnnytc3
40 secs?? I would shim it up!
Johnnytc3 is offline   Reply With Quote
Old 02-14-2005, 07:37 PM   #12417
Registered User
ritchie's Avatar
i'm not sure, but the diff is suppose to have one shim on each side, if you remove a shim from one side i think your suppose to put it on the other side. this may help,
and how are you getting this spin time, or how are you spinning the diff.
Old 02-14-2005, 07:44 PM   #12418
Default Re spin/shims.....
at the moment and for the sake of the run in I have/had 3 shims on the one side because when shimmed as per instructions the diff literally wouldn't move.
But now the shimming situation I mentioned is moving one of the 3 so that I have 2 on one side and one on the other.
As for the spinning that's spinning one tire as hard as I can and 9 out of 10 times I've had the wheels stop at the 45 second mark as mentioned and trying the 2/1 shimming option it's consistently 5 seconds less.
Will try it now with just the diff and its input shaft.....5 seconds with current shimming 2 seconds with the 2/1 option.
Old 02-14-2005, 10:21 PM   #12419
TexasRacer's Avatar
Send a message via AIM to TexasRacer
HAHA dang how fast are you counting?
TexasRacer is offline   Reply With Quote
Old 02-14-2005, 10:33 PM   #12420
Talking Very funny....
:P but actually I'm timing it with a watch.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
