Old 02-09-2005, 01:31 PM   #12331
Default Re: Camber link on C hub
Originally posted by adyb
Hi,
I'm running the new Rayspeed shock towers front and rear. On the front i have changed over the camber link position so it sits where the king pin used to be by using ball stud ZS-007F on the C hub. What I have heard is that when running this setup I need to change the king pin collar position, by removing the top one and move the bottom one so it sits in side the C hub and use the top hole where the C hub and wishbone are connected.
Does anyone know if this is right or can you use the original configuration and just change the king pin to the ball stud
Any Ideas
adyb is offline   Reply With Quote
Old 02-09-2005, 03:16 PM   #12332
Default Re: Re: Camber link on C hub
Any Ideas
Not sure why you would want to take the link out that far, you would need to use the eyelet style ball cup to help clear the inside of the wheel. Not sure you would need to put the hinge pin in the upper hole on the c-hub to help with clearance?
pops is offline   Reply With Quote
Old 02-09-2005, 04:46 PM   #12333
Francis M.'s Avatar
just saw this chasis in rczone. it looks interesting.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 02-09-2005, 04:47 PM   #12334
Francis M.'s Avatar
here another shot.
Old 02-09-2005, 05:25 PM   #12335
I am driving a Yokomo SDW with 27T Stock Motor and CS-27 tires.
The car runs great but i am looking for good tire inserts. Runtime in Germany is 7 minutes (on Carpet), so the tire overheat with the wrong insert.
Does anyone know a good tire Insert for carpet racing with CS-27 tires?
darulor is offline   Reply With Quote
Old 02-09-2005, 06:21 PM   #12336
Midnight's Avatar
Trader Rating: 85 (100%+)
IMO the HPI red is the best b/c it creates less air gap which I think lets you run longer before they heat up.
RC8T; Losi 2.0B; FT T4; AKA & RB
Hoffman Photography, www.carolinasrc.com
Midnight is offline   Reply With Quote
Old 02-09-2005, 06:48 PM   #12337
JayBee's Avatar
Trader Rating: 31 (100%+)
looks interest'n... dat's da bom diggety
- JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 02-09-2005, 07:25 PM   #12338
Registered User
ritchie's Avatar
i just ran carpet this past weekend with the sdw, with a stock motor 27t, and cs-27 PREMOUNTED tires, the only change i made was to lay the front shocks in one hole and the rear shocks up one hole, i had a ton of steering and the rear was planted, i raised the front of the body one hole on the body mounts to take away a little steering, i was using the yok "e" body. TQ and won BTW.
ritchie is offline   Reply With Quote
Old 02-09-2005, 07:38 PM   #12339
We are running Sorex A-Firms inserts, Sorex 28s in front and 24s in the rear. By far this combination seems the best. This insert fills the tire and is extreamly consistant. Tire overheating should not be much of a problem with this insert. I think Matt Howard was running some Xenon Blue inserts that also worked very well last carpet season. We used HPI reds but changed to the Sorex Firm A insert and lap times improved.
Old 02-09-2005, 07:48 PM   #12340
Midnight's Avatar
Pops are the sorex firm A close to the hpi reds. Im running take off 22 on yok wheels with HPI red inserts, and Im trying to find a combo in the sorex that is compareable.
I purchased some sorex 28 and put some HPI red inserts in on Yok wheels, I had to wrap the wheel three times to get the same air gap as the take off 22 I mounted. Do you think they will work. Im getting ready for a big off road race and havent had a chance to try them out.
Old 02-09-2005, 07:53 PM   #12341
JayBee's Avatar
Post
Damn ritchie, you're good
sounds like you had fun
- JB
Old 02-09-2005, 08:08 PM   #12342
What is the productno. for the red HPI's?
Old 02-09-2005, 08:46 PM   #12343
lem2's Avatar
Default Re: Weight
Originally posted by Al Williams
Lem2 - How much does it weigh, with batterys, shell and tyres. My CGM is almost an identical config, but I don't have a good set of scales .....
I think I went overboard!!! My CGM comes in at 1590gms with a dummy tronsponder. Pretty heavy!! But I guess acceptable with all those bling blings! To think I have all the Ti stuffs and lightweight parts! Oh well, maybe the Lieghtweight CGM will lower it down a bit and Ti shock mounting screws! Don't want to remove all those blue parts!!!
lem2 is offline   Reply With Quote
Old 02-09-2005, 09:27 PM   #12344
Matt Howard's Avatar
I ran Xenon grey's for club racing and Xenon Reds for the big races since the reds are slightly bigger.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 02-09-2005, 09:32 PM   #12345
Midnight's Avatar
I looked out in my box but I think I threw away the packaging. If you go to ebay and type in HPI red inserts they should pull up. You can also go to towerhobby to find them.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
