Old 02-07-2005, 02:02 AM   #12286
Wheelbase question.
Ok I know a shorter wheelbase will allow the car to turn tighter but what are the advantages/disadvantages to altering the wheelbase at the front versus changing it at the the back?
I know I've read it somewhere on here before but I can't find it.
Thanks in advance.
Mabuchi540 is offline   Reply With Quote
Old 02-07-2005, 02:35 AM   #12287
stinkypop's Avatar
Front- Further to the back increases steering ( more front grip)
Rear- Further to the back increases on power steering( less rear grip)
Visa versa.
stinkypop is offline   Reply With Quote
Old 02-07-2005, 03:12 PM   #12288
Default Camber link on C hub
Hi,
I'm running the new Rayspeed shock towers front and rear. On the front i have changed over the camber link position so it sits where the king pin used to be by using ball stud ZS-007F on the C hub. What I have heard is that when running this setup I need to change the king pin collar position, by removing the top one and move the bottom one so it sits in side the C hub and use the top hole where the C hub and wishbone are connected.
Does anyone know if this is right or can you use the original configuration and just change the king pin to the ball stud
adyb is offline   Reply With Quote
Old 02-07-2005, 04:08 PM   #12289
ATLAS COPCO's Avatar
Well done on sunday ady looking good with that cgm man
ATLAS COPCO is offline   Reply With Quote
Old 02-07-2005, 04:46 PM   #12290
Midnight's Avatar
Trader Rating: 85 (100%+)
I have the blue RS bladder in my cgm right now, but my wife bought me a new cgm that I have been putting together for two weeks now( buying parts from speedtech, and soaking bearings, and so on). Will the stock bladder react about the same or do I need to pull the blues out of my old car. My car was hooked before I stopped racing with it. Also what the diff between the yellow, blue, and white. I have a set of yellow,and white. Im running on a high bite concrete track. Thanks
PS I cant go any further in the building process untill I get this figured out
RC8T; Losi 2.0B; FT T4; AKA & RB
Hoffman Photography, www.carolinasrc.com
Midnight is offline   Reply With Quote
Old 02-07-2005, 05:47 PM   #12291
TexasRacer's Avatar
Send a message via AIM to TexasRacer
Where can I buy a Spool for the Yokomo SD?
Thanks!
Cody Gary
TexasRacer is offline   Reply With Quote
Old 02-07-2005, 05:57 PM   #12292
lem2's Avatar
Thanks!
Cody Gary
SPEEDTECHRC!!!! That's what I'm using.
or
You can do what Matt Howard suggested, making a spool out of the stock diff. Its in a couple of pages back.
lem2 is offline   Reply With Quote
Old 02-07-2005, 06:05 PM   #12293
TexasRacer's Avatar
I couldnt find one on SpeedTechRC and I also bought this car used and it only came with a one way .
Old 02-07-2005, 06:28 PM   #12294
You can also use the parts from a standard diff, buy the Losi Spool sandpaper pads, remove the diff balls and you got yourself a lightweight spool.
pops is offline   Reply With Quote
Old 02-07-2005, 06:32 PM   #12295
Truthfully, unless you are a pro driver, I don't think you will find much difference between the bladders. This is super fine tuning at the least. The stock Yokomo ones will work pretty much like the Rayspeed.
Old 02-07-2005, 07:51 PM   #12296
I also looked on Speedtech racing; the spool is out of stock. So when do you think yokomo will come out with a new car? I know they just released the SDW; however it was only manufactured in limited quantities.
kmorast is offline   Reply With Quote
Old 02-07-2005, 08:50 PM   #12297
Default never
get a xray
Chris
mtc3od is offline   Reply With Quote
Old 02-07-2005, 08:58 PM   #12298
well that only took, 12,297 posts
vanguard is offline   Reply With Quote
Old 02-07-2005, 09:35 PM   #12299
Chris, I see you've added your two cents. We'll see just how fast your x-ray is in three weeks.
Old 02-07-2005, 09:36 PM   #12300
Midnight's Avatar
Thanks pops!
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
