Old 05-09-2003, 04:23 PM   #1201
mo
mo's Avatar
I ran stock a couple weeks ago with a monster motor. I had it geared 6.85
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 05-09-2003, 07:43 PM   #1202
komkit's Avatar
Send a message via ICQ to komkit Send a message via AIM to komkit Send a message via Yahoo to komkit
Talking Took me 4 days, but got it done!!!
For some reason I just want to share this with you all SD owner or will be.
Done with servo rotated 90 deg. I guess it's time to let this animal goes wild.....
CFX Paintworks - The Track
komkit is offline   Reply With Quote
Old 05-09-2003, 10:55 PM   #1203
OSherman's Avatar
Default Re: Took me 4 days, but got it done!!!
Originally posted by komkit
....Done with servo rotated 90 deg....
the 90 deg rotation is intended to make more room on the main chassis for the electronics...drop that blue thing to the deck.
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 05-09-2003, 11:19 PM   #1204
rc-zombies's Avatar
Default Re: Re: Took me 4 days, but got it done!!!
komkit..
yes...definately put that receiver on the deck. I did the same mod..and you should have plenty of space to put all the electronics on the main deck.
Old 05-10-2003, 04:41 AM   #1205
komkit's Avatar
Ummm yes, I could do that. I could put the transponder on top of the servo where the RX is right now.. and move the RX down
Thanks guys,
Old 05-10-2003, 05:34 AM   #1206
komkit's Avatar
Default This should do it
I think this should be it. What do u guys thinks??
Old 05-10-2003, 07:30 AM   #1207
Default Re: This should do it
Did you glue your servo to your chassis?
elnitro is offline   Reply With Quote
Old 05-10-2003, 07:46 AM   #1208
IH
IH's Avatar
Default Rear transmission case prob
Hi,
I have got a problem with the rear transmission case. As soon as i tighten the two screws the drivetrain gets very sluggish..
Please help...
IH is offline   Reply With Quote
Old 05-10-2003, 07:50 AM   #1209
sosidge's Avatar
Check that the bevel gear is located fully on the shaft, and make sure your shims are in the right places. The Teacher had a similar problem, he may be able to say how he solved it. Mine is perfect when built as the kit suggests.
Old 05-10-2003, 11:37 AM   #1210
Regional Moderator
Darkseid's Avatar
Default Re: Chassis protective film
Originally posted by IH
Hi guys,
I am building my SD at the moment and I am wondering If I should use a chassis protective film. Although i seems to be very tricky cutting out all the holes and slots..
Has anyone of you used it?
IH
Yes, I used it on my car. And completely covered the bottom of the chassis. I wont lie to you, it take a bit of time, and you'll probably go through at least two new hobby blades while you do all that trimming. But its definitely worth the effort.
TLR 22...Tamiya F104...
Old 05-10-2003, 11:41 AM   #1211
OSherman's Avatar
Thumbs up Re: This should do it
beautiful...
•KO Propo America
•EXOTEK
Old 05-10-2003, 11:51 AM   #1212
Regional Moderator
Darkseid's Avatar
IH: here a look a the finished product. This was done using Associated's chassis film.
The best part is that there is very little reason to remove the screws in the chassis, so you probably wont have to cut out many of the screw holes.
Old 05-10-2003, 12:24 PM   #1213
IH
IH's Avatar
Hi Darkseid,
I did it like Mo suggested. I have only covered the front and the rear. Nevertheless I needed two blades....I have cut out all the
screw holes...
Old 05-10-2003, 08:32 PM   #1214
komkit's Avatar
Default Re: Re: This should do it
Yep, 3M tape and Shoe Goo around the servo.
heheheh Make me feel like running my YR-4M2 PRO again
I did it the same way. 4 years same tape same goo same servo.. Never had a problem.
Old 05-11-2003, 10:17 AM   #1215
Regional Moderator
Darkseid's Avatar
Its amazing what a new set of tires will do for you!
With a new set of pre-mounted Take Offs C22's and a small change in the piston/oil combination in the front and rear shocks, I now have a unbelievably excellent handling Yok SD!
The car felt slow, like I was driving in slow motion or something, but the lap times show fast!
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
