Old 01-30-2005, 05:50 PM   #12121
Default SDW
Some one has produced some lexan pieces that can on the outside of he gear box to keep thecrap out.
cos that price is pretty good!!
Xray T2 09 (still) - LRP - MuchMore - Futaba 3PK (still)
Bluey_74 is offline   Reply With Quote
Old 01-30-2005, 06:12 PM   #12122
Midnight's Avatar
Trader Rating: 85 (100%+)
Originally posted by Johnnytc3
LOL i thought about it but the exposed gears is a no no at my track
I second that! There is alot of tire rubber floating aroung my track also!
RC8T; Losi 2.0B; FT T4; AKA & RB
Hoffman Photography, www.carolinasrc.com
Midnight is offline   Reply With Quote
Old 01-30-2005, 09:16 PM   #12123
Registered User
ritchie's Avatar
Originally posted by Sparx
I have had some small glitches some time ago, i changed crystals and it has worked witout glitching, I tried 3 different recievers in about 3 different locations. 3 different ESC's and 2 different servos and around 5 different motors, only the transmitter left.
I will try to upload my setup in a couple of days. It's great on small slippery track with Sorex 28
no glitching today, moved the rec to the top of the top plate right behind the antenna, and put in a different sp control.
ritchie is offline   Reply With Quote
Old 01-30-2005, 09:20 PM   #12124
Registered User
ritchie's Avatar
hasn't been a problem and one of the tracks i run is not a prepared track, pretty much just a lot with plenty of pebbles, and taking your time, i can see how a cover could be made.
Old 01-30-2005, 10:07 PM   #12125
JayBee's Avatar
Trader Rating: 31 (100%+)
Angry MAN...
Nothing but problems @ practice today. Well, where do I start... was running the inline blocks and I actually like the extra amount of steering that it gives. But then... BAM and then two other BAM, BAM's ; I broke THREE inl. blocks. In the same spot on the lower kingpin and @ the same damn spot on the track. And my CVD is ever so slightly bent; this all happens on the right-side. Not only that but one of my servo mounts broke off and my rear shock tower screws that attach to the rear diff-case decided to strip out. Besides all of the repairing, I did get to try a few set-up changes that I like . So fellas that was my afternoon
Hey ritchie, that's why my stockpile is so huge
I do have a question about servos though, any of you guys using the Futaba 9550?
- JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-30-2005, 10:43 PM   #12126
lee82gx's Avatar
i'm using the S9550, what's your problem?
lee82gx is offline   Reply With Quote
Old 01-30-2005, 10:48 PM   #12127
JayBee's Avatar
Post
No problem, just want to get a couple. I like the size and i think it'll help out my electronic placement
How do you like yours, any downside to it?
- JB
Old 01-30-2005, 10:58 PM   #12128
JayBee's Avatar
Default Re: MAN...
- JB
Oh I forgot to mention, I cracked one of the new Acer ceramic bearings too
- JB
Old 01-31-2005, 03:07 AM   #12129
lee82gx's Avatar
- JB
There is no downside that I can think of. Some consider the slightly slower transit speed(0.12s) as a downside, but i find it just right because I usually have to tone down when i use 0.07-0.10s servos.
The smaller size allows me to fit virtually ANY ESC. I've fitted Novak BL+KO receivers all flat.
An excellent servo all round and I'm going to use this on all of my touring cars.
Old 01-31-2005, 04:32 AM   #12130
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
DITO
I have that servo in my SSG RS and in my Yok Mini. It is perfect in speed in my opinion. If you need sub .12 second transit time go elsewhere my friend but for the size, wieght and power nothing comes close. IMHO
Hope this helps Jaybee,
Sorry about the bad day, eeek broke a bearing.. ..sheesh that hurts.
Stephen <><
Check my last post it has a picture with the servo....LOTS OF BREATHIN' Room...LOL
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 01-31-2005, 05:59 AM   #12131
Unhappy Ok I'd buy one but not eight....
I have just opened my new Yokomo ceramic bearing set (SD-BBC). And sure enough they feel nice and free when I give them the "hold between two fingers and turn inner ring with finger from other hand test"...BUT
When I got to the wheel bearings all eight of them felt well lets just say rough. I'd buy maybe one of them being off but not 8, am I missing something about ceramics that would explain this?
Mabuchi540 is offline   Reply With Quote
Old 01-31-2005, 06:28 AM   #12132
Default Re: Ok I'd buy one but not eight....
Have you cleaned the super thick Lube from them?
It seems that every manufacturer of ceramics bearings sticks that thick lube in and it really doesn't allow free wheels type feel right away..It took my old TC3 about 6 packs before that thick stuff loosened up a bit...then I found out you can just bearign blast the thick stuff out and use thin bearing oil (I use Sin oil from Acer but Trinity Royal Oil is also good) to lube which allows super free feeling bearings, also I have done the Remove the inner seal from all the Diff bearings trick and that also improves the free wheeling feeling....WARNING if you don't take care of them i.e. cleaning and re-lubing then this trick and getting rid of the thick lube is not recommended. I clean my bearings after each race day and relube before storing and before each race day. Good habit even for cheap bearings. I also have the Yok bearings and they are starting to get a little worn so I in fact just purchased the Acer Bearing kit this morning, I was quite happy with the set that was in my old TC3. Plus I at least know the Bearing rating on the Acer's I couldn't find the rating for the Yok ones.
Hope this helps,
Stephen <><
Old 01-31-2005, 07:09 AM   #12133
Registered User
ritchie's Avatar
yokomo doesn't use the "super thick lube" >
just put them in your car and give it the old tire spin test. you'll be fine. i didn't clean mine, and my car felt excellent right off the bat.
yea yea i know, now your gonna ask about side loading and stuff, just put them in and enjoy
Old 01-31-2005, 08:54 AM   #12134
bigragu's Avatar
Default front ride height
thanks matt im going to put the rear shock tower on front i had one sitting in my box allreadyu done up just in case . thanks for all the help. later
bigragu is offline   Reply With Quote
Old 01-31-2005, 09:28 AM   #12135
One good way to check your wheel bearings is to put them on the tip of a standard pencil. Soak and clean them with motor spray, them spin them on a pencil. You will feel any roughness through the pencil. Be sure to re-lube them before you use them again.
pops is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
