Old 01-30-2005, 12:01 PM   #12106
Originally posted by Midnight
I like the tobee input shafts, some springs, type e stratus body, 64 pitch spur gears, and RS roll bar. This is the list I made to order from speedtech monday morning. Im still trying to figure out if I can use the tobee spring retainers with the RS springs. or do I have to use the RS retainers. The tobee are cheaper, and they are blue. As far as the body goes, I like the way it handles, I just dont like the wing that came with it. ( did anyone else have any luck with this wing)
Pretty sure the tobee spring retainers only fit the Yokomo Springs. The Ray Speed retainers are of a different shape to fit the spring and the longer length. Rayspeed retainers are blue too. The Stratus E works very well on a tight track, it has a lot of steering. We have the new Rayspeed Accord and will be trying it out next Saturday, it looks a little more neutral than the E.
pops is offline   Reply With Quote
Old 01-30-2005, 12:04 PM   #12107
Originally posted by Johnnytc3
Thanks,
you guys are the sh!t!!
Here is what im about to order:
CGM SPECIAL KIT
Aluminum screws
Spare Steering blocks
Spare hub carriers
Spare arms ( same front and rear!?)
Anything else this is essential or break prone?
Johnny
Throw out the diff balls that come with the kit and use the carbide ones you already have. The diff balls are steel and will last one race day at most. That will save you on diff rings.
Old 01-30-2005, 12:07 PM   #12108
Default Re: Re: Quick question.....
Originally posted by pops
Ray Speed #2 seem to be the closest.
#2? I see the part numbers listed as part# RS-11,12,13 etc?
Mabuchi540 is offline   Reply With Quote
Old 01-30-2005, 12:08 PM   #12109
Originally posted by rovic
you may need a spektrum.
let me guess, assuming you have an high quaility fm radio and hasnt been dropped. is it an airtronics? (joke)
no one can advice on that without actully seen your car/radio gear.
We have an Airtronics M-8 and was having problems with glitching on the SSG and Rayspeed, switched to 27band 18 months ago and haven't had any problems since.
Old 01-30-2005, 12:14 PM   #12110
Default Re: Re: Re: Quick question.....
RS-11 Blank (make your own holes)
RS-12 #1 (1.0mm hole x 2)
RS-12 #2 (1.1mm hole x 2)
RS-13 #3 (1.2mm hole x 3)
Old 01-30-2005, 12:20 PM   #12111
Yokomo makes aluminum input shafts (front and rear), I like the Square Ti input shafts, better than than the tobee IMO. The Rayspeed lower sway bar kit is much better than the kit sway-bar, this sway-bar really works better.
Old 01-30-2005, 12:22 PM   #12112
hey wassup guys, i haven posted here in a along time. i dont get it but y is a wide bumper recommended? im doing fine with mine. and i doubt it the rear arms broke on me 2 becuase of teh bumper.
does anyone here have a BL system in there black or ssg? if u do wat spur/ pinion gear do u recommend. wat will give me speed.
crzydrifter is offline   Reply With Quote
Old 01-30-2005, 12:30 PM   #12113
The wide bumper is to protect the front of your car, I doubt it will help the rear of the car? What is a BL system? (Brushless?) Motor with proper gearing will give you speed. Gearing is determined by the type of motor you are running (turns and wind).
Old 01-30-2005, 12:39 PM   #12114
Midnight's Avatar
Trader Rating: 85 (100%+)
Thanks pops, but what is the diff between the TI input shafts and the tobee?
RC8T; Losi 2.0B; FT T4; AKA & RB
Hoffman Photography, www.carolinasrc.com
Midnight is offline   Reply With Quote
Old 01-30-2005, 12:40 PM   #12115
Midnight's Avatar
Pops I forgot to ask do you like running the RS springs rather than the yokomo. If so why? And as far as that goes what about everyone else that has run both type of springs!
Old 01-30-2005, 03:46 PM   #12116
The Square Ti input shafts seem as light or maybe lighter, and stronger. I have seen the Tobee input shafts take a bend.
Old 01-30-2005, 03:50 PM   #12117
We have just used them as an additional tuning option. There is nothing wrong with the Yokomo springs as far as I can see. I've been told they are more progressive than the Yoke springs.
Old 01-30-2005, 04:19 PM   #12118
Send a message via AIM to Johnnytc3
I just called stormerhobbies to see if they had any cgms and they tried to sell me a worlds, 439.99 which isnt bad at all!!.
Johnny
Johnnytc3 is offline   Reply With Quote
Old 01-30-2005, 04:44 PM   #12119
Johnny
I would go for it...
Old 01-30-2005, 05:46 PM   #12120
LOL i thought about it but the exposed gears is a no no at my track
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
