Old 01-28-2005, 08:13 AM   #12061
Trader Rating: 35 (100%+)
Ok. Now that you mention it, I can see that they are from the sway bar kit. I do remember that my first Yokomo car YR-4MII had that type of open link, only I believe that the openings were larger, though. Or not!
BTW, the photo are of Chris Grainger's car (taken from the CML Distribution web site) http://www.cmldistribution.co.uk/art...id=69&type=CAR
Geppetto is offline   Reply With Quote
Old 01-28-2005, 08:14 AM   #12062
Matt Howard's Avatar
Originally posted by Mr. Shookie
hey Matt,
Thanks again for all your help last couple weeks has made a difference. Oh the ball cups, You got a part number?
Thanks,
Stephen <><
ZC-207A is the part #. I believe you only get two in a package but they're only $1 per package.
No problem with the help, it keeps me busy over hear. There's not a whole lot to do other than drink and act like an idiot.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 01-28-2005, 08:16 AM   #12063
The YR-4 cars did use a bigger open ended ball cup and heavy steel ball ends.
RCTech #361
Old 01-28-2005, 08:22 AM   #12064
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
What branch are you in?
I was active Navy for almost 6 yrs. Seen the whole world (or all that I wanted to see) in 4 years, now that is time well spent.
I am Medicaly Retarded oops Retired now. And only 29, well will be 30 a two months.
Thanks,
Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 01-28-2005, 08:27 AM   #12065
Thanks,
Stephen <><
Air Force, been in 10 years now. I've been to N.J., California, and now korea. I find out in May were I'm going after this.
RCTech #361
Old 01-28-2005, 08:41 AM   #12066
Hope you can get back to the US. Maybe if your lucky maybe Southern California. Stay far from Edwards unless you like desert and long drives to events. I live in Lancaster just south of Edwards. It takes 1&1/2 to two hours to So.Cal's about 45 mins to HotRods which is starting up Sedan racing next weekend. Jimmy Babcock bought HotRods and will host a Sedan series starting in April. So keep all that when looking at your next duty station.
Take Care & Hope Korea has treated you well.
Stephen <><
Old 01-28-2005, 11:36 AM   #12067
racer's Avatar
does anyone have a stock carpet setup with rubber for the SDW?
i'm new to setting up Yokomo cars, so any help would be appreciated.
Thanks in advance.
racer is offline   Reply With Quote
Old 01-28-2005, 02:35 PM   #12068
Midnight's Avatar
Trader Rating: 85 (100%+)
Okay I just purchased a new CGM, I running on a concrete, that has unbelieveable traction. The traction is almost like running on carpet just not as consistant. DO anyone have a good setup?
RC8T; Losi 2.0B; FT T4; AKA & RB
Hoffman Photography, www.carolinasrc.com
Midnight is offline   Reply With Quote
Old 01-28-2005, 04:46 PM   #12069
iamramos's Avatar
Matt- email me @: [email protected] email at work is down today
iamramos is offline   Reply With Quote
Old 01-28-2005, 07:23 PM   #12070
racex's Avatar
Red face
ok
racex is offline   Reply With Quote
Old 01-28-2005, 10:11 PM   #12071
lem2's Avatar
The Stock set up works pretty well. Just stand up the shock in front, maybe a thicker swaybar in front and trythe r+3 suspension mount at the back. And RS yellow or white all over.
lem2 is offline   Reply With Quote
Old 01-28-2005, 10:24 PM   #12072
Midnight's Avatar
WHat springs are compareable to those. I have the green, pink, orange! I forgot to mention that with the stock set up it would traction roll in every corner.
Old 01-28-2005, 10:44 PM   #12073
with the springs you have I would run orange in the front and green in the rear. Have you tried running harder tires and inserts to stop the traction rolling? Are you running the same tires as everyone else?
RCTech #361
Old 01-28-2005, 10:57 PM   #12074
Rob Phillips's Avatar
Originally posted by caveman
Midnight,
Losi comes with carbide diff balls, while yoks only use normal steel balls. Gets some carbide balls for your yok.
Who all makes them? Are each manufacturers diff balls different sized? I bought everything to make a couple of extra diffs except the balls.
Rob Phillips is offline   Reply With Quote
Old 01-28-2005, 11:29 PM   #12075
the yokomo diff balls are 3/32 and the thrust balls are 1/16. The diff balls are the same ones used in a losi or AE offroad diff. I'm not sure on the thrust balls since it's been awhile since I've built a diff from AE or Losi. You can use AE, Losi, or yokomo carbide diff balls and it will make your diff last alot longer between rebuilds, and even then you only need to replace or sand your rings.
RCTech #361
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
