Old 01-26-2005, 03:15 AM   #12016
rough512's Avatar
Default Re: Jaybee
Originally posted by lem2
Are the drive shafts and the cvd's included inthe unsprung weight, even if its rotating?
I think anything between the shock-tower-end of the shock body and hingepin of the arm can be considered as unsprung weight.
is this correct? or should that be anything between the lower shock end and the arm hingepin
and I was thinking that chassis balancing should only be done with the sprung weight because these are the only one involved in weight transfer. This idea has already been shot down in one of the "How to balance chassis weight" threads in the past.
I'd like to hear the opinions of the people in this thread please.
rough512 is offline   Reply With Quote
Old 01-26-2005, 05:40 AM   #12017
Hi and Hello
Question to the masses:
I just finished building my MR-4TC SD SSG and notice that the lower suspension arms (front and rear) appear high off the chassis.
Currently my shocks are set at 60 mm length with short ends, per instructions.
Is this normal? Almost impossible to adjust droop this way.
Thanks!
VRF201 is offline   Reply With Quote
Old 01-26-2005, 05:46 AM   #12018
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
The shocks need to be at least 62 or 63 mm long, i don't really remember exact.
I ran short ends in front and 63 mm and then long ends and about 64 mm in rear.
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Savx - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 01-26-2005, 05:56 AM   #12019
The instructions uses the upper holes on the front suspension C-hubs, while most people use the lower holes. 60-61mm is long enough if you use the upper holes, 62-63mm if you choose the lower holes. For the rear 60-61mm is fine if you run the original shock tower. If you use Rayspeed tower (old style), then you need 64-65mm long.
caveman is offline   Reply With Quote
Old 01-26-2005, 06:17 AM   #12020
A big thanks goes out to Sparx and caveman for the quick turn around on my post.
I'll look at the car when I get off work and make some changes.
Thanks again for the help!
VRF201 (Roy)
Old 01-26-2005, 07:47 AM   #12021
Hi,
Ive CGM since last week. Great car. I will see this weekend how it performs in race.
But Ive a question. Does anybody knows the products of SpeedRacing and NIKIs? rcmart.com carries them. They look good and the price is awesome. Are they good or sould I spend a few more dollars and buy the products from Rayspeed, Yokomo and Team Suzuki?
And does anyone can tell me the order number of this item?
http://www.ultratechcleaning.com/yok.../rs-27_450.jpg
Chris
speedy-932 is offline   Reply With Quote
Old 01-26-2005, 08:07 AM   #12022
lee82gx's Avatar
Originally posted by speedy-932
Hi,
I�ve CGM since last week. Great car. I will see this weekend how it performs in race.
But I�ve a question. Does anybody knows the products of SpeedRacing and NIKI�s? rcmart.com carries them. They look good and the price is awesome. Are they good or sould I spend a few more dollars and buy the products from Rayspeed, Yokomo and Team Suzuki?
Chris
I have a lot of NIki's stuff.
They are nice, but the motor mount requires some dremeling b4 it fits perfectly.
The rest of the stuff are great. Input shafts, center shaft.
I've seen the Speedracing steering knuckles, they appear too thin and looks likely to bend in a crash. Anyway, the graphite knuckles are better.
The rayspeed hub you attached are not for the CGM.(I think)
lee82gx is offline   Reply With Quote
Old 01-26-2005, 08:30 AM   #12023
Thanks for the answer. Sounds great. But what has to be dremeled? What does not fit?
Old 01-26-2005, 08:40 AM   #12024
lee82gx's Avatar
someone just asked me this question, i have taken pics !!
It's just a tiny bit of work, I no longer have the original shape to show b4 and after
Old 01-26-2005, 08:47 AM   #12025
forty6's Avatar
anybody interested I have a set of ss bodies (nip) in the for sale forum.
forty6 is offline   Reply With Quote
Old 01-26-2005, 09:14 AM   #12026
Regional Moderator
daniz24's Avatar
Originally posted by Midnight
Once again thanks Matt for your word of advice!!
I would also like to thank daniz24, my rear diff was real gritty, I havent rebuilt them in about 6 to 7 months. So I guess it is about time!!
No prob as you know, ball diff is one of the most important thing to take care on all EP cars....
daniz24 is offline   Reply With Quote
Old 01-26-2005, 02:16 PM   #12027
rovic's Avatar
thats a b4 rear hub(pn#rs27/rs28),rs28 has .5 toe in, it wount fit yok axles..
my 2cents on aluminum,i use it to de-tuning a twitchy car. example; running aluminum c-hubs and spindles will slow a over responsive front end. just like running your shocks upside down...
as anything, driving style plays a big part...
i also like to run my front diff tight; to the point of snaping the diff screw / rear diff about 2/3 to 1/2 the tightness of the front.
rovic is offline   Reply With Quote
Old 01-27-2005, 01:05 AM   #12028
Default Diff tightness
What's the theory behind diff tightness. What difference does it make running the front tighter than the rear for example ?
Al Williams is offline   Reply With Quote
Old 01-27-2005, 01:41 AM   #12029
Matt Howard's Avatar
You'll get a bit more onpower steering with a tight front diff but you'll lose a bit of offpower steering. In my experiences a tight rear diff never feels good on the track. Instead of tightening your front diff down try building your front diff with the yokomo diff grease for their nitro car diffs. It's a really thick silicone paste, I build my foam/carpet front diff with it instead of regular diff lube so I don't break a diff screw, it works really well in slowing down and thickening the diff action. The part # is CS-DGH, the retail price is only $4.50 for a tub of it.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 01-27-2005, 01:47 AM   #12030
beer_drinker's Avatar
I had to do that as well when I shortened the screw, except i didn't take that much off
beer_drinker is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
