Old 01-25-2005, 01:49 AM   #11986
Matt Howard's Avatar
Default Re: Question...
Originally posted by JayBee
hey Matt, when you press down on the front and rear shock towers so your car stays planted, how much 'movement' should your spur gear have? Probably a silly question, but I'm going throughout the car trying to find out where all the slop is to eliminate it...
- JB
I guess I'll have to put my car back together and try that out for ya. I'll get back to you on this.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 01-25-2005, 01:53 AM   #11987
Originally posted by Mabuchi540
Hi Matt, just wondering if when using shock length for setting droop assuming the same mounting positions are used (or does that even matter) does equal length f/r = equal droop?
I honestly don't know. Since the front and rear use different mounting holes on the arms and towers I don't think they'll match up but I've never tried it myself. The stock front tower's mounting holes are higher than the rear but we usually use a more inner mounting hole on the arm for the front as well.
RCTech #361
Old 01-25-2005, 02:05 AM   #11988
JayBee's Avatar
Trader Rating: 31 (100%+)
Thumbs up Re: Re: Question...
thanx Matt
- JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-25-2005, 02:37 AM   #11989
Regional Moderator
daniz24's Avatar
Have you tried the inline steering blocks? That should help out a bit
What is the part number? Thanks
daniz24 is offline   Reply With Quote
Old 01-25-2005, 03:45 AM   #11990
JayBee's Avatar
Arrow Inline Front Steering Blocks...
part #: SD-415SG
- JB
Old 01-25-2005, 04:04 AM   #11991
lem2's Avatar
Default Rebuilding!!!
Having an awesome time rebuilding my car!!
Excited to try out my new hudy set up black set up tools!
Half way through, here a picture!!
lem2 is offline   Reply With Quote
Old 01-25-2005, 04:12 AM   #11992
JayBee's Avatar
Post Nice Behind...
- JB
Old 01-25-2005, 05:40 AM   #11993
racer's Avatar
My front shocks are 62mm long using the short ends, my rear shocks are 67mm long with the long ends. Thats the total length with them being off the car.
btw, which car are you running? SD or the SDW?
and which position are your front "C" hubs mounted to the front amrs? upper or lower position?
Thanks again
racer is offline   Reply With Quote
Old 01-25-2005, 06:20 AM   #11994
Regional Moderator
daniz24's Avatar
Default Re: Inline Front Steering Blocks...
part #: SD-415SG
- JB
Oh thanks. Do you mean the non trailing steering block?
Old 01-25-2005, 10:19 AM   #11995
thats the one, the axel is inline with the king pin.
Dan Hughes is offline   Reply With Quote
Old 01-25-2005, 12:41 PM   #11996
JayBee's Avatar
Default Re: Re: Inline Front Steering Blocks...
In your original post didn't you say inline steering blocks... when you get the package, it's going to say Inline Front Steering Block (non-trailing type); and will have a 0 on them.
- JB
Old 01-25-2005, 12:46 PM   #11997
bigragu's Avatar
Default ride height
hey matt,
here a question for u on the front of my car using like 58mm
cut foam tires i have to crank all the way down on the shock collars to make ride height is this a comman thing or am i over looking something.i just cant seem to figure out why i got to crank all the way down on shock collars to make ride height or should i use the rear shock tower on the front will this correct the problem
thanks buddy
p.s if inyone else has run into this i would love the input
bigragu is offline   Reply With Quote
Old 01-25-2005, 01:32 PM   #11998
Lightbulb Well doh.....it can't be that simple surely....
The shock length off the car minus the shocks length at ride height is the droop amount in mm?
Yeah ok it was late and it just occured to me or the penny finally dropped as the saying goes.
Mabuchi540 is offline   Reply With Quote
Old 01-25-2005, 01:54 PM   #11999
Midnight's Avatar
Trader Rating: 85 (100%+)
Default Re: ride height
Originally posted by bigragu
hey matt,
thanks buddy
I had the same problem! It depends on where you mount the hub carrier, I mounted mine on the bottom hole so I had to crank the shock collars all the way down. Another guy mounted his in the top hole so his are barely down. Also what shock ends are u using?
RC8T; Losi 2.0B; FT T4; AKA & RB
Hoffman Photography, www.carolinasrc.com
Midnight is offline   Reply With Quote
Old 01-25-2005, 01:56 PM   #12000
Midnight's Avatar
Hey Matt, do you know what piston is compareable to the rayspeed 1.1, and what is the diff between running the front hub carrier in the top or bottom hole. Thanks in advance and also thanks to everyone who spoke their advice.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
