Old 01-22-2005, 04:44 PM   #11911
who here recommmends titanium screws for this car? i just ran the car abotu 6 times and my lower arm broke. lolz. and then i tried replacing it, gess wat happends, the screws that hold the steel pin, stripped. o was WTF?**&&^()#(*(^. but i did replace them but when i the replacement, that one also stripped.
so do u recommend ti screws? and if so, wat brand( just give me the ink =D)
crzydrifter is offline   Reply With Quote
Old 01-22-2005, 04:52 PM   #11912
SMcpot's Avatar
Trader Rating: 22 (100%+)
Smile
Thanks, Blake....I'll check 'em out.
SMcpot is offline   Reply With Quote
Old 01-22-2005, 04:53 PM   #11913
Regional Moderator
daniz24's Avatar
How about a full Ti screw set from Yokomo :
SD-TSS Titanium Screw Set for SSG/Black
SD-TSSM Titanium Screw Set for CGM
daniz24 is offline   Reply With Quote
Old 01-22-2005, 05:36 PM   #11914
tony montana's Avatar
Trader Rating: 66 (100%+)
Out of what springs I have would you run on carpet, yokomo orange, white, yellow or the stock sd springs.
K.C. Guy- TLR- Horrizon Hobby- Team Trinity- 92 zero designs- AKA
tony montana is offline   Reply With Quote
Old 01-22-2005, 05:44 PM   #11915
Blakesrc's Avatar
Send a message via AIM to Blakesrc
Tony,
rubber or foam tires? If you are running foam i would say that all of those are to soft fyi.
Blake
Blakesrc is offline   Reply With Quote
Old 01-22-2005, 07:14 PM   #11916
yeah I kind of figured that what do you recommend?
Old 01-22-2005, 07:15 PM   #11917
rc_bam226's Avatar
Yokomo and Square makes Ti screws that hold those hinge pins, check out www.speedtechrc.com
rc_bam226 is offline   Reply With Quote
Old 01-22-2005, 08:00 PM   #11918
Blakesrc's Avatar
Tony,
If you are running foams get ahold of a pair of associated purples for the front and associated coppers for the rear, that will be a good starting point. If you are going to run rubber tires pretty much any assphalt one way setup will work, i have a nice rubber tire setup i got from Pops on this board, you can email me if you would like a copy.
Blake
Old 01-22-2005, 08:47 PM   #11919
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
I have yet to hear anyone on this thread mention using Yokomo Batts; are they not any good? I know Masami uses them and Billy E. use to when he was with Yokomo, but what about you guys- anybody using 'em out there?
- JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-22-2005, 09:40 PM   #11920
Registered User
ritchie's Avatar
if your talking about the really small screws that go in the outer edge of the arm, little tip for ya, take your 2.5mm hex head driver and ream out the holes, makes it way easier to install and remove screw, the yokomo ti hinge pin screws are pretty cool, they have different style threads and are a snap to install and remove.
ritchie is offline   Reply With Quote
Old 01-22-2005, 09:56 PM   #11921
oing? wat about filing and CAed? wat are they? how and where do i do it.?
also isnt 7 the stock gearing? i just got my black and put the Bl in the setting that came in the bag. is it slow? i thought it was damn fast. can it go faster?
English
pops is offline   Reply With Quote
Old 01-22-2005, 10:00 PM   #11922
Matt Howard's Avatar
- JB
they sent me one pack to try when they first started selling them in the states and the pack I got was very good. It wasn't hand picked or anything since the boxes are completely sealed. I got an SG2 pack which had higher runtime but lower voltage (but cheaper) than the SG1 packs. The runtime on it was 444 at 1.167 and I got it in the spring so I don't know what kind of numbers they're getting right now.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 01-22-2005, 10:04 PM   #11923
If those are the only springs you have and you can't get anymore then run the oranges since they're the stiffest
RCTech #361
Old 01-23-2005, 12:28 AM   #11924
Post
- JB
You've got mail.
Mabuchi540 is offline   Reply With Quote
Old 01-23-2005, 01:49 AM   #11925
lem2's Avatar
Default Matt Howard
Regarding RS Rear Shock tower in front.
Did you place spacers on the ball studs? Because the turnbuckles are at an angle, will this affect performance?
For the rear did you add spacers also?
lem2 is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
