Old 01-22-2005, 12:53 PM   #11896
Originally posted by lee82gx
crzydrifter:
it looks like you haven't filed and CA'ed the carbon edges yet. Not a good thing to do.
I've had some great times with my Black SD, hope you also do. I ran it with the Novak BL too, geared between 6.5(too hot) to 7.0(too slow)
oing? wat about filing and CAed? wat are they? how and where do i do it.?
also isnt 7 the stock gearing? i just got my black and put the Bl in the setting that came in the bag. is it slow? i thought it was damn fast. can it go faster?
crzydrifter is offline   Reply With Quote
Old 01-22-2005, 02:06 PM   #11897
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
Originally posted by Matt Howard
There's racing but it's really cold and snowing here so I'll wait till the spring time to venture out to a track. I don't have a worlds setup for carpet but schreff should have something worked out by now.
Thanks but I don't think I'll see him until after the birds!
fpart is offline   Reply With Quote
Old 01-22-2005, 02:17 PM   #11898
Quick question....
What's the best way to remove (as much as possible) slop from CGM/SSG steering while still using standard ball ends?
It appears as if most of it is coming from the bell crank assembly.
Mabuchi540 is offline   Reply With Quote
Old 01-22-2005, 02:57 PM   #11899
Lonestar's Avatar
Default gritty diffs
Guys,
anybody has a "Trick" for having diffs that last more than 10 runs before becoming all crappy? I'm tired of rebuilding mine all the time... I heard about using Tam diff plates, any truth to this?
Thanks,
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 01-22-2005, 03:12 PM   #11900
Blakesrc's Avatar
Send a message via AIM to Blakesrc
Lonestar,
10 runs or 10 race days? Mine seem to stay pretty smooth for a really long time, at least 4 race days, sometimes more when i run stock only. Only thing that i do when i rebuild them is clean everything really well and i use one of my old long diff halves, put the diff rings on it one at a time and sand them lightly on some 600 grit sandpaper with water until the wear line from the diff balls is gone. Re-assemble them and they feel good as new.
Blake
P.S. i dont know if it makes any difference but i use MIP diff lube and associated black grease on the thrust assembly.
Blakesrc is offline   Reply With Quote
Old 01-22-2005, 03:16 PM   #11901
Matt Howard's Avatar
If you're not using carbide balls then you'll have to rebuild them every week or two. After I put the carbide balls in mine I go a month or so before I resand the rings, I've been using the same balls in my diff for almost the last year.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 01-22-2005, 03:47 PM   #11902
Lonestar's Avatar
Blake, Matt,
thanks for the feedback. No, I really mean 10 batts! I don't use carbide balls indeed (just normal ones) but I'd hope they'd still last a little longer! I use AE's black grease for thrust bearings and AE Stealth lube for the main balls, and in 10 runs or so my diffs are shot. And you can't reverse the diff rings, which would help I think... Anyways... guess I'll have to dump more cash in more hopups...
Q: do Xray's diffshave standard carbide balls? because they sure last a looooooong time with no rebuild...
Thanks for the tips, guys!
Paul
Old 01-22-2005, 03:50 PM   #11903
tony montana's Avatar
Trader Rating: 66 (100%+)
what color yokomo springs are 28lbs and 25lbs?
K.C. Guy- TLR- Horrizon Hobby- Team Trinity- 92 zero designs- AKA
tony montana is online now   Reply With Quote
Old 01-22-2005, 03:53 PM   #11904
SMcpot's Avatar
Trader Rating: 22 (100%+)
Smile
Sorry if this has been asked before, but where would I be able to find those washers that you use when you want to put a countersunk screw over a non-countersunk hole? Thinking about picking some up for the top deck of my SSG.
SMcpot is offline   Reply With Quote
Old 01-22-2005, 04:01 PM   #11905
I got hold of some ceramic diff balls and they are so smooth and they seem to have lasted ages too. A bit expensive but they are still round and the plates are in good condition.
Dan Hughes is offline   Reply With Quote
Old 01-22-2005, 04:01 PM   #11906
Blakesrc's Avatar
Tony,
I dont think that yokomo has a 28 lb spring, I believe HPI has some though which im planning on trying next time out at the carpet track. They dont really have a 25lb either, the grey is closer to 26 so an associated 25 spring will work fine. Here is a chart for ya..
http://www.schumacher.clara.net/springchart.htm
I have been running 25's in the back and 30's in the front with tossolini's modified roll center setup and the car works great but i think the 28 lb spring will really help the minor off power push im having.
Smcpot,
I think i got some of those washers in an associated aluminum screw kit fyi.
Blake
Old 01-22-2005, 04:10 PM   #11907
They're yokomo nitro car springs, I don't know the colors off hand.
RCTech #361
Old 01-22-2005, 04:16 PM   #11908
25lb is GT4 green, and its either GT4 red or brown for the 28lb spring.
Old 01-22-2005, 04:21 PM   #11909
My chart shows the GT4 Brown is 32.99 lb and the GT4 green is 23.20 lb. A good choice would be GT4 grey 26.55lb and the silver 23.87lb or Associated yellow 31.07 and purple 25.47.
kmorast is offline   Reply With Quote
Old 01-22-2005, 04:30 PM   #11910
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
I think I'm about ready to get myself some of those ceramic diff balls.
I just ordered some Acer ceramic bearings, anybody using those? I was looking at Boca ceramics, but those suckers are $195.00 for the SD!! WHOA!!
I was thinking, what do you guys think of ceramic thrust balls?
- JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
