Yokomo MR-4TC SD
here you go shookie...
a different look...
last look...
- JB
- JB
Matt Howard ...
do you have a complete set-up for your Rayspeed for carpet on
rubber?
- JB
rubber?
- JB
Originally posted by JayBee
Matt Howard ...
rubber?
- JB
Matt Howard ...
rubber?
- JB
RS Yellow spring, 45 wt oil with RS #2 pistons, shocks mounted second from outside on arm, third from inside on old style RS tower. Arms spaced all the way back, gold sway bar. Oneway used. 6 on droop gauge. Lower hole on front castor blocks with steering blocks spaced down.
Rear
RS yellow spring, 35 wt oil with RS #2 pistons, shocks mounted outside on arm, third from outside on old style RS tower. Arms spaced all the way back, silver sway bar. 4 on droop gauge.
Tires
Sorex 28 up front, 24 in rear with Xenon Grey inserts
That should be just about it.
Thanx Matt
[i]shocks mounted second from outside on arm,
That should be just about it. [/B]
- JB
matt, are the rs#2 pistons the white two hole or the black two hole, also on the rayspeed pistons, which way does the little groove go, up or down or does it matter. just rebuilt the shocks on the cgm to change from pavement to carpet, almost the same setup except for front sway bar. and only have one set of yellow rs springs. think it will work?? also running sorex 28's but all the way around and with 039f inserts, they stuck pretty good on pavement with the worlds so i hope they work on carpet, btw, most of the guys are using either the premounted takeoff 27's or the sorex 28's at the local carpet track.
jaybee, might be going to raincity sunday with the guys, you going? talk to you later, bedtime.
Yeah, I wanna go but might not be racing though, I'm short a couple things
- JB
- JB
Hey Matt. How is it going in S. Korea. Any racing over there? Do you have a worlds setup for carpet yet?
i forgot, sunday's practice day
- JB
- JB
I just picked up one of these cars and i was wondering if any one could give me a good set up for racing on carpet. if so the help would be awsome. thanks
looking for some carpet setups dont want to scroll through all these pages looking for some and can't find any one the web. Thanks in advance.
Sorry i didnt think to read the post before mine.
