Old 05-08-2003, 02:36 PM   #1171
rc-zombies's Avatar
Originally posted by utieh
who make this????
i don't really think it is very useful(it will make the car heavier), but it does really look cool!
It may make the car slightly heavier..but at least the bearings/diffs will stay in line. Look at the 'Cuda R2... it has aluminum bulkheads. I've seen that car run...
Old 05-08-2003, 02:40 PM   #1172
glide 1's Avatar
Default thanks for the links..
rc-zombies have a question? i've just finished assembling the kit and the drivetrain seems not as free as ide like it to be. Do you recommend running the car a few times? i'm already thinking of taking out shims, dremel etc.
Car looks sooooo gooood!!!!
glide 1 is offline   Reply With Quote
Old 05-08-2003, 02:48 PM   #1173
rc-zombies's Avatar
Default Re: thanks for the links..
yes..the car looks great!!!!
The only things I've done to my car is change all the bearings to Teflon sealed, Rayspeed O-rings & bladders, MIP CVD Front and rear. Everything is stock. I did lube the diff gears with Whitelightning. It's a dry self cleaning was lubricant that can be found at bike shops. I would send you some...but I don't have any relative going back there 'til Nov./Dec.
I broke the drivetrain in @ 5volts for about 30min. So far I haven't had any problems with the drivetrain.
Try flushing out your bearings and lube with lighter oil...
Old 05-08-2003, 04:00 PM   #1174
Default Re: Re: thanks for the links..
........... MIP CVD Front and rear........
rc-zombies,
What it the part # of the MIP CVD that will work with the SD?
Thanks.
elnitro is offline   Reply With Quote
Old 05-08-2003, 04:02 PM   #1175
rc-zombies's Avatar
Default Re: Re: Re: thanks for the links..
Originally posted by elnitro
rc-zombies,
Thanks.
same one that is used for the MR4TC fits perfectly.
See M.I.P site for part numbers...sorry I'm at work..don't have the part numbers handy.
Old 05-08-2003, 04:22 PM   #1176
Default Re: Re: Re: Re: thanks for the links..
Cool, thanks. I just don't want to waste $60 just to find out they don't fit.
Old 05-08-2003, 06:39 PM   #1177
komkit's Avatar
Send a message via ICQ to komkit Send a message via AIM to komkit Send a message via Yahoo to komkit
Originally posted by THeGame
You might need a little bit more then 5 deg of caster for carpet. Your just going to need alot of spare-parts...
Are you going to Frederick Sat ?
5 should be okay, I'll try it anyway.
I'm going to Hobby Hangar on Saturday.
How is your Yokomo coming?
Mine is DONE Well, just waiting for ESC.
CFX Paintworks - The Track
komkit is offline   Reply With Quote
Old 05-08-2003, 09:29 PM   #1178
glad to see another person who hardwires
Chris@WeaponR is offline   Reply With Quote
Old 05-08-2003, 11:06 PM   #1179
Default Stock
Does any one have this car in stock right now?
rfree02 is offline   Reply With Quote
Old 05-09-2003, 05:53 AM   #1180
komkit's Avatar
Compromising is no racing
Old 05-09-2003, 09:02 AM   #1181
johnbull's Avatar
Hi guys. Greetings from Malta.
Just a quickie. I'm charging some cells and off to try out the SD.
Just finished building. Everything fitted perfectly. Diffs are as smooth and free as anything. Lots smoother than all the TC3s I've built.
I turned the servo 90 drgrees. Used titanium screws everywhere. MR4 alloy drive shafts, and MR4 Special battery hold down fits straight on, keeps things cooler, and looks trick!
I've done quite a bit more but will tell you all about it later. Now I'm off to the track to see what it goes like. If it goes anything like it looks............................
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 05-09-2003, 09:19 AM   #1182
utieh's Avatar
John Bull,greetings from cloody Paris,
I really want to see some pics of ur car
did you drill a hole for the servo mod?
utieh is offline   Reply With Quote
Old 05-09-2003, 09:30 AM   #1183
komkit's Avatar
I am thinking of doing that as well.
I have been driving Yokomo YR-4M2 PRO for 4 years same car, same Servo and same Dubble Sided 3M tape with a little bit of a Shoe Goo around the edge of the Servo.. Never had a problem.
I probably would do the same with this one. That way I will have more room to play with the Electronics stuff.
I am getting rid of the original battery holder (strap) or whatever you called it... I'm going for st8 Strapping Tape, since on the chassis have the slots made from factory already.
I might have to make the slots just a tad bigger.
Old 05-09-2003, 01:09 PM   #1184
SpeedTech's Avatar
Hi Guys,
Yokomo has released the titanium screw kit and I think we should have them by monday. If I remember correctly, they are pretty cheap too for a complete set.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 05-09-2003, 01:42 PM   #1185
IH
IH's Avatar
Default Chassis protective film
Hi guys,
I am building my SD at the moment and I am wondering If I should use a chassis protective film. Although i seems to be very tricky cutting out all the holes and slots..
Has anyone of you used it?
IH
IH is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
