Old 01-17-2005, 12:16 PM   #11806
bigragu's Avatar
at this time im not runnin a rear sway bar ill try that im running the rear arms foward. i made a front sway bar out of piano wire just felt the ones yokomo has are to light do u think i should use one of the kit ones
bigragu is offline   Reply With Quote
Old 01-17-2005, 12:19 PM   #11807
Matt Howard's Avatar
try a silver bar in the rear first and go from there. They feel light but they make a big difference in the handling of the car.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 01-17-2005, 12:21 PM   #11808
bigragu's Avatar
ill do that brother thanks for all the help matt.
Old 01-17-2005, 03:28 PM   #11809
Originally posted by Matt Howard
Dan- try running your rear arms all the way back or try running a slightly softer rear spring and a silver sway bar.
Matt, im now running yoke orange springs on the rear and a silver sway bar also i moved the arms all the way to the back. The track is quite grippy and im just wondering if i should change the shock oil?
Dan Hughes is offline   Reply With Quote
Old 01-17-2005, 08:56 PM   #11810
Dan- it sounds like your dampening is pretty heavy. Try the 450 wt oil with the yok #2 pistons
RCTech #361
Old 01-17-2005, 09:06 PM   #11811
Originally posted by rovic
running 2 in the rear now, ran 1 but was lose in high speed switch backs type corners.
i guess i need the front more responsive,
anyone try 2 or 3degree castors / or
camber links that are used for a car that pushes (increase front roll and decrease rear?)
mat whats your complete set up...
www.yokomo.tk has a couple of my setups that I use as my "base" setups for either a spool or a oneway.
RCTech #361
Old 01-17-2005, 11:35 PM   #11812
beer_drinker's Avatar
9 times out of 10 I run the hingepin for the castor block in the lower hole and space the steering block in the down position.
What does changing the hingepin position in the castor block actually do?
beer_drinker is offline   Reply With Quote
Old 01-18-2005, 12:02 AM   #11813
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
I'm thoroughly confused about that one Matt ; and do you have any or know of anyone else's set-up sheets on the Rayspeed besides Adachi's? I'm not partial to track conditions, I just wanna gander at all that's out there?
Thanx-
JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-18-2005, 12:38 AM   #11814
Regional Moderator
daniz24's Avatar
Originally posted by lee82gx
why don't you use battery tape instead?
I weighed my CGM with novak BL and transponder minus bodyshell at 1600gm...very pissed after all the aluminium and titanium i put in...
What servo are you using? I believe KO's is heavier than Sanwa's. Dunno about Futaba...
daniz24 is offline   Reply With Quote
Old 01-18-2005, 12:48 AM   #11815
lee82gx's Avatar
I'm using Futaba S9550...supposed to be one of the lightest for 1/10TC
lee82gx is offline   Reply With Quote
Old 01-18-2005, 01:58 AM   #11816
Thanx-
JB
Im sure he's talking about the spacer in between the steering knuckle and the c-hub. In the kit instructions the spacer goes below the knuckle, therefore the knuckle is in the upper position, you put the spacer above the knuckle and it puts the knuckle in the lower position. If you already knew that however, I'm sorry I can't help you any further, I only know what it feels like on the track, not what it actually does with the geometry.
Trevor is offline   Reply With Quote
Old 01-18-2005, 06:40 AM   #11817
ali_g's Avatar
any RS users using the new RS shocktowers??
any setup tips??
☆ JU.C RACING ☆
https://www.facebook.com/Ju.Cracing
ali_g is offline   Reply With Quote
Old 01-18-2005, 07:01 AM   #11818
Registered User
ritchie's Avatar
jaybee, look at the direction book for the ssg. the steering knuckle goes in the lower position,, now look at the directions for the sdw, the steering knuckle goes in the upper position. think of it as, which ever side of the c-hub, (top or bottom) the king pin spacer is on thats the knuckle position
ritchie is offline   Reply With Quote
Old 01-18-2005, 07:45 AM   #11819
JayBee's Avatar
Post
thanx Trevor & ritchie
- JB
Old 01-18-2005, 09:06 AM   #11820
If you run the hingepin for the castor block in the upper position and space the steering block up then it will lower the front roll center and will give you more steering. I usually don't like this setup but I'm working on a setup with this that suits my driving style
RCTech #361
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
