Old 01-09-2005, 06:11 AM   #11626
STLNLST's Avatar
Trader Rating: 21 (100%+)
Matt- 12th scale is a blast.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-09-2005, 11:56 AM   #11627
What ever blows your skirt up!
pops is offline   Reply With Quote
Old 01-09-2005, 11:59 AM   #11628
Here is a good one for you lot. Running a SD worlds today indoors with a spool changed front drive shafts to the standard steel ones and in 3 mins of running i had sheered both pins that go in to the axle and also did one of the pins on the bone that goes in to the out drive on the spool, the wear on the pins was stupid. Can anyone help i was thinking that it was dodgy drive shafts. I was only running a 19t so nothing stupid.
Slick990 is offline   Reply With Quote
Old 01-09-2005, 01:47 PM   #11629
wel if i get that deal, il save alot of money and i will not be spending as much for the other hop-ups. im reallyh oping he can hold the car for me.
crzydrifter is offline   Reply With Quote
Old 01-09-2005, 02:29 PM   #11630
As discussed on this board many times, the Yokomo hardened universal shafts will hold up much better than about any other drive shafts out there. You need to grind down the front ball of each shaft a little to fit the front diff. Running a spool is also much harder on the shafts than a diff or one-way.
Old 01-09-2005, 02:29 PM   #11631
Angry Well with the CGM every little bit of space helps.....
Anyone else bugged by that little moulding bump in the center of the chassis that intrudes into the area set aside for the radio gear (it takes up about 5mm of space), Then theres the slightly angled chassis side or the rib in the chassis just in front of the motor (a real pain if running 540 stock with their longer than mod/pro stocks cans).
I saw a pic on here a while ago of an after market tub chassis for the CGM/SSG anyone know who makes it?
Mabuchi540 is offline   Reply With Quote
Old 01-09-2005, 02:30 PM   #11632
Guess I shouldn't have got the Tobee dogbones then.
Old 01-09-2005, 02:35 PM   #11633
SpeedTech's Avatar
The Tobees are fine I run them on the rear universal of my SDW
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 01-09-2005, 02:39 PM   #11634
Default Yeah but....
Steve Wang
I got them for the front as well (haven't used them yet).
Old 01-09-2005, 02:46 PM   #11635
Default Re: Yeah but....
The Tobee ones are fine, but if your running something other than stock, especially with a spool, they are a little too light. I think you will be fine with a 540 motor.
Old 01-09-2005, 03:41 PM   #11636
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Man, this sucks totally. Managed to get to a track today and test some more things, bodys for example. Rayspeed Accord (Ride?) must be the best body i've driven this year, just a little less steering than the Mazda.
The totally bad thing is i manged to bend my YMP rear-shaft, not the shaft but the wheelaxle, canät remember i hit something either, so. Anyone know where i can find new YMP shafts?
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Savöx - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 01-09-2005, 03:43 PM   #11637
I don't think spares are quite well available yet. Ask Steve if he has got some coming in.
Dan Hughes is offline   Reply With Quote
Old 01-09-2005, 08:28 PM   #11638
Registered User
ritchie's Avatar
i ran the tobee's front and rear at nationals in portland with no problem, but when i raced at the home track with a one way or spool i snapped three of them before switching back to the stock ones. running a m-540 motor i see no problem with them breaking. going to run the tobees with steel axles in the rear and stock or mips in the front of the worlds.
anyone have or know of where i can find the old alum battery brace that came with the mr4tc special.
ritchie is offline   Reply With Quote
Old 01-09-2005, 08:29 PM   #11639
Matt Howard's Avatar
Yokomo USA should have SDW parts sometime this week so speedtech should have at least some parts this week as well.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 01-10-2005, 12:48 AM   #11640
Matt:
Can you suggest some tyre inserts for a low-med grip track?
What do you think of the Yok-037M / Sorex "C" Medium?
SNAIL MAN is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
