Old 01-06-2005, 08:10 PM   #11566
lem2's Avatar
Originally posted by joelt
LEM2 - I believe PITSHOP has the part you need in stock. . . . Had to buy that same item (together with all the other parts that came with the 'tree') when I lost one of my shock tower mounting thingies a few months back.
Just called the shop but not available hopefully the stuff will arrive this evening along with my RS rear towers! See you soon!
Has anyone here tried using the SQUARE mounting brackets for a small fan on the CGM? Could you please be kind enough tpo post a picture? Thanks..... Lem
lem2 is offline   Reply With Quote
Old 01-06-2005, 08:48 PM   #11567
tornado
Guest
Posts: n/a
You could use the AE ones. I'm using it.
Old 01-07-2005, 01:48 AM   #11568
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
I need a rare SDW for my stable can tou post links to who might have one.
cheers in advance
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 01-07-2005, 02:10 AM   #11569
NSR
NSR's Avatar
Can anyone give me a setup recommendation for SSG base on the new version of the RS shock tower.
Any input appreciate.
NSR is offline   Reply With Quote
Old 01-07-2005, 06:05 AM   #11570
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Originally posted by B&O
what kind of bearings does WCSD comes with??? Are they the zero friction bearing with gold seal or just the plain old bearings???
SDW comes Yokomo Ceramic bearings, plain metal shield. They sure spin smooth, just need to se how long they last with another bearinglube. The original was pretty "greasy"
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 01-07-2005, 09:31 AM   #11571
Registered User
ritchie's Avatar
the exploded view in the back of the instruction manual has all the parts listed with part numbers,
the sdw comes with part number BB-1060P which would be the "SUPER PRECISON BEARING"
off the yokomo site they list the ceramic bearing as BB-106C
the standard bearing is BB-106
and just for info sake, they have a teflon bearing BB-106T
these were all numbers for the axle bearings. 6x10. some had a 2 or a 4 after them for 2 pack or 4 pack.
but with all that said, they also list the part number for the diff gears as the standard plastic gear. and i swear mine look more like the graphite gears then the plastic ones.
and having just pulled ceramic bearing out of a cgm for the sdw and putting the sdw bearings in the cgm i can tell you the sdw is free-er rolling.
so i guess what i;m saying is
ritchie is offline   Reply With Quote
Old 01-07-2005, 10:53 AM   #11572
ATLAS COPCO's Avatar
cheers in advance
lol
ATLAS COPCO is offline   Reply With Quote
Old 01-07-2005, 11:29 AM   #11573
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
www.ultimatehobbies.com has the SDW for sale still in stock.
As of this morning when I checked.
HTH
Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 01-07-2005, 12:08 PM   #11574
rc_bam226's Avatar
Also, www.allspeedhobbies.com still has one left also.
rc_bam226 is offline   Reply With Quote
Old 01-07-2005, 04:55 PM   #11575
just took a new pic on my SDW.
Only need to finish the cable-routing and mount a servo/transponder mount that should be on its way from Rainbow Ten in a couple of days
Old 01-07-2005, 04:58 PM   #11576
bah, got problems with upload.. i'll try again
Old 01-07-2005, 06:02 PM   #11577
lee82gx's Avatar
quick question:
I'm running Yokomo springs.
Front:
Green springs
5mm ride height
silver roll bar
6.5mm droop
Rear:
Yellow springs
5mm ride height
copper bar
5mm droop
Since the green springs are much stiffer than yellow, why is it that on the car, the rear end is WAY stiffer(ie harder to compress downwards) than the front(which feels very lame)? Is this normal?
I'm asking because i too much front traction off power, the car is fishtailing on a lot of corners. But the turn in as very good since i've switched from front Orange(which was nice, but has less turn in).
lee82gx is offline   Reply With Quote
Old 01-07-2005, 06:29 PM   #11578
Which is better for SD?
Yokomo Type E Stratus or Protof. Mazda 6?
MARKANO is offline   Reply With Quote
Old 01-07-2005, 06:33 PM   #11579
RaySpeed #2 piston fromthe standard Rayspeed setup sheet.
What is the part no.?? Is it the white piston with 2 holes in it?
Old 01-07-2005, 07:25 PM   #11580
Default Shock mounting angle perhaps.....
Originally posted by lee82gx
quick question:
Front:
Green springs
5mm ride height
silver roll bar
6.5mm droop
Rear:
Yellow springs
5mm ride height
copper bar
5mm droop
I only have the kit springs on at the moment but ever since I changed the front shocks to the top most hole (giving a more upright shock) I've noticed the front feels softer though technically it can't be.
Perhaps this is the case for you, just a thought.
Additional: Speaking of springs, I have a pair of the green springs coming from speedtech (these will be the only non-kit springs I have) and I have a question of my own.
All I remember from the 4wd off-road days is that if I have the stiffer springs up front (kit rear) I'll have less steering and if I put them on the rear (kit front) I'll have more. What I'd like to know from a on-road stand point is what could I expect to see if I did the same thing but more with regards this on-power off-power stuff?
I'm running twin diffs if this helps.
Thanks in advance.
Mabuchi540 is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
