Old 01-06-2005, 08:43 AM   #11551
lem2's Avatar
Originally posted by Mr. Shookie
Just a shot in the dark here,
Does anyone have a setup for So.Cal. for the Rayspeed upgrade.
I went there two weeks ago and could not find a good combo,
I am running Yokomo dish rims with super thin Yok insert on Sorex 36Rs and have two bodys, Alfa2 and Nemisis. Any help would be appreciated as I am hoping to make a few more trips down to So.Cal. this year.
Thanks in advance,
Stephen <><
You could try chaning the tires to Sorex 28's.
lem2 is offline   Reply With Quote
Old 01-06-2005, 10:20 AM   #11552
SpeedTech's Avatar
Sorex 28R might be too soft for SoCal, and because of the incredible amount of traction, they will actually overheat 2 1/2 minutes into the race. Which is why guys are still run 36R (or 32R at the softest) even during winter time
Stephen, if you're gonna be out there on Saturday, I'll be out there as well, and we can reference each other's setup
lem2,
the YS-7-1 is available separately, and each part tree will have 2 of the triangluar piece you're looking for
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 01-06-2005, 10:41 AM   #11553
Matt Howard's Avatar
Originally posted by Al Williams
B&O - thanks I might give that a try ......
I am thinking of running in the transmission tonight. I was going to hook it up to an old stock motor and run about 4Volts through it for a few hours. Does this sound o.k. ?
that's fine, your gears should be nice and broken in after that.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 01-06-2005, 10:43 AM   #11554
I'm rebuilding the shocks of my spare car.
Its too bad that it was made using the triangular things with a bigger diameter!!!
He used the C part instead of the D part
Can I order those things separately? (YS-7-1)
or
Can I rebuild the shock without the triangular things?
Has anyone tried it?
I used my shocks without the triangle piece before and it works fine but the O rings will get worn out quicker since the shock shaft will be able to move a bit on the bottom. You should be able to order the shock plastic pieces seperatly with no problem.
RCTech #361
Old 01-06-2005, 12:03 PM   #11555
Quick check......
So I've got a home made setting board now (brothers a tool maker by trade) and can more accurately determine droop and ride height.
So I have ride height 4.5mm in front and 5mm rear and droop is 4mm in front and 3mm rear. Good starting figures?
Mabuchi540 is offline   Reply With Quote
Old 01-06-2005, 12:54 PM   #11556
iamramos's Avatar
4-3 droop is what I generally use on low-bite asphalt. It helps the car scavange some traction thru the corners. I generally run 6-5 as a starting point. If the car transitions to quickly, then I would lower arms.
iamramos is offline   Reply With Quote
Old 01-06-2005, 03:57 PM   #11557
beer_drinker's Avatar
If you have a smaller number on the droop gauge, would that give you better traction at that end of the car?
beer_drinker is offline   Reply With Quote
Old 01-06-2005, 04:12 PM   #11558
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Well, first tracktest on carpet with my SDW, lowered my best laptime at Eskilstuna with about 0.3 seconds, about 1 lap faster in 5 minutes than both my SSG and CGM-cars, pretty awsome.
The SDW is great, much quicker in chicanes and fast corners. Standard setup worked pretty well but i changed to Yok Green springs all around (tractionrolled with softer springs ) lowered the rear inner camberlink, 1 mm of Kick-up and set downstop to 5 in front and 4 in rear. I also mounted the shocks on the outermost shocktower holes in front and rear.
Now i'm really looking forward to DHI Cup, just needs to paint some bodies (boring), Rayspeed Accord (same as Ride Accord? Looks like that to me..) and Yok Stratus E
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 01-06-2005, 04:31 PM   #11559
racer's Avatar
Sparx,
are you running rubber or foam?
racer is offline   Reply With Quote
Old 01-06-2005, 04:52 PM   #11560
lem2's Avatar
lem2,
Steve Wang
Thanks Steve!! Sorry about the sorex, cause its always cold there that's why I thought it will be beneficial to use a softer tire. Anyways, id'nt run just watch when I was there.
Peace and Happy Racing!!
Old 01-06-2005, 05:45 PM   #11561
joelt's Avatar
Send a message via Yahoo to joelt
LEM2 - I believe PITSHOP has the part you need in stock. . . . Had to buy that same item (together with all the other parts that came with the 'tree') when I lost one of my shock tower mounting thingies a few months back.
SPARX - Glad to hear that you've already had the chance to put down SDW. Have to wait until tomorrow in my case, because of this other thing I have to do to support my hobby (work ).
With the modifications you have or are carrying out, can you say that you're essentially going towards the same setup as what you have with your SSG or CGM?
joelt is offline   Reply With Quote
Old 01-06-2005, 05:49 PM   #11562
Originally posted by racer
Sparx,
Ahh, forgot to say what tires
Sorex 28R's rubber, Tried CS22's too but they went trash because of whacked camber angles...
Old 01-06-2005, 05:51 PM   #11563
Not very much like my CGM, stiffer suspension and different wheelbase and such, so not that close. But my CGM was totally crap the last times i ran it...
*edit*
btw, how the hell do you quote two messages in the same reply in a good way?
Old 01-06-2005, 06:36 PM   #11564
B&O
B&O's Avatar
what kind of bearings does WCSD comes with??? Are they the zero friction bearing with gold seal or just the plain old bearings???
B&O is offline   Reply With Quote
Old 01-06-2005, 08:01 PM   #11565
Registered User
ritchie's Avatar
question, i can't tell if the diff gears are graphite or not. they look more like the graphite gears then the plastic ones but the part number is for the standard gear set, anyone know for sure?
ritchie is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
