Old 01-05-2005, 09:45 PM   #11536
PomAbroad's Avatar
Send a message via Yahoo to PomAbroad
Post Difference between SS and SSS shocks
Hi, I have purchased an seconf hand CGM with no manual. I downloaded a setup sheet to document it's current setup before i begin to make any changes. What is the difference between them, and how do i tell which i have got?
PomAbroad is offline   Reply With Quote
Old 01-05-2005, 10:02 PM   #11537
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
the original shocks (SSS) are short body shocks......
the SS are optional long body shocks.....
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 01-05-2005, 10:05 PM   #11538
PomAbroad's Avatar
Thanks, how do i tell which mine are, what length are the SSS shocks
Old 01-05-2005, 10:05 PM   #11539
JayBee's Avatar
Trader Rating: 31 (100%+)
Post Re: Difference between SS and SSS shocks
The difference is in the length of the shock body; the SSS's are the shortys and the SS's are longys. Not quite sure on the actual difference in length but the difference is very noticeable. HTH
- Jaybee
Oops, too late ...
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-05-2005, 10:45 PM   #11540
Default Re: Difference between SS and SSS shocks
The SS shocks were used for the GT-4 nitro car. The Rayspeed version recomended those longer shocks, because of the higher shock towers. Most people would not use the SS shocks on the MR-4TC (all versions), so the more than likely they are SSS shocks. I measured them on a car and the body (bottom of the cap to the bottom of the shock body) SSS is 20.3mm and SS is 23.3mm.
pops is offline   Reply With Quote
Old 01-05-2005, 10:51 PM   #11541
JayBee's Avatar
Post
Hey pops,
Is there a part number for the 'black caps' with the bleed screws that went on the GT-4 shocks? Also do you know if they're available seperately?
- jaybee
Old 01-05-2005, 11:05 PM   #11542
Originally posted by JayBee
Hey pops,
- jaybee
Yes, they are the same as used on the older MR-4 cars too. Part #YS-8Y Shock End Caps. I believe there are 2 caps in each pack. $3.00 per pack.
Old 01-05-2005, 11:35 PM   #11543
Registered User
ritchie's Avatar
jaybee, called you back, but got machine. chassis is built, minus arms. had to strip the cgm for the bearings, no dust collector for me i'm gonna use it. talk to you later, bed time.
ritchie is offline   Reply With Quote
Old 01-05-2005, 11:50 PM   #11544
JayBee's Avatar
Post
Yeah I missed your call; we'll talk later...
- jaybee
Old 01-06-2005, 12:14 AM   #11545
PomAbroad's Avatar
Thanks pops, you've been very helpful.
Old 01-06-2005, 12:56 AM   #11546
Hello,
Almost finished building my SDW, and have to say I am very impressed.
A couple of questions though.
When building the shocks, and following the manual, I was left over with 4 black "o" rings - I presume these are bump stops that go on the shock shaft.
I used a shaft length of 62mm, but the springs were still preloaded. Should I extend them further ? - Did you use the shorter\longer shock ending ?
Does anybody use the optional body post position for the rear ? - what the benifit of this over mounting them on the shock tower ?
Al Williams is offline   Reply With Quote
Old 01-06-2005, 02:47 AM   #11547
B&O
B&O's Avatar
You can use extend the length of SSS shock by cutting the bottom parts of the triangular shape(where the part that supposed put the sponge thing in the middle in the old shock). You should be long enough...
B&O is offline   Reply With Quote
Old 01-06-2005, 04:52 AM   #11548
B&O - thanks I might give that a try ......
I am thinking of running in the transmission tonight. I was going to hook it up to an old stock motor and run about 4Volts through it for a few hours. Does this sound o.k. ?
Old 01-06-2005, 06:47 AM   #11549
lem2's Avatar
I'm rebuilding the shocks of my spare car.
Its too bad that it was made using the triangular things with a bigger diameter!!!
He used the C part instead of the D part
Can I order those things separately? (YS-7-1)
or
Can I rebuild the shock without the triangular things?
Has anyone tried it?
lem2 is offline   Reply With Quote
Old 01-06-2005, 08:34 AM   #11550
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Just a shot in the dark here,
Does anyone have a setup for So.Cal. for the Rayspeed upgrade.
I went there two weeks ago and could not find a good combo,
I am running Yokomo dish rims with super thin Yok insert on Sorex 36Rs and have two bodys, Alfa2 and Nemisis. Any help would be appreciated as I am hoping to make a few more trips down to So.Cal. this year.
Thanks in advance,
Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
