Old 01-04-2005, 04:22 AM   #11506
beer_drinker's Avatar
Originally posted by JayBee
a little snip here, a little tuck there... a more recent pic...
- jaybee
Does that ESC have a digital display on it? I haven't seen one of those before.
beer_drinker is offline   Reply With Quote
Old 01-04-2005, 07:02 AM   #11507
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Originally posted by Trevor
I'm still waiting too. You're not the only one
Just recieved words from the distributor the cars is in, i'll receive mine tomorrw if the postal service does'nt screw up (which is awfully common)
Any one know any important things i should look after in the building process? I'll search through the previous pages and see what all have been writing
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 01-04-2005, 07:22 AM   #11508
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
yes it does
jaybee
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-04-2005, 07:38 AM   #11509
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
yes it does
jaybee
Isn't that the keyence?
It says Hello to you (how cool is that)
I just started using a GM SX12 in my Rayspeed and WOW is all I will say. I had the QC2 before and now it is going into my B4 when it arrives.
They SX12 has a great little function when used with the GM Commander which allows me to turn up or down the amount of amps which is great for tuning in for Stock then 19T or Hot Mods.
I love this ESC so far. I will have to see how well it handles the rigors of a true race weekend, since I have been rained out the last two weekends I hope my track will have races this weekend.
I know that HotRod Hobbies in Sagus is going to raing TC on Saturdays starting next month which is great for me cause my local track only runs on Sudays and let just say Sundays are a busy day for me already.
I still love my Rayspeed & I am not quite ready for such a master peice of the SDW so I will jsut wait till the Rayspeed II comes out next month and give that a try besides it is much mor ewithin my budget. LOL $460 compaired to $130ish I will take the Rayspeed for sure.
Take Care All & GOD Bless
Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 01-04-2005, 11:18 AM   #11510
racer's Avatar
does the SDW have holes drilled out for the third-middle deck?
Thanks!
racer is offline   Reply With Quote
Old 01-04-2005, 01:12 PM   #11511
Originally posted by kmorast
How is the Rayspeed chassis on carpet? Is it stiff enough?
i tired the ssg on carpet with cs22s and found it to flexy and tried the cgm on carpet bu found it to stiff (with cs22 tyres would be better with foams)
do you think that the rayspeed is stiff enough? with cs22 tyres?
agower is offline   Reply With Quote
Old 01-04-2005, 01:52 PM   #11512
Trader Rating: 60 (100%+)
I got the ssg right and i got it setup like the "standard Diff Setup" that comes with the kit..I got that bad ass hudy setup system (the gajillion dollar one) and the nose of the chassis hits the board..why and how?? The setup calls for 1* front suspension mounts and 2 degree rear toe in...where do you get teh 1* front mounts in aluminum? I found the stuff on speedtech but they dont have the 1*...where else do they have the al ones?
Or is there a better setup i should look at? Its primarily gonna be on asphalt. Should i get a front one way too?
PROMODVETTE is offline   Reply With Quote
Old 01-04-2005, 02:30 PM   #11513
iamramos's Avatar
The stock plastic front mount is a 1deg mount. I believe that Yokomo only sells the aluminum mount in 0deg so you will have to shim it to get the one deg of kickup.
iamramos is offline   Reply With Quote
Old 01-04-2005, 02:33 PM   #11514
iamramos's Avatar
The stock plastic front mount is a 1deg mount. I believe that Yokomo only sells the aluminum mount in 0deg so you will have to shim it to get the one deg of kickup. A oneway is always a must. If your front chassis is hitting the board, you may want to check your shock lengths and droop screws
Old 01-04-2005, 02:54 PM   #11515
ok...when it says 62 or64mm..is that the total length..from top to bottom or what? I dont know because im like 1/4 inch from that!
Old 01-04-2005, 03:08 PM   #11516
lee82gx's Avatar
yes, top to bottom, fully extended. go for 62mm first.
lee82gx is offline   Reply With Quote
Old 01-04-2005, 05:47 PM   #11517
joelt's Avatar
Send a message via Yahoo to joelt
SPARX - Pay close attention to the trimming you'll have to do for the arms and the hole enlargement of the C hubs. Go for 62 to 64mm at once for the shock lengths, using the tips some of the guys have shared. And, oh yes, be prepared to cut an ear off the servo you'll be using.
RACER - No holes for the middle deck on the SDW. . . . Barely enough room as the drive shaft sits much lower compared to a Black or SSG special.
Cheers,
JOELT
joelt is offline   Reply With Quote
Old 01-04-2005, 09:41 PM   #11518
do i take the trialgle thing out of the shock that i installed earlier or just adjust the length buy the end?
Old 01-04-2005, 09:44 PM   #11519
Matt Howard's Avatar
don't take the whole triangle piece out, just cut the tube piece so your shock can extend longer. I cut my tube all the way off, others cut it in half, but you still need the triangle piece installed or the shock shaft will be able to move around the O ring and cause excessive O ring wear.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 01-05-2005, 04:48 AM   #11520
Cheers,
JOELT
Thanks for the tip's, the postman should arrive in less than an hour
I hope i can speed up the building process by using my old diffs and shocks because tomorrow is the only available practice-session before DHI Cup. Anything i should change on the car for CS22's on carpet?
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
