Old 01-01-2005, 06:35 AM   #11446
lem2's Avatar
Default Question Again.
Do you guys feel any difference in handling when using graphite or plastic arms? Plan to stock up on some parts?
Thanks! Lem
lem2 is offline   Reply With Quote
Old 01-01-2005, 07:22 AM   #11447
I built my SDW yesterday and wow, what a nice kit it is. All falls together so well. The only gripes i have is the cutting and filing you have to do to the plastics. Rick
Rick Draper is offline   Reply With Quote
Old 01-01-2005, 08:01 AM   #11448
schreff's Avatar
Send a message via AIM to schreff
Rick, I agree with you completely. I built my SDW this week. Definitely one heck of a car. But what a pain it is to trim the arms so they don't hit the tranny cases and filing the castor blocks so the universals don't rub. So now, anytime you break an arm, you have extra work to do before just slapping an arm on.
One thing I really do like is that they put the extra set of holes up in the chassis to use the normal SD arms mounts along with the normal SD arms. They did their homework with this car.
As far as normal arms vs. graphite -- On my Rayspeed SD, I went from the normal plastics arms to the HD graphite arms and I felt some decent differences. One thing is that it responded to "smaller" suspension changes better. Oh, that and it took a pretty big hit in the main without breaking. That was nice too.
Happy New Year guys.
Later,
Jason
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 01-01-2005, 04:46 PM   #11449
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
how light is the cgm lightweight chassi comparing to the original one????
is possible to get the cgm version weighing the same as the carbon fiber version (or something like 1450g)???
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 01-01-2005, 05:15 PM   #11450
lem2's Avatar
It may be possible, but costly. Ti Screws, CVD's DriveShafts, Input shafts, lt.wt motor holder, small and lightweight electronics, carbon shafts and so on. CF towers might also help.
Good Luck!! Peace and Happy Racing!
Lem
Old 01-01-2005, 05:18 PM   #11451
If you race 540 stock it is, my CGM was like 1460-70 grams ready to race so if you put in a few light weight parts it should be possible. But if you run mod with it's heavier batteries I wouldn't like your chances. I've read posts where people running mod have added all the light weight stuff they can think of and still be above 1500 grams.
But 1500 grams is the weight limit anyway isn't it?
Mabuchi540 is offline   Reply With Quote
Old 01-01-2005, 05:41 PM   #11452
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
There's a CGM 'lightweight' chassis out?
- jaybee
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-01-2005, 05:59 PM   #11453
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
My CGM weighs in at around 1460-1470 concidering what scale is used, Ti screws, LW chassis, Alu CVD's and inputs, graphite shaft, Rayspeed towers, LW motormount, HD arms and probably more including taped battery
It's probably a little "too much" but i like the car better when it's leaded to a nearly perfect 50/50 side-side weight
btw, anyoe know how i can get rid of oversteering into corners and totally understeering out of corners? The car was quite fast last race (managed to get 3rd in A but it was tot inconsistent), i tried many things. Softer front springs, more angle on the front shocks and so on, but never really find a cure on the problem, anyone got a tip?
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 01-01-2005, 06:18 PM   #11454
- jaybee
yeps......
http://shopping.rcmodel.hk/popup_image.php?pID=4164
but i think is better drilling the chassi instead of buying this milled optional chassi......
Salvadori Racing
Old 01-01-2005, 07:28 PM   #11455
Your understeering problem coming out of corners is a weight transfer problem. You transfering to much weight to the rear wheels when you start to get back on the throttle. I suggest you stiffen the rear springs. Going to softer front springs only causes your car to oversteer worse. When you enter the corner your off the throttle, all the weight is transfering to the front wheels putting softer springs on the front only allows more weight to transfer to the front. So stiffen the front springs.
kmorast is offline   Reply With Quote
Old 01-01-2005, 08:29 PM   #11456
racer's Avatar
anyone know of an online store where i can get a Yokomo SDW?
and if they ship internationally as well
Thanks in advance!
racer is offline   Reply With Quote
Old 01-01-2005, 08:32 PM   #11457
www.stormerhobbies.com
the product status is IN STOCK.....
Salvadori Racing
Old 01-01-2005, 08:58 PM   #11458
oversteer in, understeer out, huh. sounds familiar, try anti-squad at the rear, starts with 1 deg, it helps a lot.
caveman is offline   Reply With Quote
Old 01-01-2005, 09:03 PM   #11459
Matt Howard's Avatar
anti squat should free the car up off power and lock the rear in on power so I don't think he wants to do that. If anything take out all the antisquat if you're running any.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 01-02-2005, 12:07 AM   #11460
JayBee's Avatar
Post
Any thoughts on running a Mazda RX-8 and Caddy CTS on a smallish-medium/ technical carpet track guys?
- jaybee
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
