Yokomo MR-4TC SD
Old 12-30-2004, 05:34 PM
  #11401
beer_drinker's Avatar
The car weighed in at about 1600g with a Novak Brushless. I suspect that it will be a lot lighter with my Nosram Dominator Evolution and a stock motor.
beer_drinker is offline
Old 12-30-2004, 07:26 PM
  #11402
Registered User
ritchie's Avatar
Originally posted by rc_bam226
Its the same arms as the new HD ones are, the part number is SD-008HG.
sorry, sdw short arms are not the same as the heavy duty arm, the sdw does use the hd arms in the rear.
ritchie is offline
Old 12-30-2004, 07:27 PM
  #11403
rc_bam226's Avatar
my bad....
rc_bam226 is offline
Old 12-30-2004, 08:38 PM
  #11404
Matt Howard's Avatar
Originally posted by daniz24
Anyone have tried the S-World 4M or the T6 Motors from Yokomo?
Yokomo USA is supposed to get some of the new motors in next week, at least some of the T6 motors anyway.
Matt Howard is offline
Old 12-30-2004, 09:26 PM
  #11405
Regional Moderator
daniz24's Avatar
The 4M is four magnet type. Is it the same as Reedy Pt? Thx
daniz24 is offline
Old 12-30-2004, 09:32 PM
  #11406
I'm 99% sure it is but I haven't seen anything saying they are the same.
Old 12-30-2004, 10:11 PM
  #11407
Registered User
ritchie's Avatar
i have a s-world 9x2, very happy with it.
ritchie is offline
Old 12-30-2004, 10:27 PM
  #11408
lee82gx's Avatar
beer_drinker:
someone else has the same problem as you with 3600's
http://www.rctech.net/forum/showthre...threadid=58621
seems he solved it by traying the cells.
Also, it now seems very likely that your cells didn't come with the same amount of charge compared with each other. some cell would peak and some not during charger, causing erratic discharge.
I wouldn't venture to charge them or use them anymore b4 traying it, and making sure each cell is not dead 1st.
BTW, nice car, I lightened mine by using:
alu input shafts(Tobee), alu light shaft(niki), alu motor mount(niki), titanium screws, low profile servo and hopefully Alu rear dogbones.
lee82gx is offline
Old 12-30-2004, 11:22 PM
  #11409
SpeedTech's Avatar
Hi Guys,
On Yokomo's next shipment, we should be seeing almost all of the SDW parts as well. We will try to get them on the new website as soon as possible
Steve Wang
SpeedTech is offline
Old 12-30-2004, 11:35 PM
  #11410
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
ritchie is right, the arms are not 'exactly' the same. but the 2 and only differences I see when holding them up to one another is-
1. the location of the hingepin holes, which are placed approximately 2 maybe 3mm closer to the 'body' of the arm &
2. the deletion of a lower shock positioning hole and actually if any of you have the HG arms, it looks like on the SDW arms those two lower holes are placed in the spaces between the holes on the HG arms. So I guess that would make a 3rd difference.
Hope you guys understood that?
But at any rate, you can still use the HG arms on the SDW; you'll just increase the arm span on each side by 2-3mm. You'll also be taking a risk of weakening the arm (perhaps) since the material you would have to shave off on the one end would leave about 3mm for the hingepin to cling to. So is it worth it- that's up to you
- jaybee
JayBee is offline
Old 12-30-2004, 11:55 PM
  #11411
Alot of the factory guys are running the standard lenght arms with the standard suspension mounts on their cars when they want to lose some steering, I'm being told the shorter arms give the car ALOT of steering.
Old 12-31-2004, 12:47 AM
  #11412
JayBee's Avatar
Post
The factory guys are using 'em so I would say it is worth a shot... thanx Matt
- jaybee
JayBee is offline
Old 12-31-2004, 05:38 AM
  #11413
Got my SDWR today but i am not sure what to do with it I might keep it or i might sell it on, that does everyone think?. Rick
Rick Draper is offline
Old 12-31-2004, 05:39 AM
  #11414
Keep it!! This car is awesome
darulor is offline
Old 12-31-2004, 06:45 AM
  #11415
If I understand the SDW short arm discussion correctly. I will be able to install the short arms on my CGM by changing the suspension mounts and arms; is that correct?
kmorast is offline
