Old 12-29-2004, 01:33 AM   #11341
lee82gx's Avatar
Originally posted by beer_drinker
Hi guys,
I got my CGM for Christmas, along with titanium screws, a lightweight Yokomo driveshaft and an aluminium motor mount. I finished building it today. It went together great (even though it's only my 2nd rc car) and is really fast with my Novak Brushless, which i'm running in it at the moment. I only tested it on the street though.
I still have to weigh it, but then i'll post some pictures
we have almost the same setup!
hope you enjoy your CGM as much as i do!
lee82gx is offline   Reply With Quote
Old 12-29-2004, 01:59 AM   #11342
johnbull's Avatar
Originally posted by PROMODVETTE
seems like everyone was saying to get the tub type chassis now the worlds one is a flat type like the ssg...why?
A flat chassis car is OK for real experts that don't wallop curbs.
For the likes of me and a million other RC enthusiasts the CGM is the safest bet. In the hands of Masami the SDW will be a bit quicker, but with all respect, I doubt whether you or I would be able to appreciate the difference. Having said that, the SDW is a lovely looking car, even just to keep on the shelf and look at.
Proof of what I am saying came again last week. My son drove my CGM for the very first time last Sunday and was immediately doing the same lap times he does with his TC3 with which he has won 4 National championships and looks well on his way to a fifth. And those lap times are well over a second a lap quicker than I have ever done.
Incidentally, he also reckons the CGM is quicker round the corners and easier to drive, than his TC3 - and his TC3 is ballistic!
johnbull is offline   Reply With Quote
Old 12-29-2004, 02:23 AM   #11343
Trader Rating: 60 (100%+)
cool...i got a ssg and was thinkin about buying the conversion to make it the tub chassis (local track has carpet and asphalt) but if its really about the regidity (for high bite) i could just make something or stack another upper on it to make stronger. BTW stormerhobbies.com has the worlds edition in stock
PROMODVETTE is offline   Reply With Quote
Old 12-29-2004, 03:09 AM   #11344
beer_drinker's Avatar
I already do! I'm going to practice and properly set up my car tomorrow.
Oh, and I just bought a new assembled 3600HV battery from Trinity. I went to charge it but it only takes about 1000mah charge, then the charger switches off. I'm using a Millenium Pro. What should I do?
beer_drinker is offline   Reply With Quote
Old 12-29-2004, 03:14 AM   #11345
lee82gx's Avatar
your charger is false peaking.
either that or you have a poor power supply(which i don't think is the case)
Anyway, just charge it again. It's normal for the pack to false peak when it's been stored for a long time.
Old 12-29-2004, 03:21 AM   #11346
I didn't really explain it fully. When it finishes charging at 1000mah it's fairly warm, like it's fully charged. When I restart the charge it will charge until it reaches 300-400mah and does it again, this time hotter than when it stopped the last time.
I can also charge all other batteries successfully
Old 12-29-2004, 03:26 AM   #11347
lee82gx's Avatar
that would mean you're pack arrived partially charged already.
give it a discahrge or drive it on the car. finish the pack and try charging it back up.
it should be right then,
Old 12-29-2004, 03:31 AM   #11348
The first time this problem occured, I thought so too, so I did discharge it on a 20A bulb discharger. It only lasted about 3-4 minutes.
Old 12-29-2004, 03:35 AM   #11349
lee82gx's Avatar
if your pack is side x side i'd check each cell's voltage. there could be a dead cell in it.
Old 12-29-2004, 03:56 AM   #11350
OK, I can't really check the voltage of each cell, so i'm discharging the pack again to 5.4 volts. The lights on the charger are very bright so I think all 6 cells are functioning.
Old 12-29-2004, 05:19 AM   #11351
asw7576's Avatar
Do you have voltmeter ? you'll be screamin to know if one of the 6 cells is almost dead. Almost dead cell usually shows low voltage reading.
Old 12-29-2004, 05:43 AM   #11352
I dont have a voltmeter, but i'll see if i can borrow one from someone tomorrow. I dont think there is a dead cell, because when I discharge them all the cells get equally hot (measured by touch) and the lights on the discharger are just as bright as any other of my packs. I don't really know what the problem is.
Old 12-29-2004, 05:53 AM   #11353
lee82gx's Avatar
maybe all it needs are a few cycles to get back in shape..
as a rule i try to avoid trinity consumables and sanyo batteries
Old 12-29-2004, 06:47 AM   #11354
Matt Howard's Avatar
the CGM tub chassis is stiffer than any of the other SD chassis, the flat graphite ones flex a bit more giving the car more traction. If I had only one type to get to race on multiple surfaces it would be the CGM. If you can afford two cars then the flat graphite chassis are probably slightly better on low traction tracks due to the flex.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 12-29-2004, 06:53 AM   #11355
johnbull's Avatar
MATT>
I think we're pretty much in agreement here.
Happy New Year.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
