Old 05-05-2003, 09:42 AM   #1096
rc-zombies's Avatar
Originally posted by futureal
Darkseid: My modification of choice is to flip the server 90 degrees (as somebody earlier on here has done), using a Futaba S9550 digital servo. The case is about half the size of a normal servo, which then leaves room to mount the XXtra and GT7 side by side.
I did the same mod as well...w/S9550
There is alot more room now for any size electronics...
I'll also be using the GT7 and Futaba HRS receiver.
Old 05-05-2003, 09:44 AM   #1097
rc-zombies's Avatar
Originally posted by Darkseid
futureal: I haven't given up on that idea yet. I just wanted to run my electronics mounted in this configuration first to see if re-mounting the servo is even neccesary. So far, for me, I don't think it will be.
I also like having my reciever mounted on its side. I have had glitching problems in the past with the XXtra when its been sitting flat.
for glitching problems...try using copper shielding tape on the bottom of the receiver. they can be found a larger electronics stores.
Do you guys think that the front dog bone is a little short...it's almost touching the blue diff retainer ring. compared to the rears..which are more recessed into the diff. ..
Old 05-05-2003, 12:44 PM   #1098
Regional Moderator
Darkseid's Avatar
It seems like it really wouldn't matter. Theres still plenty of room between the retaining ring and the dog bones up front.
TLR 22...Tamiya F104...
Old 05-05-2003, 12:45 PM   #1099
rc-zombies's Avatar
just curious.... we had this same problem with the Pro3's bones coming out..
Old 05-05-2003, 05:18 PM   #1100
Regional Moderator
Darkseid's Avatar
Oh, your worried about them coming out. Well considering how hard it is to get the bones at just the right angle so that you can remove the front diff completely.......I don't think they're going anywhere on their own!
Old 05-05-2003, 05:27 PM   #1101
rc-zombies's Avatar
yes thats true....
this is not the poorly designed purple car that I used to have.
Old 05-05-2003, 06:14 PM   #1102
racer's Avatar
i found that the suspension arms in the front are higher than the rear? is that correct, or have i adjusted front the droop screw too low?
any help would be appreciated.
Thanks in advance!
racer is offline   Reply With Quote
Old 05-05-2003, 08:18 PM   #1103
are they going to make graphite arms and other parts? im finding alot more i dont like about this car.
Chris@WeaponR is offline   Reply With Quote
Old 05-05-2003, 09:07 PM   #1104
rc-zombies's Avatar
Sooner or later there will be graphite parts for the car. Square RC just released Ti axles, and f/r Ti input shafts. They will probably release an alum. bulkhead..as they did with the EVO-III, +more to come... Tobee craft released option parts as well... HD blue alum. dog bones, Blue alum. input shafts, and servo mounts. unfortunately they're only available in Japan. We'll see alot of option parts released in the next couple of months...
Old 05-05-2003, 09:57 PM   #1105
JimmyMac's Avatar
Dark... try taking out some Droop in the rear til you can get it setup right. That's what I had to do. Waiting on my RaySpeed springs to arrive later this week. But looks like rain all week long!! Hopefully it'll be over when the weekend hits. Have some more testing to do before the Regionals in 2!
JimmyMac is offline   Reply With Quote
Old 05-05-2003, 10:31 PM   #1106
CSF0623's Avatar
Do you happen to have a web site for these companies? Thanx in advance!
CSF0623 is offline   Reply With Quote
Old 05-05-2003, 10:41 PM   #1107
CSF0623's Avatar
Thanks in advance!
Check to see if your front shocks are longer than ur front droop also use the longer shock end.
Old 05-06-2003, 07:41 AM   #1108
IH
IH's Avatar
Thumbs up
Just received my SD today. I will assemble it on Friday and race it
on Sunday. I am so curious
Greets,
IH
IH is offline   Reply With Quote
Old 05-06-2003, 09:15 AM   #1109
rc-zombies's Avatar
http://www.rc-square.com/
http://www3.kcn.ne.jp/~tobee/
Old 05-06-2003, 09:59 AM   #1110
SpeedTech's Avatar
Hi Guys,
We might be getting some titanium screw kits for the MR-4TCSD later on this week. I'll keep you guys posted. The Yokomo MMS (Motor management system) and HMM (Hyper Motor Mate) are both in stock.
CSF0623,
you ready for SoCal tonight?
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
