Old 12-08-2004, 01:53 PM   #11071
Originally posted by Matt Howard
Yokomo USA should have the SDW's in sometime next week so they're probably out in japan right now or they will be soon.
So just in time for xmas. Cant wait this car is going to be the dogs for any spec racing.
Slick990 is offline   Reply With Quote
Old 12-08-2004, 01:59 PM   #11072
sosidge's Avatar
Originally posted by lee82gx
Is it possible to have the car PERFECTLY flat, parallel to the ground with perfectly EQUAL left-right tweak or downtravel?
Only two of these three settings are important.
The chassis must be built perfectly straight, and the droop/downtravel should be set even on both sides.
Then set the shock pre-load to get a tweak free car - it will handle evenly on the track, even if it looks a little uneven on the bench.
It's unlikely you will get the pre-load even on all 4 corners of the car as the weight distribution is far from perfect.
My problem is that I can't seem to get the kingpin to thread straight into the hub.
I'm surprised by this - I pretty much do as pops suggested - the kingpins will find their own straight thread if treated with delicacy!
Old 12-08-2004, 05:56 PM   #11073
lee82gx's Avatar
that would mean i will have slightly (0.5-1.0mm) different ride height left to right?
I'm driving the CGM, I'm sure chassis is not bent or tweaked.
lee82gx is offline   Reply With Quote
Old 12-08-2004, 08:22 PM   #11074
rough512's Avatar
Also, if you're involved in a big wreck you might want to loosen all the top deck screws, put the chassis on something perfectly flat and then tighten the screws back down to prevent chassis tweek.
Will countersinking the topdeck screws help eliminate chassis tweak?
rough512 is offline   Reply With Quote
Old 12-08-2004, 08:24 PM   #11075
Matt Howard's Avatar
Yes
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 12-08-2004, 08:26 PM   #11076
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Originally posted by forty6
Did they release it in Japan yet?
RC-Champ in Japan have them instock. Still considering if I should spend 52,000 YEN
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 12-09-2004, 02:24 AM   #11077
sosidge's Avatar
Probably yes. As long as the car drives right, a small difference in the static ride height won't matter.
Old 12-09-2004, 01:25 PM   #11078
Lonestar's Avatar
you can also use contersunk screws without countersinking the plate. Ugly but really works a charm.
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 12-09-2004, 10:02 PM   #11079
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
Hey guys
Just ordered all of the alum. suspension blocks. Question though- besides the pros of being a more accurate fit, and of course BLUE , what are some of the cons...
- jaybee
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 12-09-2004, 10:16 PM   #11080
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
Matt have you ran the Rayspeed shock bladders and if so what tuning effect do the have...I saw that there are 3 colors and did not know if you have tried them?
Looking to run carpet and did not know if the stock ones are the best ticket???
Jeff
Jeff Werner is offline   Reply With Quote
Old 12-09-2004, 10:26 PM   #11081
Jeff
I tried them and I honestly couldn't feel a difference between the hardnesses. I'm using the yellow ones right now and they feel the same as the stock ones. If you need to replace your stock bladders then I would recommend trying them, but it's not something that's really useful in setting up your car.
RCTech #361
Old 12-09-2004, 10:27 PM   #11082
Originally posted by JayBee
Hey guys
- jaybee
they're slightly heavier and I've heard on rare occasions they can bend slightly.
RCTech #361
Old 12-09-2004, 10:43 PM   #11083
JayBee's Avatar
Wink
Thanx Matt... I'm already committed ...
Damn, too bad about the shock bladders, I was thinking about ordering them too
Also, the ceramic ball-bearing set, does it comes complete with 'EVERY' ball-bearing for the car?
- jaybee
Old 12-10-2004, 01:03 AM   #11084
johnbull's Avatar
Hi friends. Haven't been here for a while.
Christmas Cup meeting in a few days so have converted the CGM back to mod. What fun.
I've also finally succumbed. I've dished out for some ceramic bearings and am impressed by the car's smoothness.
Still by far the best car I've ever had.
johnbull is offline   Reply With Quote
Old 12-10-2004, 04:05 AM   #11085
stinkypop's Avatar
I have to admit I've bent a front one of these running an eight single, but if you'd seen my driving you would understand why it was bent.
stinkypop is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
