Old 11-23-2004, 02:31 AM   #10816
Matt Howard's Avatar
nothing new here, it's starting to get cold. I might try some of those Ti CVd's in the spring when the outdoor tracks open back up here.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 11-23-2004, 05:16 AM   #10817
Trader Rating: 35 (100%+)
Originally posted by Matt Howard
I don't know if the team bomber shaft is any lighter but I'm almost positive if you twisted both ends of your yokomo shaft it will feel like a noodle.
I've checked my shaft each time I've rebuilt my transmission and it seems to be as solid as when it was new.
I don't know if it made a difference or not, but before I installed my Yokomo graphite shaft, I applied a coat of the thin CA. The CA actually seemed to soak into the fibers of the shaft. I then used a very fine sand paper to smooth the surface of the shaft which became a little rough.
I weighed the shaft afterwards and it was 1 gram less in weight than the aluminum shaft that came with my kit. I didn't think to weigh the graphite shaft before applying the CA.
If I can locate a source for the Bomber shaft I'll give it a try for comparrisons sake.
Geppetto is offline   Reply With Quote
Old 11-23-2004, 05:34 AM   #10818
The CA probably did the trick. I think speedtech is the only source in the states for the team bomber shaft, you can try the overseas online stores, they might have one.
RCTech #361
Old 11-23-2004, 04:34 PM   #10819
Whats the spring rate of the rayspeed white springs? Also what sort of shock length front and rear do i want indoor on carpet with rubber tyres? and what amount of camber is a good starting point? Thanks Rick
Rick Draper is offline   Reply With Quote
Old 11-23-2004, 09:45 PM   #10820
I don't know the rate on the RS white springs, I don't have my chart on this computer. For rubber tire carpet racing I usually set my droop to 7 in front and 5 in the rear (using the droop gauge). For camber I usually ran 1 deg up front and 1/2 in the rear.
RCTech #361
Old 11-23-2004, 09:48 PM   #10821
vtl1180ny's Avatar
R/C Tech Charter Subscriber
Is there a Center One way for the SD, I know there are one's for the TC3.... The front one way works great on my track but it's too hard on axels....
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 11-23-2004, 09:57 PM   #10822
Blakesrc's Avatar
Send a message via AIM to Blakesrc
Spring rates:
Yokomo
Spring Rating [lb/in]
Orange 18.87
Green 16.06
Pink 14.93
Yellow 14.71
White 12.94
Blue 12.12
Rayspeed
Gray 19.90
Red 18.26
White 17.17
Yellow 14.87
Blue 14.29
Green 13.20
Blake
Blakesrc is offline   Reply With Quote
Old 11-23-2004, 09:58 PM   #10823
forty6's Avatar
I don't know if they suit one chassis better than the others, I wouldn't see why they would though. I'll probably just get another new rear tower and cut off the body mounting holes and use it up front.
Matt,
Any luck on Billy's setup?
forty6 is offline   Reply With Quote
Old 11-23-2004, 10:17 PM   #10824
danjoy25's Avatar
Trader Rating: 37 (100%+)
Originally posted by Blakesrc
Spring rates:
Yokomo
Orange 18.87
Green 16.06
Pink 14.93
Yellow 14.71
White 12.94
Blue 12.12
Rayspeed
Gray 19.90
Red 18.26
White 17.17
Yellow 14.87
Blue 14.29
Green 13.20
Blake
Does anyone know why Yokomo and Rayspeed springs are way to soft compared to a Associated or Xray Springs, which can are rated up to 40 lb?
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 11-23-2004, 10:21 PM   #10825
Registered User
ritchie's Avatar
i believe these are mostly meant for pavement, i think most guys use either the yokomo gas car springs or the assoc springs for carpet.
ritchie is offline   Reply With Quote
Old 11-23-2004, 10:22 PM   #10826
Originally posted by forty6
Matt,
Not yet, whenever I remember to call it's like 3 am back in the states. I'll call tomorrow since it will be thursday morning here and wednesday afternoon on the west coast.
RCTech #361
Old 11-23-2004, 10:23 PM   #10827
Not that I've seen.
RCTech #361
Old 11-23-2004, 10:24 PM   #10828
exactly, I ran AE springs when I ran foam carpet.
RCTech #361
Old 11-24-2004, 12:11 AM   #10829
Slingblade's Avatar
Default roll out......
I have a cgm and run stock with rubber on a fairly tight technical track. What would be a good starting point spur/pinion combo for this? (64p) What is the ideal amp draw I should shoot for? Rollout? Thanks in advance, 'blade
Slingblade is offline   Reply With Quote
Old 11-24-2004, 03:05 AM   #10830
Default Re: roll out......
I'm assuming you're runnning a monster stock motor, for that on a tight track I would start my gearing at a 7.5 overall ratio. A 100 spur and 31 pinion will give you a 7.59 ratio. I have no idea what kind of amp draw you should be looking for, sorry.
RCTech #361
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
