Old 11-20-2004, 09:16 PM   #10786
vtl1180ny's Avatar
R/C Tech Charter Subscriber
Originally posted by Blakesrc
vtl1180ny,
You are correct on the shore ratings. The double pink/orange is also called Cyan which is 35 shore with a 55 shore outer ring. The tires do wear quite fast but i guess thats the price you pay for traction in mod. I will probably try double pink/orange in front and double pink in the back next week for even more steering. The tossolini setup requires the front arms to be cut so you can move them back an additional 3mm and a couple of the suspension blocks to be shaved 1-2mm. If you decide to do it, take your time, the end result is well worth it though.
Blake
How much is truely gained by that setup? Althought I have the capabilities to perform the mods I don't think I have the patience these days...
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 11-20-2004, 10:58 PM   #10787
Matt Howard's Avatar
with the shaved front arms you get more steering, with the shaved blocks in the rear you're lowering the rear rollcenter so you'll have more rear traction. Overall the car will be more responsive and have more grip. IMO it's worth it for foam carpet racing.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 11-21-2004, 12:16 AM   #10788
Blakesrc's Avatar
Send a message via AIM to Blakesrc
vtl1180ny,
Matt just said it exactly. The car is just "planted" and super responsive. The only issue i am having with it is i cant find any 28lb springs for the front. I have tried 25's and the front dives a bit to much entering turns if you arent careful, and i have tried 30's and it pushes a bit. If you are going to be racing on carpet a lot its deffinetly worth trying.
Blake
Blakesrc is offline   Reply With Quote
Old 11-21-2004, 12:18 AM   #10789
I used AE purples in front and AE coppers in the rear, if I remember right they are 30 and 25 lb springs
RCTech #361
Old 11-21-2004, 12:20 AM   #10790
Blakesrc's Avatar
Matt,
yep that is what i ran last week and the car pushes a bit, i dont know what springs Chris had on the front that were 28lb, i havent seen any spring chart with a 28lb spring.
Blake
Old 11-21-2004, 12:23 AM   #10791
Matt,
Blake
They were springs for the Yokomo GT4 nitro car, I don't know off hand what color was 28 lbs though.
RCTech #361
Old 11-21-2004, 06:56 AM   #10792
mymax's Avatar
I run Xray spring on my CGM
Violet #308396....28lb Xray spring set
mymax is offline   Reply With Quote
Old 11-21-2004, 07:24 AM   #10793
Thanks for the info
RCTech #361
Old 11-21-2004, 08:37 AM   #10794
hi
just order a cgm conversion for my ssg and was wondering what setup changes i am going to have to make? and whether i shud fit a cgm rear shock tower to the front or not? and other things like that? not any general things i know what everyone has been doing to lightnen them up as everythig similar to that, i just would like to kno about general setup chnages i wil have to make.
thanks
A Gower
agower is offline   Reply With Quote
Old 11-21-2004, 12:21 PM   #10795
asw7576's Avatar
I just got back from Japan today ..... and yes I went to RC Champ - Tokyo for my RC shopping needs. Anyway, the shopping experience was not good because I met two bada$$ shopkeepers: the chubby bald got B+ and the small lazy look got A- for being lousy characters
Here is my tip when shopping overseas: If you don't smile & you speak necessarily, they ( the locals ) will treat you right !!! If they act rude, you slam the money + merchandise on the table
Regardless the unpleasant experience, the shop have complete stocks of mr4tc sd. I get all the spare and hop up parts for my yokomo.
Old 11-21-2004, 01:03 PM   #10796
vtl1180ny's Avatar
Originally posted by agower
hi
thanks
A Gower
Go to yokomo.tk and use Mo's carpet setup... It's very close to where you want to be....
The car likes soft tires from what I'm finging out, see my above post....
I may try the Tossolini setup if I get adventurous....
Otherwise the car is great.... I haven't touched my Tc3 since converting to CGM....
I still lurk....
Old 11-21-2004, 06:36 PM   #10797
Regional Moderator
daniz24's Avatar
Did you get the Team Bomber Shaft?
daniz24 is offline   Reply With Quote
Old 11-22-2004, 02:27 AM   #10798
stinkypop's Avatar
Just out interest has anyone tried there cgm setup like Tossolini's carpet setup on asphalt with a mod motor?
stinkypop is offline   Reply With Quote
Old 11-22-2004, 03:19 AM   #10799
I tried the shaved front arms but the shorter wheelbase made the car too twitchy for me.
RCTech #361
Old 11-22-2004, 03:20 AM   #10800
I got confirmation from Yokomo USA that the limited kits will be out the beginning of december, no exact date yet.
RCTech #361
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
