Old 05-04-2003, 02:58 AM   #1066
and another...
Chris@WeaponR is offline   Reply With Quote
Old 05-04-2003, 02:59 AM   #1067
and one that just looks cool i think....
Old 05-04-2003, 03:03 AM   #1068
Today i ran the car at the carpet track and i since i have no hop up and i need springs that are on order i got a decent time of 13.8
I also broke a arm like everyone has im sure but heres something you might want to look at.
Old 05-04-2003, 05:35 AM   #1069
Kenneth Tan's Avatar
Originally posted by KilRuf
Anyhow, goin to bed. Just got back from X2. Pretty good movie. Especially like Night Crawler! Now just gotta wait for Matrix Reloaded!! Catch yall L8Rz!
Mystique is one HOT babe!
Kenneth Tan is offline   Reply With Quote
Old 05-04-2003, 07:54 AM   #1070
Got our kit built this weekend. My initial impressions of the SD build:
Upside: Well-made parts and molds. Drive train is very free without the work you put into freeing up the TC3.
Downside: Top plate is too flexy making the overall chassis a bit more flexy than you'd expect with a 3mm bottom plate. Wish Yok had spec'd teflon-sealed bearings, aluminum CVDs, fewer steel screws and maybe fewer plastic parts. Can't use AE springs (too long). Droop screws don't rest on chassis plate with kit suspension set up.
coolrcdad is offline   Reply With Quote
Old 05-04-2003, 09:02 AM   #1071
OSherman's Avatar
Originally posted by coolrcdad
...Downside: Top plate is too flexy making the overall chassis a bit more flexy than you'd expect with a 3mm bottom plate. Wish Yok had spec'd teflon-sealed bearings, aluminum CVDs, fewer steel screws and maybe fewer plastic parts. Can't use AE springs (too long). Droop screws don't rest on chassis plate with kit suspension set up.
your chassis has a lot of flex?.. ...i think just the opposite about mine...i think it is one of the stiffest dual-deck (actualy tripple-decker) chassis' on the market...just a lil bit of twist in it, but the fore and aft is like a brick...SOLID....
had a problem with the droop issue to, but only up front...solved it with the longer lower shock ends.
scale of 1-10...9.85 Yokomo did a lot of research when developing this car...i see a lot things that i wished for in the other shaft cars on, and a few cool things xclusive to the YOK...
may not be teflon shocks..but damn do they go together easily...and no air in there..
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 05-04-2003, 11:45 AM   #1072
rc-zombies's Avatar
yes he top plate is flexy by itself...but when on the chassis...overall the chassis is very stiff.
I was able to get teflon sealed bearing for about $26.00 shipped. THat is a bargain. PM me and I'll give you how to contact her. yes...it's a her..
Old 05-04-2003, 04:53 PM   #1073
peter_robinson's Avatar
Trader Rating: 21 (100%+)
i have to complement yokomo on designing what looks like another contender.
one question though, why is the slotted hole for mounting the servo not countersunk??? it seems funny to over look such a detail.
also...
if anyone knows the internal ratio, and the actual tooth counts on the ring and crown gears, i would be greatful.
peter
For orders or inquiries, email [email protected] Follow RC-Trim on Twitter and Facebook
RC-Trim | Serpent USA | On-Point | Trinity | Revtech | ORCA | BSR | KO Propo | PT RC Racing Oil | WTRC | rcpitwhores.com
peter_robinson is offline   Reply With Quote
Old 05-04-2003, 04:57 PM   #1074
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
hey guys, i have been thinking about getting this car just about how much you guys paid for yours ?
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 05-04-2003, 05:25 PM   #1075
Matt Howard's Avatar
Peter- the internal ratio is 2.353
Tag- www.speedworldraceway.com has them for $279.99, I think Billy still has one or two left.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 05-04-2003, 07:02 PM   #1076
Peter: Sam noticed that, too so he used a hex nut that fits inside the slot and added servo tape to secure the servo.
Tag: We got ours from speedtechrc for $269.
Osherman: we tried the longer shock bottom mounts and thought the front shocks were too long with them.
Ran the car today on carpet with the kit set up and springs (CS27 tires) and it handled very well out of the box. Lots of steering.
Old 05-04-2003, 07:19 PM   #1077
But wait, there's more! . . .
The hex nut in the non countersunk servo chassis hole helps keep the servo from shifting around but the tape is essential.
And, is Yok serious about the kit gear ratio? 5.5?
Old 05-04-2003, 07:30 PM   #1078
THeGame's Avatar
Send a message via AIM to THeGame
whats wrong with the kit bearings ? Also what Cells fit best in the battery slots GP or the Sanyos ? Are you guys running into any problems when building the car ? Do you need to do any Mods to get the drivetrain free ?
THeGame is offline   Reply With Quote
Old 05-04-2003, 07:41 PM   #1079
coolrcdad- that ratio is what they run their 23T stock motors in Japan
Thegame- There's nothing wrong with the kit bearings, some people just prefer teflon sealed ones. I'm running the GP's and you just need to file down the battery slots and they fit fine. I haven't heard of anyone having any problems building their kits yet. After about 5-6 battery packs through my car the drivetrain is very free, just space the diffs following the instructions and you'll be fine. No need to shave anything like the TC3.
Has anyone else noticed how quiet the cars are? My car sounds like a belt car, no whine like a TC3 or barracuda
RCTech #361
Old 05-04-2003, 08:08 PM   #1080
OSherman's Avatar
Originally posted by Matt Howard
...Has anyone else noticed how quiet the cars are? My car sounds like a belt car, no whine like a TC3 or barracuda
funny you mention it..today at its first outing, the scorekeeper at our track approaches me and compliments me on how the car looks...and also follows up the compliment with, "why is your car so quiet? you can barely hear it? do you use the brakes?"...i just chuckled..
•KO Propo America
•EXOTEK
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
