Old 11-20-2004, 09:33 AM   #10771
Send a message via ICQ to Cobra81li200
no, torque steer pulls your car to the left, your car may be tweaked to some point (check that l/r droop are the same, especially on the front).
Cobra81li200 is offline   Reply With Quote
Old 11-20-2004, 09:42 AM   #10772
SpeedTech's Avatar
Originally posted by daniz24
Hi, any news about the SDW pricing? Thanks
daniz24,
The pricing should be very close to our estimate. We are also working on a special gift for all pre-order customers I'll let you guys know what it is once I receive it
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 11-20-2004, 09:44 AM   #10773
SpeedTech's Avatar
Originally posted by Midnight
Hey Steve, any idea about when you will get anymore type E bodies?
Midnight,
Just got a fax from Yokomo USA and we should get more on Monday. Yokomo USA also supplies Yokomo Japan with bodies (like the Rayspeed TSX and the Yokomo Type "E") and due to the popularity of these body, Yokomo is trying to keep up the best they can.
Steve Wang
Old 11-20-2004, 10:20 AM   #10774
Have double checked the lengths/heights (using shock length instead of screws for droop) etc of all suspension parts left and right/front and back (with calipers) and all is the same as it should be.
I've also checked steering linkages are same lengths and servo centred (all the obvious stuff) etc.
As this was it's very first time on the ground can't think what else would be causing it other than perhaps the new tires not run it at race speed perhaps?
Had another thought.....I've read posts in here about how sloppy cgm steering is, and I've noticed it on mine as well but with a little more on the left side than the right. Perhaps this is it with the right being in more control?
Mabuchi540 is offline   Reply With Quote
Old 11-20-2004, 04:48 PM   #10775
Try a little bit of toe in to stop your car wondering. Stupid question, but have you set your steering trim while driving the car? Another question, was the surface level? Even a slighlty angled surface will make the car go funny when you grab some throttle. One thing though, your car wont be affected at all by your motor, it will definately be something else on the car or something affecting the car. How much wandering are we talking, and how long does it last i.e. 2, 5, 10 metres? Or just continuos?
Just trying to help . And get yourself to a meeting soon, so you can get help. Ultimate Open in January, and only NZ$10 entry fee .
Trevor is offline   Reply With Quote
Old 11-20-2004, 05:16 PM   #10776
vtl1180ny's Avatar
R/C Tech Charter Subscriber
What is everyone using for tires with the CGM on carpet???? I was using Fast Tires 35/30 rear and 42/26 front... great traction but the rears are wearing quicker than I'd like.... I tried Jaco's Orange/Purple front and purple rear since my LHS stocks Jaco and the car was all over the place.... I'm basically using Mo's CGM setup.... I may just order some more Fast Tires.....
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 11-20-2004, 05:53 PM   #10777
Blakesrc's Avatar
Send a message via AIM to Blakesrc
vtl1180ny,
I have been using jaco and parma purple fronts and double pink/orange rears and the car has been great. I have also been using the tossolini setup fyi.
Good luck,
Blake
Blakesrc is offline   Reply With Quote
Old 11-20-2004, 06:06 PM   #10778
Ducati-Rider's Avatar
Default SB Racing
Blake - do you know when the next SB race is?
Bill
Ducati-Rider is offline   Reply With Quote
Old 11-20-2004, 06:16 PM   #10779
Well yeah it has a little bit of toe, at the moment it's 1/2 a degree.
As for the steering trim, yeah I had to set it to go straight but as I figure it this just means somethings not right in the first place.
As for the wandering, without the trim adjustment I'd say a slight continuous wandering.
Don't know about the ultimate, I wouldn't have been racing long by then, hopefully the Manawatu track will be done soon though as it's in my town.
Old 11-20-2004, 06:22 PM   #10780
vtl1180ny's Avatar
Originally posted by Blakesrc
vtl1180ny,
Good luck,
Blake
I'm not one on this whole color system.... From what I gather, Purple is a 40 shore and pink is a 35 shore? Correct? I think orange is somewhere around a 50 shore....
Purple fronts and dbl pink/orange rears would make more sense to me then the reccomendations I got when I bought the Jaco's....
The 35 shore's in the rear wear much more on the outside than the inside also.... Having a firmer outside ring should help that.....
I was going to try Tossolini's setup, but if I'm corrent he went so far as to trim the arms.....
I still lurk....
Old 11-20-2004, 06:29 PM   #10781
Blakesrc's Avatar
vtl1180ny,
You are correct on the shore ratings. The double pink/orange is also called Cyan which is 35 shore with a 55 shore outer ring. The tires do wear quite fast but i guess thats the price you pay for traction in mod. I will probably try double pink/orange in front and double pink in the back next week for even more steering. The tossolini setup requires the front arms to be cut so you can move them back an additional 3mm and a couple of the suspension blocks to be shaved 1-2mm. If you decide to do it, take your time, the end result is well worth it though.
Blake
Old 11-20-2004, 08:37 PM   #10782
forty6's Avatar
Originally posted by SpeedTech
daniz24,
Steve Wang
Please tell us that it is the Steve Wang bobble head!
forty6 is offline   Reply With Quote
Old 11-20-2004, 08:38 PM   #10783
forty6's Avatar
Default Billy's Worlds set-up
Is it posted anywhere? Matt H.,,,,anybody???? Thanks.
Old 11-20-2004, 08:49 PM   #10784
Matt Howard's Avatar
Default Re: Billy's Worlds set-up
Not that I know of, I'll try to get it next week.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 11-20-2004, 09:06 PM   #10785
Yeah, just adjust your trim. All it means is that the servo horn wasnt put on so that the wheels were perfectly straight. If you have sub-trims on your transmitter, use them to get the horn eyeball-straight while you have the car on the bench, then get the car going straight with your normal trim when you're running it. I'm sure everyone uses the steering trim to get their car to go straight hehe.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
